1000+ hp S2000 - Honda-Tech
1000+ hp S2000
Old 04-01-2004, 02:11 PM   #1
ITR981002's Avatar
Default 1000+ hp S2000
Is this for real?? This is what was said about the dyno sheet:
here's what you ****** have been waiting for.
he is on the low tech side, and didnt know how to scan it in or have a scanner for that matter.
we still need to tune out the crossover and the we could not
take it past 8000 rpm because it was braking loose the tires it was pretty nasty the way it sounded.
I'm having a hard time believing that this is even possible from a S2000:
ITR981002 is offline   Reply With Quote
Old 04-01-2004, 02:12 PM   #2
Opie's Avatar
Holy ****! Wonder if that's a repost/real though?
Opie is offline   Reply With Quote
Old 04-01-2004, 02:13 PM   #3
domoMKIV's Avatar
Default Re: (opie)
so this s2000 has a 2jz-gte in it, right?
domoMKIV is offline   Reply With Quote
Old 04-01-2004, 02:13 PM   #4
Default Re: 1000+ hp S2000 (ITR981002)
a 1000HP S2K is like me at a bar.... can't hook up worth ****!
I'm not buying it and he shouldn't be sellin it!
Celestion is offline   Reply With Quote
Old 04-01-2004, 02:15 PM   #5
handa's Avatar
Default Re: 1000+ hp S2000 (Celestion)
wow!
handa is offline   Reply With Quote
Old 04-01-2004, 02:18 PM   #6
Lance C's Avatar
Default Re: 1000+ hp S2000 (handa)
good luck with traction buddy!
what size tires are you running?
Lance C is offline   Reply With Quote
Old 04-01-2004, 02:18 PM   #7
ITR981002's Avatar
I've never seen numbers like that from a Honda... but supposedly, its true. Here's more about what was said of this car:
the motor that will be running in the car is close to completion. I should know since i helped with the gathering of brains for the project. I contacted a friend from, (right now a nameless source) to help us with the build up. Every part made for the motor is one off and mostly custom. Countless hours have been spent calculating flow characteristics for the head, and custom intake manifold. The amount of science that went into development of this motor is crazy, even stuff i have no clue about, ie. internal ramming effect of the exhaust gases for the exhaust manifold development.
In addition a new form of injection is going to be used in order to keep the amount of detonation non existant so we can keep relatively close to stock compression on the motor. My acquaintence has been experimenting with a new solute he developed in house that was actually intended for his company, and were looking for a "guinea pig". its gonna be like a mad science project gone wrong when we fire dis bish up.
that's about all the details i can give now, because thats about all i know.
Old 04-01-2004, 02:18 PM   #8
J.R.'s Avatar
If it is one wow, if it isnt one
J.R. is offline   Reply With Quote
Old 04-01-2004, 03:04 PM   #9
Al Bundy's Avatar
I don't believe it. It lost like 125 hp when it dipped into vtec.
Al Bundy is offline   Reply With Quote
Old 04-01-2004, 03:05 PM   #10
potator's Avatar
April fools bitch.
potator is offline   Reply With Quote
Old 04-01-2004, 03:06 PM   #11
ucb
Default Re: 1000+ hp S2000 (Al Bundy)
Quote:
well, they did say they werent able to tune the cross over point.
ucb is offline   Reply With Quote
Old 04-01-2004, 03:18 PM   #12
Z
Old User.
Z's Avatar
Default Re: 1000+ hp S2000 (UCBGSR)
I haven't heard of any S2000 that was making even close to that power. Now all of the sudden one just comes out of no place and makes over 1000whp? I don't think so.
Z is offline   Reply With Quote
Old 04-01-2004, 03:20 PM   #13
Lance C's Avatar
that would suck to have that kind of dip in your power band.... can you imagine accelerating out of a turn and then wham you hit vetc tires rate of acceleration slows then instantly wham its back to normal and your *** end is whipping out of control...
