SYNAPSE BLOW OFF VALVES AND WASTEGATES IN STOCK! WINNER OF SEMA AWARDS!
Ok Guys, let me introduce you (if you haven't already seen this) to the best BOV and Wastegate on the market today. They are the winner of a SEMA 2007 award for Best New Product in Performance and Racing!
Info on BOV from Synapse:
Synapse Synchronic BOV is a fast-acting design that functions as a blow-off, diverter (DV)/bypass and even a pop-off valve. The patented (6,863,260) design eliminates the diaphragm with a multi-tier piston actuator that self-centers under pressure. This design is intended to significantly reduce or eliminate compressor surge and will not leak boost.
Item includes:
Synpase Synchronic Blow-Off Valve
Stainless Steel Mounting Flange
Other Necessary Hardware
Synapse also offers adaptor flanges for many vehicles and for other BOV flanges. What this means is, if they are available for your vehicle, you can purchase the adaptor flange and bolt it directly to the flange you already have welded to your piping! If not, weld the provided flange on and you are set.
Click Here for more information and/or to purchase this item!
__________________________________________________ _____________________
Synapse Synchronic Wastegates
Synapse offers a 40mm Wastegate and a 50mm V-Band Wastegate. They are also available with and without hardware.
40mm Wastegate
[url="http://www.iapdirect.com/product.php?productid=42026"][img] http://imagehost.vendio.com/a/126376.../img][/url]
Info from Synapse:
Synchronic Wastegate is a fundamentally new design that incorporates our patented actuator technology to give you more tunability than you thought was possible with a wastegate.
WG001 is our smallest frame universal wastegate with a 40mm valve and two bolt mounting flange that is a bolt on replacement to many wastegates on the market today. With each retail kit, you get 4-25 psi boost in a box.
No Diaphragm!
Adjustable Valve Pre-Load
6 Built-In Boost Settings
Integrated Flow Control
Advanced Engineered Materials
Integrated Exhaust Manifold Seal
50mm Wastegate
WG002 is our large frame universal wastegate with a 50mm valve and v-band mounting flange that is a bolt on replacement to the popular 44mm wastegates on the market today. With each retail kit, you get 4-25 psi in a box.
No Diaphragm!
Modified by ImportAutoPerformance.com at 3:10 PM 5/28/2008
Item includes:
40mm Wastegate
Info from Synapse:
No Diaphragm!
50mm Wastegate
No Diaphragm!
Re: (legomytego)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by legomytego »</TD></TR><TR><TD CLASS="quote">bump for a good product i have one of there bov on my teg </TD></TR></TABLE>
Thanks. These are definitely the best WG and BOV on the market today!
