methanol/nitrous jet calculator?
Old 06-14-2011, 09:11 AM
91integraLSVTEC's Avatar
Default methanol/nitrous jet calculator?
Does anybody know of a website that can help me determine the fuel jet i need to run nitrous? (wet setup, seperate fuel system pump at 100psi) Or if anybody knows the formula to do the conversion? thanks!
Spawne32's Avatar
Default Re: methanol/nitrous jet calculator?
http://revlinemotorsports.com/~raz/t...alculator.html
Old 06-14-2011, 09:14 AM
Spawne32's Avatar
wait methanol or nitrous? you cant use the same calculation for both
Old 06-14-2011, 09:30 AM
Thanks for the link but i think thats a calulator to determine injector size for alcohol.
im running a wet nitrous setup and using methanol as fuel. I was using windshield washer fluid on low shots but now i want to go up to 100 shot and want to be more precise with fuel, this time ill be using a proper mix of 50/50 pure methanol and water. I dont wanna risk blowing my engine so a calculator to help determine fuel jet size, some helpful advise and some r&d would help out alot!! thanks in advance!
Old 06-14-2011, 09:34 AM
Spawne32's Avatar
i just wanna get this straight, your using nitrous and methanol together in the wet kit? along with gas? or methanol is your primary fuel, and your spraying nitrous along with it?
Old 06-14-2011, 09:41 AM
yup. 93octane
Old 06-14-2011, 09:44 AM
Spawne32's Avatar
ok then i really cant calculate that lol methanol has a completely different value from gas, i would just assume since your already running it, keep the percentage of increase on both the same, and just dial down the methanol a bit according to your air/fuel ratio you see on your wideband. The increase in methanol will make you slightly richer by going to 50/50.
lucava05
02-27-2010 03:22 AM
doug118
08-13-2007 08:22 AM
ridewhencan
07-01-2004 06:43 PM
SilverEP3
02-23-2003 08:34 AM
Quick Reply: methanol/nitrous jet calculator?
