"Insufficient memory available to complete the operation" - Honda-Tech
Old 10-22-2008, 01:38 PM   #1
Unceasing Measure
Archidictus's Avatar
Default "Insufficient memory available to complete the operation"
This is relatively time-sensitive, so any answers I can get would be wonderful.
To preface this - I've already restarted, rebooted, unplugged and otherwise let my computer cool down.
So I'm working in Adobe Illustrator (here at work) and need to export several files as JPEGs. This has never been a problem before, as the laptop I use is rather powerful and has plenty of space, however, while I can still save changes to the illustrator document (huge file), the program is coming up with this window:
whenever I attempt to export anything (as jpeg, gif, bmp, etc.). This just started happening after I allowed the computer to reboot at the behest of Windows [freak]-Updater. The operating system is XP and the computer has been running fine until this.
Any suggestions?
This is only happening in Illustrator (the program I need right now). I can export and save things just fine in other programs.
Archidictus is offline   Reply With Quote
Old 10-22-2008, 04:21 PM   #2
qhondak's Avatar
i can think of two things. You dont have enough virtual memory, or have have too many applications opened. try closing some applications before exporting those files.
qhondak is offline   Reply With Quote
Old 10-22-2008, 05:43 PM   #3
I root for shitty sports teams
The GreenD16's Avatar
Default Re: "Insufficient memory available to complete the operation" (Archidictus)
How big of files are we talking about? How big of a page file do you have setup? How much RAM?
The GreenD16 is online now   Reply With Quote
Old 10-22-2008, 08:40 PM   #4
egsleepercivic's Avatar
if all this started happening after an update I would sart with a system restore first, prior to the update, if problem persist, then start check memory, pagefile, and file size etc.. like others have mentioned
gl
egsleepercivic is offline   Reply With Quote
Old 10-23-2008, 06:22 AM   #5
Unceasing Measure
Default Re: (qhondak)
Quote:
Neither of those - I tried them before I made the post. This problem just started occurring, and it happens regardless of the number of programs open.
Quote:
I was working off an 8.02 Meg file, exporting no more than a few hundred Kbs at a time - nothing different than I had been doing all day. RAM is over 1000 (hasn't changed since the problem started), page file is very large.
Quote:
gl
I'm probably going to roll it back now, since the tech support guy couldn't figure it out
Thanks for all the help, fellas
Old 10-23-2008, 11:58 AM   #6
eight equals equals equals D
Tim2179's Avatar
Default Re: (Archidictus)
Which version of AI are you using? I have AI 8, AI 10 and CS, but I prefer working in 8 since it's a lot faster than the newer versions.
AI files are usually pretty small (compared to PS files). Do you have linked or embedded images in your AI file? Embedded images will increase you file size and also use more memory. Linked images will decrease your file size.
You can dump your unused swatches and brushes to reduce your file size. (typically these libraries add about 300kb to all your files)
For a temporary fix, you might want to take a screen capture and save that as a jpeg.
Usually if I get an AI memory error, I can close a few programs and it will work, but I'll have to restart AI too.
Tim2179 is online now   Reply With Quote
Old 10-26-2008, 06:28 PM   #7
iam7head's Avatar
Default Re: (Tim2179)
i use to run cs2 and it's doing that to me all the time(one gb rams on XP professional), crashing while saving, memory going thru the roof, etc
go search up adobe to see if your version of Ai have a known problem with accessing rams.(they probably do but the solution is often just to get the newest ai =/ )
<---running cs3 with 6 gb rams and x4 cores
iam7head is offline   Reply With Quote
China used prisoners in lucrative internet gaming work projektt General Discussion and Debate 11 06-12-2011 12:51 AM
Memory leak??? Driving me nuts!!! PatrickGSR94 General Discussion and Debate 7 07-17-2009 10:41 AM
Real problem with Canon Digital Photo Professional exporting .TIFF file instead of .JPEG Puma General Discussion and Debate 1 06-05-2007 09:11 AM
Backing up MS Outlook emails???? The GreenD16 General Discussion and Debate 4 10-05-2004 11:20 AM
Corrupt or missing NTOSKRNL.EXE file. HEEEEELP!!!!! Frozen E General Discussion and Debate 21 10-23-2003 08:50 PM
Tags
6gb, adobe, ai, ap1, available, complete, cs3, export, exporting, illustrator, insufficient, jpeg, memory, operation, save
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
