Zex 105300 cam & AEM cam gear for a stock D16Y8?
Old 03-07-2006, 01:48 PM
boostincoupe's Avatar
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Zex 105300 cam & AEM cam gear for a stock D16Y8?
I'm going to be pushing my bone-stock D16Y8 (sans ARP headstuds) to its limits for an event in June, and I'm trying to find some good ways to put the most "power" down. "Power" = 230-240whp, hence the quotations
So far, here's my current traction solutions:
- ES motor mount inserts
- 205/50/15 BFG drag radials
- OBX LSD & rebuilt Y8 tranny
With regards to the motor, would a Zex cam and AEM cam gear be of any benefit to my setup? I'm going to be running a Precision SC50, ramhorn manifold, 3" open downpipe, Tial 35mm WG w/open dumptube, Uberdata-chipped P28, DSM 450's, etc. etc...
What's the highest you can rev a stock Y8 head with a Zex cam and AEM cam gear?
Old 03-07-2006, 02:04 PM
gnar kill's Avatar
Default Re: Zex 105300 cam & AEM cam gear for a stock D16Y8? (boostincoupe)
I have a zex 59300 in my stock z6 with arp head studs and I got zex valvesprings also....I rev to about 7200 which is stock readline but I am pretty sure it would be ok up to 8000...my motor only has about 100 miles on it though so I don't get on it very much since it isn't broke in yet...I also am not yet turboed but will be
Old 03-08-2006, 10:06 AM
Default Re: Zex 105300 cam & AEM cam gear for a stock D16Y8? (gnar kill)
bump!
Old 03-08-2006, 10:08 AM
SL0WEGG's Avatar
i say about 7200 due to the stock springs/retainers
Old 03-08-2006, 10:13 AM
BOOSTIN1's Avatar
there is a few d-series guys on here that rev to 7500 with that setup,but i would push it pass that.
Old 03-08-2006, 10:16 AM
BOOSTIN1's Avatar
Default Re: Zex 105300 cam & AEM cam gear for a stock D16Y8? (BOOSTIN1)
i mean i would not push it pass that,sorry for the typo!<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOOSTIN1 &raquo;</TD></TR><TR><TD CLASS="quote">there is a few d-series guys on here that rev to 7500 with that setup,but i would push it pass that.</TD></TR></TABLE>
Old 03-08-2006, 10:28 AM
King-Kong's Avatar
I had the same setup, but stock engine, no headstuds, stock cam etc, I used a sc50 60/63 and on 13psi i hit 264whp at 7200ish and was still making power up to 7800 and i shifted at 8000 all year, even missed gears, you shouldnt be too worried, i used 444 cc injectors and they were maxed out but i was using a conservative tune which was a bit rich, 255lph walbro and stock regulator, AEM cam gear but never adjusted it.
Old 03-08-2006, 10:38 AM
ELSpool's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOOSTIN1 &raquo;</TD></TR><TR><TD CLASS="quote">there is a few d-series guys on here that rev to 7500 with that setup,but i wouldn't push it pass that.</TD></TR></TABLE>
I was one of them, did it for over a year of very hard driving. No worries!
Old 03-08-2006, 10:41 AM
Default Re: Zex 105300 cam & AEM cam gear for a stock D16Y8? (ELSpool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ELSpool &raquo;</TD></TR><TR><TD CLASS="quote">
I was one of them, did it for over a year of very hard driving. No worries!</TD></TR></TABLE>
With the 105300 cam and an AEM cam gear?
Old 03-13-2006, 06:00 PM
Stop the Beast's Avatar
I'm personally getting the same cam but don't plan on using a cam gear. The Full Race Pink's Civic used the 59300 (z6 version of the 105300) and it gained about 40whp across the board over the stock cam with no mechanical timing adjustments. I just bought one today.
Old 03-13-2006, 08:39 PM
bluemax189's Avatar
Default Re: Zex 105300 cam & AEM cam gear for a stock D16Y8? (Stop the Beast)
thinking of the same cam for my car. so it will work fine with stock redline and stock valvetrain and turbo?
