external wastegate exhaust housing?
Old 07-15-2010, 10:54 PM
logic factory's Avatar
Default external wastegate exhaust housing?
are there any off the self options for a t4? anyone have success creating their own?
Old 07-16-2010, 08:25 AM
EnFOURcer's Avatar
Default Re: external wastegate exhaust housing?
I am also interested in a T4 version
Old 07-16-2010, 09:39 AM
Moderator
TheShodan's Avatar
Only ATP and Forced Performance have these v-band configurations off the turbine housing itself. Unless you have a casting facility that can create one, making one on your own will be very difficult. Forced performance usually use theirs for the GT-R series. I'm not sure if they sell the housings individually, however.
Old 07-16-2010, 11:10 AM
g-gameslude18's Avatar
that appears to be just about the best spot to put a wastegate.
Old 07-16-2010, 11:41 AM
boostedeg302's Avatar
I wonder how the boost creep is with that mani? haha jk that looks awesome and super effective
Old 07-16-2010, 01:39 PM
Adriano's Avatar
I have seen a few guys weld a flange straight to ex housing before. Why not just do that?
Adriano
Old 07-16-2010, 01:45 PM
Moderator
TheShodan's Avatar
Welds are typically **** due the differences in the metallurgy. You're taking steel flanging and using against an oxidized iron nickel. Not the best thing in the world to do. If that's all you have then that's one thing, otherwise, there's no real benefit as you'll more than likely develop exhaust leaks from the gaps the rod couldn't fill in.
Old 07-16-2010, 01:51 PM
Adriano's Avatar
I have welded and seen plenty of v-bands flanges welded to ex housing without any issues. I dont see why welding a w/g flange would be any different???
Adriano
Old 07-16-2010, 02:28 PM
Tony the Tiger's Avatar
Adriano
It's doable, but you'll always get a weaker joint than welding similar metals..
The wastegate has a lot of weight to it, so the housing + flange has to support a lot of stress and now the strength of the weld is critical.
When you weld a V-band flange on the downpipe, first it's usually a big 3" or 4" flange with lots of surface area.. Secondly, the downpipe is usually supported by brackets, exhaust hangers and that takes some weight off the welded joint.
jamjam
06-05-2006 09:21 AM
vtecguy01
12-29-2005 06:42 PM
b00st Junkie
11-25-2005 02:59 PM
Integra808
03-27-2003 03:40 PM
DA666
04-03-2002 08:12 AM
Quick Reply: external wastegate exhaust housing?
