why would a wastegate just stop working and not opening up???
Quick question for you guys? I have noticed that my wastegate is no opening up for some odd reason and I was messing with the boost controller and thats not it.
timing and vaccum hoses are prefect. So why would a wastegate just stop working?
SOHC TURBO
on 10 psi
tial 38mm wastegate spring at 7psi
SOHC TURBO
on 10 psi
Re: why would a wastegate just stop working and not opening up??? (Markb16a)
you send it to me and i tell you why
race gas on a pump valve?
taking boost reference off the manifold?
Re: why would a wastegate just stop working and not opening up??? (TiAL)
if its a diaphragm wastegate, that can tear and render the wastegate inoperable.
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TiAL »</TD></TR><TR><TD CLASS="quote">you send it to me and i tell you why
Sounds a bit more like THIS reason here. But details from The OP are needed..
Re: why would a wastegate just stop working and not opening up??? (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan »</TD></TR><TR><TD CLASS="quote">
Sounds a bit more like THIS reason here. But details from The OP are needed..</TD></TR></TABLE>
If he's using race gas for 10psi of boost, he's got a turbo bigger than my spare tire
I'd recommend you take your WG off and disassemble (unless you aren't 'handy'). It could be corroded or in need of service.
