Where can i find a t3 housing for a T04B25 - Honda-Tech
Old 02-25-2017, 07:00 PM   #1
RACEPAK's Avatar
Default Where can i find a t3 housing for a T04B25
hello guys
i have a new airesrech T04B25 that i want to use.. it has a T4 1.10 divided housing, and i want to find a t3 up to a .82 or a t4 with a range from .63 to .82, anyone know where can i find one?
thanks alot
RACEPAK is offline   Reply With Quote
Old 02-27-2017, 10:15 AM   #2
Moderator
TheShodan's Avatar
Default Re: Where can i find a t3 housing for a T04B25
Depends upon the size/profile of the exhaust wheel. More than likely, you'll need to find something that fits close to its size profile in a T3 and custom machine to fit. Many of the older AiResearch /Garretts didn't have aftermarket availability for turbine housings unless they were a popular model.
Photos, measurements, etc, will help to determine if this is indeed the case for your particular situation.
TheShodan is offline   Reply With Quote
Old 03-12-2017, 12:03 PM   #3
RACEPAK's Avatar
thanks alot.
i measured and took pictures of most of the specs i think are needed, the turbine has the old style heat shield i think i saw these on old turbonetics turboץ
Old 03-13-2017, 11:56 AM   #4
Moderator
TheShodan's Avatar
Yeah....hmmm. Even "eyeballing" it, that looks like that will need to be machined for the turbine wheel profile, the heat shield height, the flange thickness of the back of the CHRA for the correct depth, etc.
I'll see if I can pull up part of the standard JB Aftermarket specifications for standard wheels like the 68mm, 71mm and 74mm and 77mm. That looks like it to be an older wheel just under the much older turbine wheel sized between an older Turbonetics "O-Trim" (2.2292exducer / 2.8" Inducer) and a custom config.
Eeek. Where'd you get this T04B25 from? That looks like an OEM application. what did it come off of?
Old 03-15-2017, 05:04 PM   #5
RACEPAK's Avatar
thanks for the reply, i got it new several years ago on ebay, its for a NAVISTAR / INTERNATIONAL 7.6 liter
yeah. i dont know why it reminded me a turbonetics for some reason
tnx
Old 03-15-2017, 06:32 PM   #6
Moderator
TheShodan's Avatar
Because Turbonetics & Garrett used to work Hand in Hand about 20 years ago. They haven't since about 1999.
Went through all of the specifications / profiles. No dice, my friend. You have to get something that was originally from something that used a 70mm profile. (Like an older "Stage 5" profile) and custom machine to fit. With that heat shield, it'll be a rough ride to find.
But I wish you luck.. I'm sorry I couldn't be of more help.
Old 03-16-2017, 02:13 PM   #7
RACEPAK's Avatar
THANKS ALOT, guess it goes back on ebay
Old 03-17-2017, 06:39 AM   #8
Moderator
TheShodan's Avatar
Quote:
I'm so sorry you wasted your time. But, eBay tends to do that with turbochargers.
T3 6262-SP .63 vs .82 housing.. Dyno Comparison gringotegra Forced Induction 20 07-08-2010 12:11 AM
.82 a/r housing on the t3/t04e 57 trim turbo komat Forced Induction 7 04-10-2006 05:51 PM
where can i get a gt37 for a good price Fulle-loaded Forced Induction 0 11-03-2004 09:37 AM
need a little turbo information help B00STeD Forced Induction 7 08-21-2002 03:59 PM
60-1 T3/T4 Turbo Sale Full-Race Javier Forced Induction 3 07-09-2002 04:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
