What rings to use?
What rings to use?
I have a 84mm lsvtec with CP pistons and am going to freshin it up....what are you guys using for rings? rings from CP themselves? or oem Honda rings?
Re: What rings to use?
My machinist was very impressed with the CP pistons and rings. He used to assemble engines for indy car teams so that is saying something.
Who is Mr Robot?
Um round ones? Jk lol
Typically a "shelf" forged piston will use the same size rings as an OEM piston in regards to thickness/height.
CP rings are quality, total seal rings are nice pieces as well. OEM will also work assuming what I said about ring size.
For the most part all of the rings for a particular application are the same if not damn similar. It's only when you start making huge power, running very high rpm for long durations, or are building a motor around vert specific requirements for operation that the design of the rings starts to come into play.
Basically if they are round and fit the piston and are gapped and installed correctly you should be fine.
