what spark plugs you runnin
Re: what spark plugs you runnin (808eg6)
yes run colder plugs for FI. i was running bkr7e-11's but im trying out other plugs. Some other plugs you might want to try are bcp7e-11's or bkr7en-11's
Re: what spark plugs you runnin (DLB1994)
They didn't last cuz of the gapping. What gap did you have it at? You should try a narrower gap.. even though the wider the better.. most people dont have a good ignition setup to run a wide gap.
Re: what spark plugs you runnin (ekb18c)
he can get away with it because he has a good ignition setup. He says he has a full MSD setup, so my understanding is he's got a more powerful spark from some type of MSD amplifier.. therefore he can run a larger gap.
I run denso iridiums on the street and Beru Racing conatant electrode at the track ( they foul to easy on the street) I only run one or max two stages colder as I would rather melt a plug than a piston!
Re: what spark plugs you runnin (GruvyTune)
not sure which, their numbers are all snafu like 42 or 45, I think I asked for an 8 for the street, they are pregapped and I dont suggest chaging it as you may break the electrode. all i know is that at 12 psi the densos made 8hp over the zex i was trying out.
Re: what spark plugs you runnin (B18C-EJ1)
Hey does anyone know the difference between the BKR7E's and the BCPR7E's??
Yes I know what each letter represents.. but has anyone tried both and felt/seen any difference? All I know is that you're not supposed to mis-match them.
Re: what spark plugs you runnin (RealTypeR)
BKR6E, gapped to .30.
The 6's are 1 heat range colder than stock.
I think the 7's foul too easily for street cars.
Re: what spark plugs you runnin (Incognito)
Which company makes these "BKR's".....I am installing my turbo in a few weeks here and I dont want to blow anything. So I figure I should get some of these since it seems the rest of you use them
Wait a minute. How many psi are you guys pushing? If your pushing:
over 14 psi on your motor use NGK part# 5820(NGK Race Plugs R5671A-10).
If your using 7-10 psi use NGK Part# 5238 (NGK Race Plugs R5671A-9)
These are great plugs plus they ar cheap! (couple of bucks)
HTH
HTH
BCPR7E-11's @10psi, does the job
Question: what gap do you guys reccomend for these plugs as this much boost ona stock ignition setup w/ 3 degrees retard in the ignition?
.44 gap and i run full msd setup with accel spark plug wires
Try gapping it at 30. .44 is way too big IMO
try .044
