what arp head studs do i use for my ls vtec
Old 12-16-2010, 05:57 PM
gs-r94coupe's Avatar
Default what arp head studs do i use for my ls vtec
old setup was ls turbo with arp head studs and rod bolts,was wondering if i can use the head studs off my ls for the ls vtec.
im putting a 96 gsr head on it will the ls arp head studs work or will i need to buy different ones.
help please
Old 12-16-2010, 09:27 PM
ryguy2588's Avatar
Default Re: what arp head studs do i use for my ls vtec
"A B16 block will always use B16 headstuds no matter what B-series VTEC head because of the blocks deck. A GSR, LS/VTEC, B20/VTEC will use GSR headstuds no matter what B-series VTEC head."
The B16 head studs will work, but they just won't stick up as far as the GSR ones cuz the GSR ones are a little longer.
Old 12-16-2010, 09:30 PM
so i cant use my ls ones i already have, i have to go buy gsr ones
Old 12-16-2010, 09:39 PM
ryguy2588's Avatar
No you can't use the LS ones. You have to use the VTEC head studs. Either the GSR or B16. I would just get the GSR ones because they're longer than the B16 ones.
Old 12-16-2010, 11:22 PM
king06's Avatar
GSR's
Old 12-16-2010, 11:40 PM
AllShowNoGo727's Avatar
ARP LS VTEC head studs they are cheap...
Old 12-17-2010, 09:26 PM
aight thanks guys will go buy a set of gsr ones tomorrow lol
Old 01-01-2011, 06:29 PM
Bseriescivic5's Avatar
Is the deck height on the ls (b18a,b,) the same as gsr deck height? p72.???
Old 01-01-2011, 07:55 PM
ryguy2588's Avatar
No they aren't the same here are a couple sites that you can find more info and numbers for them.
https://honda-tech.com/forums/tech-misc-15/block-deck-height-differences-b18a-b-b16a-b16b-b18c-b20-1312642/
http://www.zealautowerks.com/bseries.html
B18A/B: 211.84mm
B18C: 212.39mm
I'm pretty sure there can me a little variance in these numbers, but I don't believe there are the same.
gs-r94coupe
23
12-17-2010 09:27 PM
almostjdmeg
01-03-2009 07:41 AM
aemintgsr
04-07-2007 11:52 AM
turbo*s2k
11-14-2003 01:49 PM
SoloSol
01-09-2002 04:38 PM
Quick Reply: what arp head studs do i use for my ls vtec