Old 03-14-2006, 03:28 AM
EF9ZC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stop the Beast &raquo;</TD></TR><TR><TD CLASS="quote">I'm personally getting the same cam but don't plan on using a cam gear. The Full Race Pink's Civic used the 59300 (z6 version of the 105300) and it gained about 40whp across the board over the stock cam with no mechanical timing adjustments. I just bought one today.</TD></TR></TABLE>
How high did full-race rev too?
Old 03-14-2006, 08:41 AM
EF9ZC's Avatar
Where did you read that full-race used the zex cam gear on ebay the guy selling their hatch said it was a stock y8 one
Old 03-14-2006, 10:43 AM
Default Re: (EF9ZC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9ZC &raquo;</TD></TR><TR><TD CLASS="quote">Where did you read that full-race used the zex cam gear on ebay the guy selling their hatch said it was a stock y8 one</TD></TR></TABLE>
Call them and ask, they used a 59300 (I worked with them on it). You shoudn't use that cam with stock valve springs.The Pinks car was revved to 9,000RPM's. The power was falling off after 7500 but the high revs were needed to land in boost for the next gear.
Old 03-14-2006, 11:10 AM
igo4bmx's Avatar
the zex cams are designed pretty well, and made my aem cam gear purchase a waste. I lost alot of power whenever i adjusted the cam gear to anything other than stock, and i believe others reported the same thing
Old 03-14-2006, 11:12 AM
Default Re: (igo4bmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx &raquo;</TD></TR><TR><TD CLASS="quote">the zex cams are designed pretty well, and made my aem cam gear purchase a waste. I lost alot of power whenever i adjusted the cam gear to anything other than stock, and i believe others reported the same thing</TD></TR></TABLE>
Are you running the 105100 or the 105300 with upgraded valvetrain?
Old 03-14-2006, 11:30 AM
igo4bmx's Avatar
Default Re: (boostincoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe &raquo;</TD></TR><TR><TD CLASS="quote">Are you running the 105100 or the 105300 with upgraded valvetrain?</TD></TR></TABLE>
running the 105300 with crower valvesprings and retainers.
stock valves
Old 03-14-2006, 11:45 AM
perlmeister8's Avatar
/\ Interesting....I am also running the 105300, good info to have
Old 03-14-2006, 11:56 AM
EF9ZC's Avatar
If i'm going to be reving to 9000 would you recomend this cam or do you think power will fall off?
Old 03-14-2006, 12:01 PM
Default Re: (EF9ZC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9ZC &raquo;</TD></TR><TR><TD CLASS="quote">If i'm going to be reving to 9000 would you recomend this cam or do you think power will fall off?</TD></TR></TABLE>
The 105300 documentation states that it makes power from 2000-7200rpm.
Old 03-14-2006, 12:06 PM
EF9ZC's Avatar
Guess i'll look into crowers turbo cam...
Old 03-14-2006, 12:44 PM
igo4bmx's Avatar
Default Re: (EF9ZC)
power will fall no matter what cam you use.
the main bottleneck after a good cam becomes the head and intake manifold.
here is a good comparison:
My car d series, mildy ported and polished
Here is another d series, a well ported and polished head
now both cams are stage 2 zex (mine 105300, his 59300) which are the same except the 105300 is made for the y8 and the 59300 is for the z6 motors
Old 03-14-2006, 12:58 PM
ELSpool's Avatar
My dyno with stock Y8 cam and mild port job by myself made peak power at 7800rpm...
Old 03-14-2006, 01:28 PM
EF9ZC's Avatar
crower doesn't say when their cams powers at atleast i dont remember reading it. I dont know i would like to rev to atleast 9 possibly 95 i just wana make sure that i have a cam to support the higher revs i would hate to fall short because of something that could possibly be prevented
Old 03-14-2006, 02:12 PM
Default Re: (EF9ZC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9ZC &raquo;</TD></TR><TR><TD CLASS="quote">crower doesn't say when their cams powers at atleast i dont remember reading it. I dont know i would like to rev to atleast 9 possibly 95 i just wana make sure that i have a cam to support the higher revs i would hate to fall short because of something that could possibly be prevented</TD></TR></TABLE>
Even with major, major, port work the SOHC will be hard pressed to make power to 9000+RPM's. Plan on making usable power to ~7500, the rest of the gear will be simply to keep the revs high into the next shift-as I said before.
Quick Reply: Zex 105300 cam & AEM cam gear for a stock D16Y8?
