where to get ngk 1 or 2 step colder spark plugs?
Old 04-20-2003, 03:35 PM
civicguy's Avatar
Default where to get ngk 1 or 2 step colder spark plugs?
im almost finish with my turbo and would like to get some information or recomendation about what type of spark plugs to get and where to get them
Old 04-20-2003, 04:08 PM
B18EG6's Avatar
Default Re: where to get ngk 1 or 2 step colder spark plugs? (civicguy)
summitracing.com
ngk-6097
Old 04-20-2003, 04:47 PM
98civicEX's Avatar
http://www.sprakplugs.com , i belive discount auto now sells NGK as well.
Old 04-20-2003, 06:45 PM
turbod16y8's Avatar
Default Re: where to get ngk 1 or 2 step colder spark plugs? (98civicEX)
auto zone has them...... or advance auto parts
Old 04-20-2003, 09:27 PM
twkdCD595's Avatar
Default Re: where to get ngk 1 or 2 step colder spark plugs? (turbod16y8)
local auto parts stores usually have a couple different heat ranges in stock... however they only list what the recommended factory heat range is of the vehicle you tell them... so they will not know what your talking about as most workers are ignorant of such facts.
most the time you can just ask them to look up the ngk part # for the plug to see if they stock them... without having some turd tell you "thats not what the computer says".
Old 09-17-2003, 12:10 PM
Nextelbuddy's Avatar
Default Re: where to get ngk 1 or 2 step colder spark plugs? (twkdCD595)
does any one know the part number of the ngk spark plug that is one step colder than the stock honda plugs? also do they come pre gapped?
Old 09-17-2003, 12:11 PM
Mr. Softee's Avatar
Default Re: where to get ngk 1 or 2 step colder spark plugs? (nextelbuddy)
bkr7e's are the ones most poeple use. i use something similar tot hat from ngk r and have used those ones before with no problems
sam
Old 09-17-2003, 12:14 PM
Default Re: where to get ngk 1 or 2 step colder spark plugs? (94goldjungsr)
do they come pre gapped? also can i just take that part number to say auto zone or do they not stock them?
Old 09-17-2003, 12:15 PM
Mr. Softee's Avatar
they dont have them at autozone near me. and yes they are pregapped but you should check them anyway to make sure they didnt get ungapped in shipping
sam
Old 09-17-2003, 12:28 PM
New User
LshatchTurbo's Avatar
My car loves the NGK 3330 plugs. This is the BCPR7ES, 2 step colder, .032 pregapped plug. I get them from advanced/discount auto parts all the time. Just tell them u need the NGK 3330. Sometimes they have them, sometimes they dont, just depends on your store. But these plugs work fantastic for me, and I sure you would have great results as well, and best of all there very cheap.
Old 09-17-2003, 12:33 PM
Default Re: where to get ngk 1 or 2 step colder spark plugs? (lshatchturbo)
will i notice any power loss through spark on 5 psi.
Old 09-17-2003, 12:34 PM
Mr. Softee's Avatar
i was using some generic spark plugs with only 3k miles on them and my car would not even go through the RPMs in boost.
Old 09-17-2003, 12:40 PM
paulzy's Avatar
those are the ones I ran when I was on the bottle. you can get the 3330 or the 2023(which are the bkre7's)
Old 09-17-2003, 12:42 PM
Default Re: where to get ngk 1 or 2 step colder spark plugs? (Paul_Vang)
so if i get the NGK 3330 plugs they are 1 step colder? and they will be fine on my motor with only 5 psi?
Old 09-17-2003, 12:47 PM
Mr. Softee's Avatar
they're fine man.
Old 09-17-2003, 01:14 PM
thanx for all your help but i really wanted to know if the ngk 3330 were 1 step colder or 2? i dont want 2 step i only want one.
Old 09-17-2003, 01:15 PM
Mr. Softee's Avatar
if you want an immediate answer, i believe they are 2 step but i am not sure on that. call up sparkplugs.com they will definitely answer you with a solid response.
sam
Old 09-27-2003, 11:04 AM
well i went to napa and they pulled up the ngk BKR6E-11 for the stock replacment plug for 1.8 DOHC vtec motor. so i asked for 1 step colder and he gave me BKR5E-11. i told him i was looking for BKR7E-11 and he said that was 1 step hotter. i see so many mixed responses on here. so whats the deal are the BKR5E-11 hotter or colder?
Old 09-27-2003, 12:06 PM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nextelbuddy &raquo;</TD></TR><TR><TD CLASS="quote">well i went to napa and they pulled up the ngk BKR6E-11 for the stock replacment plug for 1.8 DOHC vtec motor. so i asked for 1 step colder and he gave me BKR5E-11. i told him i was looking for BKR7E-11 and he said that was 1 step hotter. i see so many mixed responses on here. so whats the deal are the BKR5E-11 hotter or colder?</TD></TR></TABLE>
Larger the number = colder the plug.
Directly from NGK's site.
7's are what you want.
Old 09-27-2003, 12:46 PM
boosted hybrid's Avatar
Default Re: where to get ngk 1 or 2 step colder spark plugs? (ladysman)
Just to add to ladysman post:
6's: 300-350whp level
7's: 350whp-450whp level
8's: 450whp-600whp level
I pretty much use the 7's in everything i tune and run, which is overkill. You'll get better gas mileage and partial throttle response with a hotter plug since it combusts the mixture greater.
Old 09-27-2003, 12:50 PM
Sinner's Avatar
I think domestic sparkplugs are the opisite of honda plugs... going up is cooler in a honda and going up in a domestic is hotter. I could be wrong but that is what I was told at a autozone... you never know what you get at those places.
Nick
Old 10-10-2003, 09:21 AM
Charlie Moua's Avatar
Default Re: where to get ngk 1 or 2 step colder spark plugs? (Sinner)
now which one is it?
B18c1 for 200-300whp appilcations? NGK part number?
Old 10-10-2003, 09:24 AM
ladysman's Avatar
Default Re: where to get ngk 1 or 2 step colder spark plugs? (Charlie Moua)
bkr7e's
I think 1283 is the part #
Old 10-10-2003, 09:29 AM
PrecisionH23a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lshatchturbo &raquo;</TD></TR><TR><TD CLASS="quote">My car loves the NGK 3330 plugs. This is the BCPR7ES, 2 step colder, .032 pregapped plug. I get them from advanced/discount auto parts all the time. Just tell them u need the NGK 3330. </TD></TR></TABLE>
Agreed. They actually have a shorter insulator tip compared to the bkr7e's that i used to run. The shorter insulator tip the better, the further the tip sits into the combustion chamber the more heat it is exposed to... which can lead to guess what? I learned that from my tuner on my last trip to the dyno.
Old 11-09-2004, 02:03 AM
1SlowSi's Avatar
Default Re: where to get ngk 1 or 2 step colder spark plugs? (PrecisionH23a)
Bringing this one back up. I see the debate between the two spark plugs.
BKR7e and BCP7e's. Is it 7e or 7es... and i saw a post that said to get plugs without the -11 at the end? whats the difference? As far as gapping goes, i see most run a .030 gap. Is there like a certain gap for an X amount of power? im gonna be running around 300whp. what gap for that?
With a lower number like .026 that would be making the gap smaller corret? for more power? im dumb and new at this.
Quick Reply: where to get ngk 1 or 2 step colder spark plugs?
