what injectors to use with 350-400whp?
Old 12-06-2006, 06:44 AM
92redhatch's Avatar
Default what injectors to use with 350-450whp?
right now i have a set of rc 550 cc's. I want to keep the injectors at about a 80% duty cycle. The motor is a b16 on a 57 trim turbo with forged internals. i want to make from 350 to 450 whp. I know i have to change the 550's so what size would be just right for this horsepower number?
thanx
Old 12-06-2006, 06:56 AM
Moderator in Chief
Muckman's Avatar
Default Re: what injectors to use with 350-450whp? (92redhatch)
750cc
Old 12-06-2006, 07:02 AM
11SEC CIV's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92redhatch &raquo;</TD></TR><TR><TD CLASS="quote"> I want to keep the injectors at about a 80% duty cycle. </TD></TR></TABLE>
curious on why? why not just get 1000's/96lbers and not worry about it
you know how boost is addictive
Old 12-06-2006, 07:03 AM
aaronISthrowed's Avatar
Default Re: what injectors to use with 350-450whp? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">750cc</TD></TR></TABLE>
Old 12-06-2006, 07:08 AM
92redhatch's Avatar
nah 1000cc injectors are over doing it. Its a stock sleeve b16a2 i dont want to push more then 450whp. its my daily driver. and daily driven it will only be on 6 psi.
Old 12-06-2006, 08:17 AM
HamiltonRex's Avatar
Default Re: (92redhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92redhatch &raquo;</TD></TR><TR><TD CLASS="quote">nah 1000cc injectors are over doing it. Its a stock sleeve b16a2 i dont want to push more then 450whp. its my daily driver. and daily driven it will only be on 6 psi.</TD></TR></TABLE>
how your gonna run 6psi daily and make 450whp.. swap out the WG springs whenever? I doubt you will make 450 on 12psi.
Anyways.. 750's should do it, 780's is what im running.
Old 12-06-2006, 08:40 AM
N20civicB18's Avatar
Default Re: (HamiltonRex)
id say 750's but i do have a set of PTE 1000's forsale only have about 500 miles on them $250 PM me if interested
Old 12-06-2006, 09:01 AM
Moderator in Chief
Muckman's Avatar
750s are nice because its the biggest size you can get from RC thats saturated (OBD2) so you dont need to wire up a lame resistor box.
Old 12-06-2006, 09:09 AM
92redhatch's Avatar
i forgot to add i have a turbo xs boost controller. Im not trying to make 450whp on 6 psi. 6 psi i should make like 220whp. on about 20 psi i should be pretty close to the 400whp range if not past it. High boost is only for track days. What power should i see with the 550cc's at 80% duty cycle? like 300whp?
Old 12-06-2006, 09:11 AM
komat's Avatar
750 will be enough
i got 1000cc at 420hp its at 60ish%
Old 12-06-2006, 09:18 AM
92redhatch's Avatar
ya thats what i thought that 750cc's would be just about right for my setup and horsepower goals. Now the question is what horsepower will the 550cc's make at 80% duty cycle? Im guessing around 300whp.
Old 12-06-2006, 09:45 AM
Moderator in Chief
Muckman's Avatar
Ive personally seen 550s max out at 341whp at a low fuel pressure.. (base of 35psi). I think you could get 350 out of them safely.
Old 12-06-2006, 09:49 AM
PrecisionH23a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92redhatch &raquo;</TD></TR><TR><TD CLASS="quote">ya thats what i thought that 750cc's would be just about right for my setup and horsepower goals. Now the question is what horsepower will the 550cc's make at 80% duty cycle? Im guessing around 300whp.</TD></TR></TABLE>
I have maxed 440's out at 100% duty cycle at 317whp on a dyno jet. The last set of 750cc's I maxed at 100% was at 470whp. I don't recall working with too many 550cc set-ups... but I think at 80% duty cycle will net you around 340-360whp with stock fuel pressure.
Anyways, go with 750's as everyone else has already said.
Old 12-06-2006, 09:54 AM
slowsi00's Avatar
&lt; -- 400whp 440cc injectors
lots of fuel pressure.
Old 12-06-2006, 09:57 AM
PA MATT's Avatar
Default Re: (slowsi00)
Why not just get the 1000 cc's in case you end up building down the road? isn't the price difference pretty small?
Old 12-06-2006, 10:09 AM
92redhatch's Avatar
because i want an 80% duty cycle to ensure that i have a really good spray patern. And if i do build another block later on it will be years down the road so theres no point in having the 1000's.
Old 12-06-2006, 07:14 PM
PA MATT's Avatar
not trying to jack your thread and I can delete this if you like, but does anybody want to chime in on 1000's? would there be any problem running 1000's at 300-400whp? Would it really be beneficial to use 750's?
Old 12-06-2006, 10:15 PM
Man U FTW
Schister66's Avatar
how about a compromise at 880cc....
Old 12-07-2006, 03:42 AM
wrx'n you's Avatar
Default Re: (PA MATT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PA MATT &raquo;</TD></TR><TR><TD CLASS="quote">not trying to jack your thread and I can delete this if you like, but does anybody want to chime in on 1000's? would there be any problem running 1000's at 300-400whp? Would it really be beneficial to use 750's? </TD></TR></TABLE>
yeah, i wanna know also
Old 12-07-2006, 05:06 AM
92redhatch's Avatar
the spray pattern. At 80% the injector has a great spray patern. at 100% the spray pattern sux. and anything under 75% the spray pattern isnt so good either.
Old 12-07-2006, 05:19 AM
cuin9sec
Guest
Posts: n/a
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">how about a compromise at 880cc....</TD></TR></TABLE>
thats what i was going to say...i thing 880's would be best.
Old 12-07-2006, 05:46 AM
Drkaccrd's Avatar
tegman2
08-09-2008 05:18 PM
99_red_si
03-01-2008 09:14 PM
chieu
07-03-2007 09:18 AM
all_out_jdm
07-09-2005 10:50 AM
93H22A
06-16-2003 02:27 AM
Quick Reply: what injectors to use with 350-400whp?
