witch intake manifold should i use
Old 05-17-2010, 08:32 AM
b18 hatch mike's Avatar
Default witch intake manifold should i use
bulit ls block b16 head with a little work done to it and dont know witch im i should use any ideas
Old 05-17-2010, 09:26 AM
dpetro1's Avatar
Default Re: witch intake manifold should i use
whats the rest of the setup? power goal? are you going for peak hp or more of a mid-range powerband? what is your budget?
kinda hard to answer without more details.
Old 05-19-2010, 10:49 AM
well i got a sc61 turbo peakboost ramhorn 38 mm wastegate 81.5 ls block eagle rods cp pistons 3 inch turbo back exhaust b16 head with supertech valve springs and retainers and want to make like 400hp
Old 05-19-2010, 01:24 PM
narfdanarf's Avatar
turbo sounds way too big for a 400hp goal...with that being said you can make 400 on that turbo with ease on a stock b16 intake manifold.
Old 05-19-2010, 04:57 PM
ok that`s not what i asked i know this i am asking with manifold is the best to make power with that flows best i was thinking a cheap blox or a victor x unless someone else has a different one in mind
Old 05-19-2010, 05:03 PM
not even a 100% sure the turbo is a sc61 thats what i was told when i bought it it has a 60 cold side and 63 hot side
Old 05-19-2010, 05:32 PM
narfdanarf's Avatar
you ask a vague *** question...you want the best that is overkill for your setup or do you want a cheap *** blox, if you want something cheap a b16 manifold will support your goals, if you want to buy a manifold just because get a victorX, if you want something awesome, you can look into the kinsler or wilson manifolds.
Old 05-19-2010, 06:04 PM
well i dont have one at all now so i just want what is best for my setup i dont know what is overkill thats why i ask and those mesurements i gave dose that sound like a sc61
Old 05-19-2010, 06:24 PM
Turbo-LS's Avatar
just run a blox for 400whp its a good all around manifold gives great driveability and power. the victor is ment for high reving big turbo and power applications
Old 05-20-2010, 05:47 AM
dpetro1's Avatar
it sounds like you are describing the a/r not the actual wheel trims. the a/r does not have anything to do with the size of the turbo. are there any other marking or number on the turbo? is it made by precision? you may need to remove the housings and mesasure the wheels to get a definite answer
here's a good link that explains trim, a/r, etc
http://www.turbobygarrett.com/turbob...o_tech102.html
Old 05-20-2010, 06:56 AM
yes it is made by percision but it dosent seem like its that big of a turbo i an running it on my built bottom end ls at 330 hp it spools up fine
and i should just go with a blox?
Old 05-20-2010, 07:01 AM
dpetro1's Avatar
blox will work fine for your setup. again its hard to say becuase there isnt really one thats "better" than others. oem, blox, skunk2, edelbrock...they will all meet your goals.
Old 05-20-2010, 07:09 AM
i think i will just go with the edelbrock b/c it has the vacuum line ports on the back side and a cleaner look imo
Old 05-20-2010, 12:07 PM
Turbo-LS's Avatar
its really is overkill for that setup but it will technically "work"
Old 05-20-2010, 12:44 PM
fasthatch95's Avatar
I use victor x there ported clean and yes clean vacuum ports and all even a 70mm bore! Ive had every intake you can imagine and thats been my favorite so far!
Old 05-20-2010, 03:22 PM
jdm inc's Avatar
I Would go with a victor X! Mayb youll want more power later then you wont have to change the manifold imo.
Old 05-20-2010, 04:53 PM
attack666's Avatar
If you want to spend your money.. spend it right !
save up and buy a Victor X
Old 05-20-2010, 05:21 PM
i do plan on more power for sure and i have found some good deals like 250 used anyone know of a better deal
kennybintegra
08-22-2009 10:36 AM
JDM00SI
06-20-2005 10:02 PM
spoon23_JDizM AkA SpOoN20
10-26-2003 09:10 PM
Quick Reply: witch intake manifold should i use
