What pressure plate for 400hp integra
i want to get a clutch and pressure plate for my turbo Ls\vtec im building and was wondering which one to choose i already have a competition stage two and was wondering if i could upgade the pressure plate only to avoid the disc from eating my flywheel must be able to hold 400hp
Re: What pressure plate for 400hp integra (HamiltonRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex »</TD></TR><TR><TD CLASS="quote">the exedy twin disc setup should hold the power.</TD></TR></TABLE>
he's making 400 hp. not 800
Re: What pressure plate for 400hp integra (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic »</TD></TR><TR><TD CLASS="quote">he's making 400 hp. not 800 </TD></TR></TABLE>
I was being sarcastic. Stupid questions deserve stupid answers.
so whats stupid about my question it a legit querry.... all you honda tech guys are all the same selfish and ridiculuously unhelpful when unexperienced person ask a question insread of giving a **** you send them to go search archives is this a forum where people are free to exchange ideas or what.......
Re: What pressure plate for 400hp integra (Spec R_GSR)
ok, heres what i think (honestly)
A good clutch setup for about 400whp.
ACT XXtreme duty PP with a 4 puck unsprung disc, or a 6 puck unsprung.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex »</TD></TR><TR><TD CLASS="quote">ok, heres what i think (honestly)
ACT XXtreme duty PP with a 4 puck unsprung disc, or a 6 puck unsprung.</TD></TR></TABLE>
Re: What pressure plate for 400hp integra (PrecisionH23a)
ACT XTR6 - Xtreme pressure plate and a 6-puck unsprung disk
That worked well for me on my >400 WHP B16 setup. I slipped it a lot and generally abused the hell out of it for a year or so, no problems.
Re: (bigbadboy)
thanks alot guys for the input much appreciated but do those six puck discs cause any pemature wear to a flywheel by the way this is going to be a daily street driven car so it must be able to be drivable in traffic
Re: (PrecisionH23a)
depends on what his plans for the car are also.
If hes just going to be running around the streets on a standard 205/50/15 street tire then he should be ok with something 'rated' for his setup.. But if he wants to beat it at the track on 24.5" slicks, then he should go overkill a bit. Just my opinion.
ACT Im running a standard 'heavy duty PP with the full organic street disc' no problems yet.. slips a bit sometimes but held up good on 22's.
Re: (Spec R_GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spec R_GSR »</TD></TR><TR><TD CLASS="quote">see thats the combination im thinking about a organic street disc with like a heavy duty pp or xrteme pp </TD></TR></TABLE>
no it wont be enough dude, dont go with the full organic disc. definatly a 6puck and xtreme plate or heavier.
Re: (zeimbo)
I rock the XTSS with 6 puck unsprung, I daily drive my setup, 400whp, and to tell you the truth I HATE THIS CLUTCH!!!
The engagment is so harsh when your just trying to pull outta somewhere and drive like normal.
I will never get an unsprung clutch again for daily driver use!!!
Re: (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a »</TD></TR><TR><TD CLASS="quote">The XTSS holds 319ftlbs... that should get you around the 400whp marker on a GSR.</TD></TR></TABLE>
this is the one im using on my stock motor, lets hope it holds a little more than 400whp once the built motor is ready.
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spec R_GSR »</TD></TR><TR><TD CLASS="quote">so whats stupid about my question it a legit querry.... all you honda tech guys are all the same selfish and ridiculuously unhelpful when unexperienced person ask a question insread of giving a **** you send them to go search archives is this a forum where people are free to exchange ideas or what.......</TD></TR></TABLE>Sad a post like this has to be the truth to some extent.
Anyway, check out Spec & Competition cluthes. I like them both.
1 Post
Re: (mike1114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 »</TD></TR><TR><TD CLASS="quote">I rock the XTSS with 6 puck unsprung, I daily drive my setup, 400whp, and to tell you the truth I HATE THIS CLUTCH!!!
I will never get an unsprung clutch again for daily driver use!!!</TD></TR></TABLE>Just a question about your set up...Do you have solid motor mounts or inserts? I ask cause I drove a D series turbo Civic that had bad clutch chatter getting the car moving but when the inserts were installed it stopped completely. Made the car much more pleasent to drive.
Re: (mike1114)
i have a 6 puck unsprung and the xtreme pressure plate on my integra right now (210whp greddy kit) and engagement isnt harsh at all. it does bang gears when youre revving out tho. the first couple weeks was stiff as hell and gave my calve a workout but it relaxed a little after that and i dont have to slip the clutch to get out of first (unless im running someone).
