weight difference between mild-steel and aluminum intercooler piping?
Old 01-24-2005, 10:03 AM
whitelightnin's Avatar
Default weight difference between mild-steel and aluminum intercooler piping?
is it alot?
if anyone can give me APPROX. weight differences, id appreciate it!
thanks
R2
Old 01-24-2005, 10:18 AM
b18bturbo's Avatar
Default Re: weight difference between mild-steel and aluminum intercooler piping? (whitelightnin)
your going to save approx 5-10lbs depending on what thickness aluminum as well as mild steel you use
Old 01-24-2005, 11:20 AM
WREKONIZE V8 KLR's Avatar
13lbs difference on my 2.5 setup, alum-vs-ss
Old 01-24-2005, 12:36 PM
Tony the Tiger's Avatar
Default Re: weight difference between mild-steel and aluminum intercooler piping? (WREKONIZE V8 KLR)
I saved about 15 lbs switching over to aluminum piping.
Old 01-24-2005, 12:40 PM
PM-Performance's Avatar
Default Re: weight difference between mild-steel and aluminum intercooler piping? (Tony the Tiger)
15lbs? 12lbs? I didnt think all my piping in Mild steel even weighed that much. Damn, i woulda guessed wayyyy off then . lol.
Old 01-24-2005, 01:22 PM
RyanEJ8's Avatar
Default Re: weight difference between mild-steel and aluminum intercooler piping? (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">15lbs? 12lbs? I didnt think all my piping in Mild steel even weighed that much. Damn, i woulda guessed wayyyy off then . lol. </TD></TR></TABLE>
It didn't seem like mine even weighted 15 lbs total. Aluminized Steel.
Old 01-27-2005, 01:47 PM
pubestripe's Avatar
Default Re: weight difference between mild-steel and aluminum intercooler piping? (RyanCivic2000)
does heat affect the aluminum piping at all? i thought that aluminum heat had a drop off at like 300-400 degrees where it began to soften, so does anyone with aluminum piping run into that prob?
Old 01-27-2005, 02:06 PM
J337_UNIT's Avatar
Default Re: weight difference between mild-steel and aluminum intercooler piping? (pubestripe)
there wont be enough heat to do anything to the aluminum piping if its used as intercooler piping... even on the hottest day.
Old 01-27-2005, 02:08 PM
pubestripe's Avatar
Default Re: weight difference between mild-steel and aluminum intercooler piping? (J337_UNIT)
k, that is what i thought... thanks!
b16bri
08-05-2010 08:47 PM
denraweb
02-07-2008 09:35 AM
Mugencrxsir1
03-13-2006 12:38 PM
TodaTeg
07-13-2003 06:44 AM
Quick Reply: weight difference between mild-steel and aluminum intercooler piping?
