What is the best cams for turbo
i have a ls vtec turbo, but i want a better cams in my set up, what cams can i use, i like so much how the cams sound .
Re: What is the best cams for turbo
well i like so much the sound, but my set up is wiseco pistons 9:0 c/r golden eagle rods KMS springs and retainers, type r intake manifold, 1000cc rc injectors, fuel lab regulator and im using VP C16 fuel walbro 400 pump
honestly itll be a matter of opinion.
i would say anywhere from pro 1s, gsc t1s, tuner1s, gsc n1s, maybe todas, maybe crowers( last result), and of course ddtechs
turbo and manifold info needed. you could possibly be hurting your performance.
maybe go back and read the tech in the gsc turbo cams vs. itr cams
I never narc'd on nobody!
Notice that no where in that did I mention BRIAN Crower. We're talking about the actual Crower, not the spin-off.
yeah dependin on what...... turbo and manifold do you have.
and are your 9.0:1 at 81, 81.5, 84mm bore......?
need answers to some of these questions.
Straight from Junk2's website:
Recommended: High-compression, fuel pressure regulator and/or upgraded fuel injectors, VTEC controller, modified ECU.
so is it a drag build or street and drag. are you lookin for peak power, or a wide power band.
sounds like something around pro 1s or any t1s. keeps forgettin bout derreks cams.
Never said I knew everything. You, however, don't even know the specs or recommendations on the products you're recommending to this guy.
He doesn't have raised compression. In fact, he has LOWERED compression. The Pro 1's would be a bad match for his setup. You still haven't told us why you have Crower so much, either. At least they haven't put bounties out on a bugny of their customers...
lmao listen racist he know his ****.
just do us all a favor and read that gsc vs itr thread. good amount of tech from there to start your basis on
i had pro1's on a 9 to 1 setup, lets just say after a few pulls i swapped back to GSR cams. the pro1's DID NOT get along with my setup at all. my tuner told me more compression and they would have likely worked. maybe next time I'll bump compression and buy another set (i sold them to a friend who could actually use them at the time).
