gsr cams
Old 03-22-2004, 02:10 PM
bluesi00's Avatar
Default gsr cams
to put gsr cams in my turbo civic si do i have to use gsr cam gears, or do i use my stock cam gears??
Old 03-22-2004, 02:11 PM
TeamCracka's Avatar
Default Re: gsr cams (bluesi00)
Doesnt matter, both will fit fine.
Old 03-22-2004, 02:20 PM
bluesi00's Avatar
ok cool thanks. also the clearences of the valvetrain stay the same as a stock b16a2 head??
Old 03-22-2004, 03:36 PM
Jared's Avatar
Default Re: (bluesi00)
valve lash will need to be adjusted but the specs stay the same
Old 03-23-2004, 07:59 AM
bluesi00's Avatar
what will they be adjusted to?
Old 03-23-2004, 08:27 AM
Rod.'s Avatar
I would like to know also. I am in the same boat
Old 03-23-2004, 12:43 PM
bluesi00's Avatar
Default Re: (redturbocivic)
Old 03-23-2004, 09:54 PM
99blusi's Avatar
I believe Si cams and GSR cams require the same clearance...not 100% on this, but I'm thinking that they do.
Old 03-23-2004, 10:15 PM
bluesi00's Avatar
can anyone add to that???
Old 03-23-2004, 10:32 PM
ScottEK's Avatar
You adjust the valve lash to the setting of your head, one of the reasons they will have to be adjusted is because when you are installing them you loosen the valve lash adjustments to prevent the cam from binding. Dropping in the cams and just smashing on the cam caps wouldn't be very wise.
kdohio
10
10-26-2010 11:49 AM
TurboJdmEF9
05-26-2006 02:16 PM
kndaqikEG
01-12-2005 01:09 PM
Quick Reply: gsr cams
