where to get ngk 1 or 2 step colder spark plugs?
Old 11-09-2004, 06:58 AM
  #26
BoostedsiR's Avatar
Default Re: where to get ngk 1 or 2 step colder spark plugs? (ladysman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman &raquo;</TD></TR><TR><TD CLASS="quote">bkr7e's
I think 1283 is the part #</TD></TR></TABLE>
are you sure because I need thoose plugs
Old 11-09-2004, 09:27 AM
  #27
In-N-Out Burger
NightRiderS2K's Avatar
Default Re: where to get ngk 1 or 2 step colder spark plugs? (BoostedsiR)
NGK BKR7E-11
Stock no: 1283
I am holding the box in my hand as I just finished typing this
Old 11-09-2004, 09:43 AM
  #28
jmal1919's Avatar
Default Re: where to get ngk 1 or 2 step colder spark plugs? (civicguy)
I just put in some NGK 4091's last night (.30 gapped). My car seems to like me for it too. It's against the norm here, but that can be a good thing at times.
NGK V-power spark plug 4091 R5671A-7
Old 11-09-2004, 11:32 AM
  #29
sporkcrx's Avatar
Default Re: where to get ngk 1 or 2 step colder spark plugs? (jmal1919)
I'd just leave them at the stock gap unless the spark is getting blown out. I've always run 1 step colder on my past turbo set ups, but my next one will just use stock ones. Stock gap, stock heat.
Old 11-10-2004, 04:13 PM
  #30
oxSLEEPERxo's Avatar
Default Re: where to get ngk 1 or 2 step colder spark plugs? (boosted hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote">Just to add to ladysman post:
6's: 300-350whp level
7's: 350whp-450whp level
8's: 450whp-600whp level
I pretty much use the 7's in everything i tune and run, which is overkill. You'll get better gas mileage and partial throttle response with a hotter plug since it combusts the mixture greater.</TD></TR></TABLE>
I thought for every 75-100 whp you make, you should go 1 step colder? So if someone is planning to have 200whp on a d16z6, shouldn't they go with 7's and not 6's? And for someone that is planning to have 300whp, shouldn't they go with 8's? correct me if i am wrong
Old 02-04-2005, 04:39 PM
  #31
cpforyou's Avatar
Default Re: where to get ngk 1 or 2 step colder spark plugs? (oxSLEEPERxo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oxSLEEPERxo &raquo;</TD></TR><TR><TD CLASS="quote">
I thought for every 75-100 whp you make, you should go 1 step colder? So if someone is planning to have 200whp on a d16z6, shouldn't they go with 7's and not 6's? And for someone that is planning to have 300whp, shouldn't they go with 8's? correct me if i am wrong</TD></TR></TABLE>
NGK BKR7E-11 Spark Plugs should work okay too with good tuning. You can always change the gap a little to compensate.
NGK don't make a BKR8E-11 or anything like that. You'd have to go with one of their more expensive race plugs or something.
Old 02-04-2005, 07:21 PM
  #32
FSM Dan's Avatar
Default Re: where to get ngk 1 or 2 step colder spark plugs? (cpforyou)
We keep them in stock. Stop down the shop and see us!
Dan
Old 02-11-2005, 03:55 PM
  #33
cpforyou's Avatar
Default Re: where to get ngk 1 or 2 step colder spark plugs? (FSM Dan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FSM Dan &raquo;</TD></TR><TR><TD CLASS="quote">We keep them in stock. Stop down the shop and see us!
Dan</TD></TR></TABLE>
Kep what in stock? BKR8E-11?
Old 02-11-2005, 05:42 PM
  #34
raceACCORDingly's Avatar
Default Re: where to get ngk 1 or 2 step colder spark plugs? (NightRider-gsR)
1283 are pregapped at .044
6097 are not gapped. i normally get these and gap them at .038 and they work great.
092eg6
11-06-2009 08:59 PM
trianglegreg
11-04-2005 03:10 PM
romoracing
03-15-2005 10:19 PM
Poey2
03-06-2004 04:45 PM
Quick Reply: where to get ngk 1 or 2 step colder spark plugs?
