5w20 engine oil is Honda's new standard. But is it right? - Honda-Tech
Old 04-05-2012, 06:57 PM   #1
rubikscube's Avatar
Default 5w20 engine oil is Honda's new standard. But is it right?
Honda is putting this oil in all of their new vehicles. They're even putting it into older cars, such as the 06-11 Civics and Accords. I know that they switched to it for CAFE standards and all, but it seems deceptive. When you bring you 2006 Civic Si in to Honda for an oil change, odds are that the "bulk oil" they throw in will be 5W20, and not the 30 weight that the car calls for. What do you guys think about this? Do you think 20 weight is good enough, or is it all based on slight gas mileage gains with no regard for pre-mature engine wear?
rubikscube is offline   Reply With Quote
Old 04-05-2012, 06:59 PM   #2
slowly blowing brothers
solbrothers's Avatar
Default Re: 5w20 engine oil is Honda's new standard. But is it right?
some even call for 0w20
solbrothers is offline   Reply With Quote
Old 04-05-2012, 07:00 PM   #3
T3KNiQe's Avatar
Yes really you should use 0w-20, I use it in my s2k
T3KNiQe is offline   Reply With Quote
Old 04-05-2012, 07:03 PM   #4
__oversea's Avatar
Read the owners manual.
__oversea is online now   Reply With Quote
Old 04-05-2012, 07:04 PM   #5
rubikscube's Avatar
5w20 is better for cold starts, but doesn't 5w30 beat it in nearly every other area? I just think it's odd that Honda themselves developed cars around 5w30, but are now switching to 5w20 just to meet CAFE standards. I really wonder how much wear is being done to a 2006 Si that's meant to run 5w30, but the dopes at Honda are throwing in 5w20 since that's the oil they have in bulk and it costs them less. They don't care how long your car lasts, just as long as it lasts the length of the warranty.
Old 04-05-2012, 07:04 PM   #6
rubikscube's Avatar
Quote:
I have. Best friend's Si calls for 5W30. Took it to Honda and they put in 5W20
"Bulk oil".
Old 04-05-2012, 07:05 PM   #7
Bloody Beaver
.Beaver's Avatar
The Honda parts dept had a mat on the counter with a chart of oil weights. Most 5w20 cars had an * by it stating 0w20 was also approved.
.Beaver is offline   Reply With Quote
Old 04-05-2012, 07:05 PM   #8
T3KNiQe's Avatar
bro 5w-20, 5w-30,5w-40,5w-50,5w-a bajillion all perform the same on a cold start. Do you know what those numbers on a oil bottle really mean?
Old 04-05-2012, 07:06 PM   #9
op mad for no raisin
Old 04-05-2012, 07:07 PM   #10
civic08's Avatar
Quote:
what do they mean bro
civic08 is offline   Reply With Quote
Old 04-05-2012, 07:08 PM   #11
rubikscube's Avatar
I do, I meant to say 5 is better at cold starts than 10, but didn't type it out. Does anyone really think 5w20 is as good as 5w30 for cars like the Si that were developed to run 30 weight? What about Lance? 30 weight, 40 weight?
Old 04-05-2012, 07:08 PM   #12
Occupy GDD
Alex_G's Avatar
I would never run a thinner oil than spec'd for the engine. Get a 30 weight in there. Thats not to say a 20 weight is bad, its a very good oil for the right application.
Alex_G is offline   Reply With Quote
Old 04-05-2012, 07:11 PM   #13
rubikscube's Avatar
Quote:
Originally Posted by rota92 View Post
I run 5-20 Mobil1 in GF's 07 EX for ~10k until I change it. Runs like a boss. Oil report came back minty fresh.
I think you should talk to the dealer, doesn't sound like a common thing to do if that's not what the manual and the oil cap say lol
I called every dealer in the area. All of them put in the 5w20 "bulk oil" which they claim is a synthetic blend. There are even dozens of posts on 8thcivic about people in other states that have been given 5w20 without knowing it. I'm sure it's not a huge deal, but seems a bit odd to me. They went to the 20 weight purely to satisfy CAFE standards.
Old 04-05-2012, 07:12 PM   #14
furious94ls's Avatar
My fathers TSX was using a little more oil than normal with no abnormal signs of it (leaks/smoke) He was having his oil changed at the dealership.
I decided I'd be doing the oil changes for him from now on. I use Penzoil 5w30 high mileage with an OEM filter. The car now requires NO oil to be added in the 3k oil change. Before it was 1.5quarts at about 2k.
