What timing belt for itr water and oil pump
Old 01-06-2008, 07:09 PM
racer034life's Avatar
Default What timing belt for itr water and oil pump
Im wanting to run ITR oil pump and water pump on my ls-t set up. I was woundering what timing belt to run with the new oil and water pump. I didnt know if i would run a vtec or keep a non-vtec one. Also can what gains if any would i get from runing a greddy or toda timing belt if i can use one.
Old 01-06-2008, 08:03 PM
so no one knows anything about this at all with all the people that are LS-t...........
Old 01-06-2008, 10:30 PM
Turbo B18C EJ6's Avatar
Default Re: (racer034life)
If your using the itr oil pump and water pump, you cant use the ls timing belt. You have to use a 1.8 vtec timing belt. i would buy a gsr timing belt its the same as the itr. no differance.
Old 01-06-2008, 10:54 PM
ISPhuevos's Avatar
Default Re: (Turbo B18C EJ6)
when i did my ls-vtec i use a gsr water pump and timing belt, you cannt use a gsr water pump with a itr time belt. The gsr water pump has 22 teeth and the (itr,b16,ls) have 21 i think. So if you use a gsr w/p then you have a gsr timing belt.
Old 01-07-2008, 07:17 AM
also are there any pro's or cons to using a greddy or toda timing belt at all.
Old 01-07-2008, 07:45 AM
Moderator
TheShodan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racer034life &raquo;</TD></TR><TR><TD CLASS="quote">also are there any pro's or cons to using a greddy or toda timing belt at all.</TD></TR></TABLE>
No Hp gains, just a stronger Kevlar belt that can withstand higher RPMS on the engine and is less prone to cracking and wear.
Old 01-07-2008, 10:16 AM
OMG B16's Avatar
Default Re: (ISPhuevos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ISPhuevos &raquo;</TD></TR><TR><TD CLASS="quote">when i did my ls-vtec i use a gsr water pump and timing belt, you cannt use a gsr water pump with a itr time belt. The gsr water pump has 22 teeth and the (itr,b16,ls) have 21 i think. So if you use a gsr w/p then you have a gsr timing belt. </TD></TR></TABLE>
You can use a gsr pump and itr timing belt.
You cant use a LS belt with a vtec water pump. All vtec water pumps have 22teeth where as the LS has 19.
ITR/B16/GSR Water pump on a LS/ITR/GSR Block = GSR or ITR Belt.
Old 01-07-2008, 01:16 PM
blackeg's Avatar
Default Re: (OMG B16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OMG B16 &raquo;</TD></TR><TR><TD CLASS="quote">
ITR/B16/GSR Water pump on a LS/ITR/GSR Block = GSR or ITR Belt.</TD></TR></TABLE>
right
Justintegra
04-20-2008 12:46 PM
vw eater
06-09-2006 07:49 PM
BoOsTiN Dc2
02-07-2004 04:49 AM
BoOsTiN Dc2
02-07-2004 02:32 AM
projectTeG
10-28-2003 02:31 PM
Quick Reply: What timing belt for itr water and oil pump
