what gap for gsr turbo spark plug? - Honda-Tech
Old 07-21-2007, 06:09 PM   #1
gsrtpower's Avatar
Default what gap for gsr turbo spark plug?
what do u guyz recommend? currently running the 2 step cold plug....hit me up with some info...thx
gsrtpower is offline   Reply With Quote
Old 07-21-2007, 06:36 PM   #2
B A N N E D
I heard anywhere from .030-.038 is good
garrettej8 is offline   Reply With Quote
Old 07-21-2007, 11:37 PM   #3
Default Re: (garrettej8)
Ask your tuner what he likes
RCautoworks.com is offline   Reply With Quote
Old 07-22-2007, 05:44 AM   #4
Adriano's Avatar
Default Re: what gap for gsr turbo spark plug? (Mr Wonderfull)
I run plug 9's and gap them to .022-.024.
Adriano
Adriano is offline   Reply With Quote
Old 07-22-2007, 08:28 PM   #5
gsrtpower's Avatar
Default Re: what gap for gsr turbo spark plug? (Adriano)
alrite i just adjust my plug to .30
what the reason y people set it low for turbo?
do u gain more hp? does it burn better fuel in the high rpm..or what??????
what is it primary purpose...sorry i just started my first turbo project....need a lot to learn...planning to boost 10lb<<<<<what do u guyz recommmend the gap for 10lb...with a gsr t3 t4 turbo??????hit me up with some good info thx
what kind of spark wire ya recommend for turbo...am currently running stock plug...plan of getting nology hot wire.....is that brand good.....let me know..thx
Old 07-22-2007, 08:52 PM   #6
Default Re: what gap for gsr turbo spark plug? (gsrtpower)
The reason you need a smaller gap is due to the fact that with a turbo, cylinder pressure is increased. It is more difficult for the spark to jump the gap. That is why you use a shorter distance (gap).
Kyle R is offline   Reply With Quote
Old 07-22-2007, 08:57 PM   #7
needmypass's Avatar
Default Re: what gap for gsr turbo spark plug? (herecomesboost)
well i think its the amount of fuel in the cylinder in a boosted setup makes it harder to spark. a/f ratio is usally lower
needmypass is offline   Reply With Quote
Old 07-23-2007, 07:48 AM   #8
oscarmayer's Avatar
-7 at 28-34 is good for your needs.
you sould consider changing to a more race style plug. they seem to work better as well with boosted.
R5672A-7 would be your needs.
oscarmayer is offline   Reply With Quote
Old 07-23-2007, 09:04 AM   #9
MeanGreenMachine's Avatar
Default Re: (RCautoworks)
Quote:
MeanGreenMachine is offline   Reply With Quote
Old 07-23-2007, 12:57 PM   #10
blackeg's Avatar
Default Re: (Mr Wonderfull)
im running the bkr7e's gapped to .020. 412hp stock ignition on 17 psi not 1 hint of spark knock
blackeg is offline   Reply With Quote
Old 07-23-2007, 01:06 PM   #11
ej8
ej8's Avatar
Default Re: (blackeg)
I run 7's @ 0.030, 8psi boost on b18a1
Old 07-23-2007, 03:41 PM   #12
needmypass's Avatar
i don't think your spark plugs fire when the intake valves are open lol.
Old 07-23-2007, 03:45 PM   #13
Default Re: (needmypass)
What does that have to do with anything? Air has mass. Compressed air is more dense (more mass per unit volume). Making it more difficult for the spark to jump the gap.
Old 07-23-2007, 03:58 PM   #14
needmypass's Avatar
Default Re: (herecomesboost)
The whole reason the gaps need to be closed up is nopt how much fuel... Its air, the pressure of the charge entering the chamber blows out the spark if the gap is too big, reducing gap reduces resistance, and makes it easier for the spark to jump, and harder for the charge to blow it out.
charge entering the chamber blows out the spark if the gap is too big....... blows it out.
Old 07-23-2007, 03:59 PM   #15
I didn't post that. Someone else did. I thought you were talking to me
Old 07-23-2007, 04:06 PM   #16
needmypass's Avatar
Quote:
was this for me. I thought it was so i tried posting the quote from the other guy and why i said this
Old 07-23-2007, 09:54 PM   #17
gsrtpower's Avatar
thx for the info guyz....i just recently adjusted my ngk 7 to .30....
is thier anything i nned to konw more about...? hit me up with some info..thx
spark plugs tArebelpinoy Honda Accord (1990 - 2002) 16 08-25-2008 10:39 PM
Spark Plug QuickTypeR Acura Integra Type-R 7 04-26-2004 10:02 PM
Spark Plug Question MARC P All Motor / Naturally Aspirated 12 08-07-2003 01:57 PM
plug on top of intake manifold??? dose Hybrid / Engine Swaps 6 11-21-2002 10:15 AM
spark plugs HYBRIDHATCH92 Tech / Misc 4 04-04-2002 10:10 AM
Tags
94, alrite, gap, gsr, hatch, ls, ngk, plug, plugs, r5672a7, spark, talon, tsi, turbo, vtec
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
