TURBO COOLANT LINE KITS W/BLACK FITTINGS!!!!! - Honda-Tech
Closed Thread
Old 06-14-2007, 08:15 PM   #1
Default TURBO COOLANT LINE KITS!!!!!!
We just got these in. Their 28mm to -6 machined 6061 aluminum fittings used for the turbo feed line going to the turbo. PM me if you have any questions.
$30 Shipped
Front Block Port Coolant Kit
$115 Shipped in USA
Comes with:
28mm to -6 front block port
Two 14mm to -6 fittings for GT series turbos
Two -6 90 degree fittings
Two -6 45 degree fittings
5 ft of -6 steel braided hose
1 -6 aluminum weld bung for the radiator
For black fittings and pro lite 350 hose (black hose) its $135 shipped.
Inline Kit
$99 SHIPPED
Comes with everything pictured plus 7 ft. of AN 6 steel braided hose. Push lock ends attach to stock lines and run back to turbo. Also comes with a hose separator to keep your lines looking good. No ghetto zip ties here.
RADIATOR KIT
$120 SHIPPED
Comes with 7 ft. of AN 6 steel braided hose. Just weld the AN 6 bung to the bottom of your aluminum radiator and connect the line to the turbo. Use the AN 6 Tee to tap for your other source.
T KIT
$139 SHIPPED
Comes with 7 ft. of AN 6 steel braided hose. Just use the 2 AN 6 T's to tap into your stock lines for the feed and return. Also comes with a hose separator to keep you lines looking good. No ghetto zip ties here.
Please send payment using paypal (add 3%): bandrfittings@gmail.com
Credit cards will be accepted soon.
Orders in CA add 7.75% sales tax.
Modified by B R Fittings at 8:37 PM 6/14/2007
Modified by B R Fittings at 8:41 PM 6/14/2007
Modified by B R Fittings at 11:00 PM 8/23/2007
Modified by B R Fittings at 11:55 PM 8/23/2007
Modified by B R Fittings at 5:36 PM 7/20/2008
B R Fittings is offline
Old 06-14-2007, 08:22 PM   #2
89efDUSTY's Avatar
Default Re: TURBO COOLANT LINE KITS!!!!!! (B R Fittings)
damn let me be the first to say very nice product.
89efDUSTY is offline
Old 06-14-2007, 08:27 PM   #3
Default Re: TURBO COOLANT LINE KITS!!!!!! (89efDUSTY)
Thank you very much.
Old 06-17-2007, 11:37 AM   #4
0TT
0TT's Avatar
have you got some pictures of the inline kit installed onto a b-series engine?
0TT is offline
Old 06-17-2007, 05:01 PM   #5
Default Re: TURBO COOLANT LINE KITS!!!!!! (0TT)
I don't have any pics of it installed, but I can send you pictures of where to tap the lines into. I have a b series engine sitting in my garage.
Old 06-19-2007, 08:35 AM   #6
bump
Old 06-21-2007, 05:01 PM   #7
bump
Old 06-23-2007, 08:22 AM   #8
up top
Old 06-26-2007, 07:05 AM   #9
bump
Old 06-27-2007, 05:47 PM   #10
Pm's replied
Old 06-29-2007, 08:20 AM   #11
bump
Old 06-30-2007, 09:24 PM   #12
bump
Old 07-02-2007, 07:34 AM   #13
bump
Old 07-02-2007, 02:21 PM   #14
96ex's Avatar
bump check pm
96ex is offline
Old 07-02-2007, 07:41 PM   #15
Default Re: TURBO COOLANT LINE KITS!!!!!! (96ex)
Replied, will have tracking # tomorrow, shipped 2nd day air.
Old 07-03-2007, 07:16 AM   #16
up top
Old 07-05-2007, 07:46 AM   #17
bump
Old 07-06-2007, 07:28 AM   #18
up top
Old 07-07-2007, 04:31 PM   #19
up top
Old 07-09-2007, 06:56 AM   #20
bump
Old 07-10-2007, 07:14 AM   #21
up top
Old 07-11-2007, 07:35 AM   #22
bump
Old 07-12-2007, 05:21 PM   #23
bump
Old 07-14-2007, 05:30 AM   #24
bump
Old 07-15-2007, 12:12 PM   #25
bump
Closed Thread
CLUTCH LINE KITS B R Fittings Performance 280 07-03-2013 06:41 PM
FUEL FILTER TO FUEL RAIL KIT, AN FITTINGS/AVIALABLE W/BLACK HOSE B R Fittings Forced Induction 254 11-16-2011 12:07 AM
Bosch 044 Pump Kits, Fuel Filters..... B R Fittings Forced Induction 75 06-07-2011 03:53 PM
Cross-threaded block port fitting (water line install) dpetro1 Forced Induction 22 08-20-2010 06:14 AM
B & R BLOCK PLUG NOW AVAILABLE IN ANODIZED BLACK B R Fittings Forced Induction 267 11-20-2008 08:32 AM
Tags
4an, black, br, braided, coolant, fittings, honda, kit, line, lines, mx6, required, return, steel, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
