What thickness aluminum for end tanks? - Honda-Tech
Old 09-23-2003, 09:39 AM   #1
Overblown-Teg's Avatar
Default What thickness aluminum for end tanks?
Hey all, I wanted to see what thickness everyone uses for end tanks? I'm putting together a few custom intercoolers and I want what is best.. I was thinking .06" or .08" Is that good?
Overblown-Teg is offline   Reply With Quote
Old 09-23-2003, 11:13 AM   #2
dasher's Avatar
Default Re: What thickness aluminum for end tanks? (Overblown-Teg)
.125"
dasher is offline   Reply With Quote
Old 09-23-2003, 11:41 AM   #3
Default Re: What thickness aluminum for end tanks? (dasher)
wow that is freeking thick. is that what the big companies use?
Old 09-23-2003, 11:48 AM   #4
EFb18b's Avatar
something doesn't sound right. | | <---That is pretty freaking thick! I would have thought 1/16" or at max 3/32"
EFb18b is offline   Reply With Quote
Old 09-23-2003, 12:05 PM   #5
Default Re: What thickness aluminum for end tanks? (Redlineracer)
yeah I have some 1/8" that I use to make mounting brackets from. I was thinking 1/16" which is .06".. I'd like some input from Full race and maybe cheapturbo. I know they both are doing custom coolers.
Old 09-23-2003, 12:11 PM   #6
boosted hybrid's Avatar
14 gauge seems to be what PWR makes their end tanks out of, or at least from eye balling a few cores that have been threw my shop. Basically you want the thinest material to keep the thermal conductivity high, but thick enough its not impossible to weld.
boosted hybrid is offline   Reply With Quote
Old 09-23-2003, 12:16 PM   #7
Default Re: What thickness aluminum for end tanks? (boosted hybrid)
So what inch thickness is 14g? I would say from looking at some pipes I have it would be around 1/16".
Old 09-23-2003, 12:30 PM   #8
Lierley Fab
Fabman's Avatar
.080 or .125 3003 or 5052 no 6061
Fabman is offline   Reply With Quote
Old 09-23-2003, 12:39 PM   #9
B*A*N*N*E*D
Default Re: What thickness aluminum for end tanks? (fabman)
Quote:
exactly.
todd, we use .125 5052 for our endtanks.
PeakBoost is offline   Reply With Quote
Old 09-23-2003, 12:46 PM   #10
Default Re: What thickness aluminum for end tanks? (CHEAPTURBOdotCOM)
hmm interesting. I thought for sure you all would use 6061.. Why do you use the others? What rod would you recomend with the 5052? I normally use a 4043 I think. I also have some 5052, should I match the rod to the material?
Wow so your using 1/8" end tanks? That is really heavy. Can you use a normal sheet metal brake to bend them or are you using a press brake?
Old 09-23-2003, 12:47 PM   #11
EFb18b's Avatar
14g = .0781 from my cheat sheet.
Old 09-23-2003, 07:49 PM   #12
dasher's Avatar
.125 is also the thickness Bell Intercoolers uses (owner - Corky Bell)....
Aluminum Alloy 6061 has a thermal conductivity of 180 w/m-k
5052 has a thermal conductivity of 137 w/m-k
1100 has a thermal conductivity of 218 w/m-k
6061 and 5052 are both good alloys for this purpose because they are highly corrosion resistant and strong.... using 1100 would scratch too easily despite it having a really good thermoconductivity(its at least 99% aluminum )
Modified by dasher at 11:30 PM 9/23/2003
Rear brake shoe tolerance Zebra Honda Civic (2006 - 2015) 2 06-05-2016 02:47 AM
who has blox adjustable end links? amej8 Suspension & Brakes 6 05-19-2009 04:42 AM
intake manifold material 4drsedaneg Welding / Fabrication 6 02-09-2009 12:04 PM
JDM front question....intercooler question Boosted_01 R Acura Integra Type-R 3 01-14-2009 05:41 PM
Fabbing IC end tanks, how thick? Boilermaker1 Welding / Fabrication 5 04-17-2006 09:35 PM
Tags
1100, 3003, al, alloy, aluminum, big, end, endtanks, intercooler, metal, sheetmetal, tanks, thicjness, thickness, wmk
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
