Turbonetics Custom Turbos, BOV's and Wastegate Specials!!!
Turbonetics Custom Turbos, BOV's and Wastegate Specials with Price Matching!
If you find a better prices advertised we will match it on all Turbonetics related parts and AEM Electronics!
You asked for it, and here it is: a Bisimoto custom Turbonetics t3/t4 turbo, with aluminum 60 trim compressor, with an F1-57 wheel on a T3 flange, 0.63 a/r. This combo offers fast boost response and low inertia of a T3, with the high flow characteristics of a t4 turbo compressor!
Perfect for excellent drivability while delivering excellent power in a journal bearing configuration.
Available in 4 or 5 bolt configurations. Takes one week to customize
$669 Best Seller!
This is the new monster in town! Used on the Bisimoto 533hp+ CR-Z. This unit has a forged billet compressor wheel, that out flows a 67mm cast inducer. The billet compressor wheel offers quicker spool than its cast counterparts, and features a 60 series housing for tight engine bays and excellent turbo response.
713C Inconel turbine wheel at 65mm, for maximum strength and durability. 0.68 a/r on the turbine. Comes with a 1 year, no frills warranty.
Ceramic Ball Bearing $1141
Journal Bearing $799
BTX6462X Billet Turbo, with T3 housing, ball bearing $1,349
BTX6462XJ Billet Turbo, with T3 housing, journal bearing $789
BTX6462XJ Billet Turbo, with T4 housing, journal bearing $799
The BTX6565, was designed to maximize efficiency at high boost pressures, and features a ported compressor housing to limit the unpleasant effects of surge. The unique porting, reminiscent of Turbonetics GT-K series, provides additional flow to make maximum horsepower across the entire RPM band, with hp rages of 550-700+whp.
The BTX6565 is equipped with the latest HP compressor wheels, a state of the art turbo with a 65.5mm inducer wheel, and a 91mm exducer. A unique F1 series turbine housing comes into effect: a T4 twin scroll (tangential divided) housing, coupled with Turbonetics patented ceramic ball bearing technology will ensure quick and efficient spooling properties for the turbo system.
This BTX6565 also features a 3'' v-band outlet to expel gases post use, a polished compressor housing, and ceramic coated twin scroll exhaust housing in 058, 0.70, 0.84, 1.00, 1.15, 1.32, and 1.52 a/r's.
Single scroll turbones also available upon request. Takes 7-10 days to manufacture. 1 year, no hassle warrantee, in water/oil cooled, or oil cooled only options.
Ceramic Ball Bearing: $1,495
Journal Bearing: $1,295
This exclusive blow-off valve features a dual cross tunnel discharge system with various discharge designs. You can use one or two horns to vent the pressurized air directly to atmosphere for that extra loud discharge. Without the horn, you can recirculate for tuning purposes and quieter operation.
Dual Discharge for Max Flow and Flexible Install
Pressure Chamber Design Prevents Leaks
Pull-Type Valve for Low & High Boost Applications
Unique Loud Discharge Sound
Vent to Atmosphere or Recirculate
High Quality Aluminum
Comes with all flanges and hardware necessary for installation
$169 Free Shipping!
The new "Raptor" mid-sized bypass valve offers physical size and airflow characteristics that fill the performance gap between the "Street and Strip" and "Godzilla" valves. Kit includes mounting hardware, flange and fittings.
The unit is:
Fully polished
1.5"(38mm) valve
Compact design
Adjustable preload
Sealed valve stem
1.5" (38mm) discharge
'O'-Ring-sealed valve seat
Rolling diaphram design
Both hose or horn configuration included
$319 Free Shipping!
A Bisimoto best seller, and used on Bisimoto's 700hp wagon build. A totally unique design! The "Godzilla" bypass valve assembly offers the ultimate in surge protection and cosmetic appeal. Highest flow capacity available - bar none! Aircraft-quality construction featuring a 1.8" (45mm) diameter all stainless steel valve assembly and a totally sealed actuator assembly. All polished aluminum with a unique V-band mount that allows a full 360-degree orientation. Includes 2" diameter discharge for system connection and weldable steel alloy and aluminum mounting.
$297 Free shipping!
The Evolution features an investment cast 304 stainless body designed with computer flow analysis. "Nitronic 60" stainless steel one-piece valve, and polished aluminum billet cap. This is a 36mm wastegate that is capable of controlling turbochargers up to 500 HP
$229 Free shipping!
Completely designed from the ground up, Turbonetics engineers threw out the rule book when creating this new middle-weight wastegate. Capable of comfortably handling 700+ HP and only measuring slightly more than the super slim Evolution Wastegate, the RG-45 features V-Band connections in and out, 45mm valve diameter and cast stainless steel base for strength and durability.
Built with the latest technology such as an inconel valve to withstand high exhaust gas temperatures, high temp fluro-silicone diaphragm for predictable and repeatable boost control, and V-Band connections all in a very small frame size. Like its name suggests the gate has a 1.77''/45mm valve and is good for powerplants making 700+ HP.
The RG-45 is also able to be bolted on to the Tial 44mm gate V-Band flanges with the (21912 optional adaptor flange) to make this a direct replacement with no modifications necessary.
45mm Valve - Able to control 700+ HP
DFT - Directed Flow Technology uses active design to move exhaust gases out of the main body chamber
Investment Cast Stainless Steel - Corrosion resistance & strength
V-Band flanges - Inlet and discharge are made for easy installation and adjustments
Multiple Boost Ports - For clean and simple installation
11 psi spring installed - Comes with 5, 8, as well as 15 psi springs
Turbonetics stand-off base design - Provides cooling for the valve and diaphragm insulation
$390 Free Shipping!
Re: Turbonetics Custom Turbos, BOV's and Wastegate Specials!!!
HAPPY MONDAY! FREE SHIPPING ON ANY BISIMOTO ORDERS OVER $150 TO ANYWHERE IN THE CONTINENTAL USA
THIS WEEK MONDAY-FRIDAY OCT.17-21!!!
VALID ON BISIMOTO.COM
ONLINE ORDERS USE COUPON CODE: FS2011
(For out of country discounted prices please email sales@bisimoto.com)
Good morning to all our Bisimoto Fans!!! This week we are offering FREE SHIPPING ON ANY ORDER OVER $150 on the Bisimoto store to anywhere in the Continental USA!! Use coupon code: FS2011
THAT INCLUDES:
- BISIMOTO CAMSHAFTS
- BISIMOTO VALVE TRAIN
- BISIMOTO CAM GEARS
- BISIMOTO RODS AND PISTONS
- BISIMOTO V2 HEADERS
- H/F2B and H/2D KITS
- ACTION CLUTCH KITS
- AEM ELECTRONICS
- KINSLER ITBS AND SO MUCH MORE!!!
Starting today until Saturday 10/22/2011!
(Out of country customers can email sales@bisimoto.com for discounted shipping!)
Two More Days Left....Take advantage of this special!
We are offering FREE SHIPPING ON ANY ORDER OVER $150 on the Bisimoto store to anywhere in the Continental USA!! Use coupon code: FS2011
Until Saturday 10/22/2011!
Two More Days Left....Take advantage of this special! Ends Saturday 10/21/11!
We are offering FREE SHIPPING ON ANY ORDER OVER $150 on the Bisimoto.com to anywhere in the Continental USA!! Use coupon code: FS2011
Special still valid.
Please Call Bisimoto at (888) 922-6686 mon-fri 9-6pm pacific to place order.