Old 04-01-2004, 03:20 PM   #14
Chairman Kaga's Avatar
Default Re: 1000+ hp S2000 (Z)
It's still April 1.
Chairman Kaga is offline   Reply With Quote
Old 04-01-2004, 03:22 PM   #15
Z
Old User.
Z's Avatar
Default Re: 1000+ hp S2000 (Chairman Kaga)
Quote:
Originally Posted by Chairman Kaga
It's still April 1.
I know. I'm not buying this 1000hp S2000.
The Torque is too high on that dyno anyway.
Old 04-01-2004, 03:22 PM   #16
dgm2's Avatar
i think its a fake.
dgm2 is offline   Reply With Quote
Old 04-01-2004, 03:24 PM   #17
Lance C's Avatar
now that i think about it this has to be an april fools joke...
1. stock compression simply because they didnt know what to make the compression for that kind of hp.
2. usually there is an air/fuel line on the dyno graph
3. no pics, links to threads, owners names... NOTHING
4. once again this simply hasnt been done before by anyone. then out of the blue some guys jsut come out of the wood work and create this monster on their first try..... what did they make first a 2000whp supra?
5. its april fools day
Old 04-01-2004, 03:28 PM   #18
Racer-X's Avatar
Looks like he lost around 250 when he hit vtec.
But even if this is possible it can't be nothing more then a drag car.
Maybe the dyno is screwed??
Racer-X is offline   Reply With Quote
Old 04-01-2004, 04:03 PM   #19
YZF_R1's Avatar
Default Re: 1000+ hp S2000 (Racer-X)
It's impossible to make 1000 HP on stock compression naturally asperated.
YZF_R1 is offline   Reply With Quote
Old 04-01-2004, 04:06 PM   #20
Set Rguy = 'moderator'
Rguy's Avatar
Default Re: 1000+ hp S2000 (YZF_R1)
April fools biotch.
Rguy is offline   Reply With Quote
Old 04-01-2004, 04:22 PM   #21
This One's Avatar
Default Re: (potator)
Quote:
Originally Posted by potator
April fools bitch.
Laughing my ******* *** off.....
This One is offline   Reply With Quote
Old 04-01-2004, 04:37 PM   #22
amir's Avatar
Default Re: 1000+ hp S2000 (Rguy)
Quote:
Originally Posted by Rguy
April fools biotch.
hahaha
amir is offline   Reply With Quote
Old 04-01-2004, 04:38 PM   #23
Smeeg Heed's Avatar
Default Re: (tHIS oNE)
mkay even it if wasn't april 1st I would have said it was fake. The picture even looks horribly fake.
Smeeg Heed is offline   Reply With Quote
Old 04-01-2004, 04:48 PM   #24
ITR981002's Avatar
Quote:
Its not N/A
Old 04-01-2004, 04:51 PM   #25
Oh yeah I forgot I can edit my own title! Yay!
Bishop Don Shizzle's Avatar
1000 hp S2K? Yeah, no.
Bishop Don Shizzle is offline   Reply With Quote
Dyno'ed the s2k Yesturday... ITR0065 Honda S2000 25 08-23-2007 07:39 PM
Dyno chart of AEM V2 intake on BONE STOCK 2004 RSX-S Team 4 All Motor / Naturally Aspirated 11 08-31-2005 08:55 PM
What do dead stock s2000's dyno in at? goingtobefast Honda S2000 20 07-11-2005 02:42 AM
B16A2 dyno problems - VTEC engagement? SiRGodfather All Motor / Naturally Aspirated 5 04-25-2004 06:05 PM
What are the differences between the RSX-S and S2000 engines? Djazair Acura RSX DC5 & Honda Civic EP3 18 06-28-2002 09:43 PM
Tags
1000, 1000hp, 2000whp, bhp, highest, honda, horsepower, hp, lost, monster, motor, s2000, s2k, stock, supra
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