5w20 and 5w30 flow the same when cold. Hence the 5. If the car calls for 5w30 don't put 5w20 or 0w20.
furious94ls is offline   Reply With Quote
Old 04-05-2012, 07:12 PM   #15
rice_classic's Avatar
Quote:
You have your numbers backwards.
These 2 are identical for cold starts because they both start with the number 5.
Start here:
http://www.bobistheoilguy.com/motor-oil-101/
Read all 10 articles.
rice_classic is offline   Reply With Quote
Old 04-05-2012, 07:14 PM   #16
CRX-Kid11's Avatar
i work at a dealer, two different shops but same dealer, somethings we get jobs from other shop witch is a gm shop, we only have 5-20 in are pumps so thats what they get,even if they call for 30, do i think its right? no. do i care? no. just sayin
CRX-Kid11 is offline   Reply With Quote
Old 04-05-2012, 07:14 PM   #17
njn63's Avatar
I'm not sure I understand this statement. CAFE standards only apply to new cars so why would that impact what oil they put in a car at service?
njn63 is online now   Reply With Quote
Old 04-05-2012, 07:14 PM   #18
Can't be Tamed
boredumb's Avatar
40 weight sounds nice
boredumb is offline   Reply With Quote
Old 04-05-2012, 07:17 PM   #19
rubikscube's Avatar
Quote:
Their bulk oil is now 5w20 oil. So when you bring an 06 Si in that calls for 5w30, they'll just give you 5w20 but put "bulk oil" on your receipt because it's cheaper for Honda. Even if it's not as good for your car.
Old 04-05-2012, 07:19 PM   #20
T3KNiQe's Avatar
Quote:
The first digit before the tack is the viscosity of the oil at 74 degrees Fahrenheit. The digits after the tack are the viscosity at normal operating temperature. All cars should use a 0w- oil, which is the thinnest oil today. Their is no oil on this earth that can protect a car on a cold start below 74 degrees. A 0w will provide the quickest protection at 74 degrees, then 5w at a higher temperature, 10w and so on etc etc.
Also another thing is oil pressure doesn't equal lubrication, oil flow equals lubrication. A -20 weight oil has much better flow characteristics when compared to a -30,-40,-50,-60. Even at racing temperatures their is very little difference in oil characteristics. So people who put -40 oil in their car under the assumption that well it revs high and they race are misguided. Theirs a super long article I read about oil one day that took me 2.5 hours to read dispelling all these myths and rumors. I wouldn't even know where to start. It was extremely fascinating to say the least. Most people like myself previously weren't to sure what it all meant anyways.
Old 04-05-2012, 07:25 PM   #21
njn63's Avatar
That's just cheap/lazy. For what they charge for an oil change the least they could do is stock the proper oil... it's not like Honda used a bunch of different weights.
Old 04-05-2012, 07:29 PM   #22
4LugR's Avatar
i think it depends on the dealership. i work at a honda dealership and if you bring in a Si we put in 5w-30 still. we have 5-20 and 0-20 on tap but we have a huge drum of 5-30 and we even have a drum of mobil synthetic 5-30.
pretty much all of honda's cars from 2012 on will be running 0-20. not sure why, but pretty much every honda since 2001- 2011 has been running the 5w-20 oil, but not the Si and S2k.
4LugR is offline   Reply With Quote
Old 04-05-2012, 07:30 PM   #23
rubikscube's Avatar
Quote:
People getting bamboozled. They rapin erbody out here!!
Old 04-05-2012, 07:32 PM   #24
rubikscube's Avatar
How much less protection does a 5w20 provide than a 5w30?
Old 04-05-2012, 07:35 PM   #25
TOO MUCH TORQUE's Avatar
you should see what drivers put in these same hondas OUTSIDE of north america...its clear they use these thin oils to attain better gas mileage.
TOO MUCH TORQUE is offline   Reply With Quote
Using different weight oil than in owner's manual-ok to do? Collsj Tech / Misc 10 01-17-2017 04:12 PM
Manual Transmission Oil Weight? Vague Honda Civic / Del Sol (1992 - 2000) 27 08-22-2015 04:59 PM
Best Motor Oil... themunchkinman Honda Civic / Del Sol (1992 - 2000) 34 04-23-2008 08:29 PM
Royal Purple Oil? mooseheads36 Honda Civic (2006 - 2015) 20 08-22-2006 10:41 AM
Which brand and weight oil do you guys use in your turbo'd honda's? nutsack Forced Induction 11 09-05-2001 12:13 PM
Tags
020, 10w30, 10w40, 520, 5w20, 5w30, engine, flow, full, grades, half, honda, motor, oil, synthetic
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
