Water/meth kit plus q16? HELP
Old 04-06-2016, 09:45 PM
miahjera04's Avatar
Default Water/meth kit plus q16? HELP
Currently have a turbo ls/v setup on 2 tunes. Makes 427whp on 93 and 557whp on q16. Since q16 is $15/gallon I've been debating on adding a 5gal aem water/meth kit to the setup. Both tunes are plenty safe for the car, thinking the added aem kit will allow for a bit more boost while staying "safe"... thinkin...500whp on 93+meth. My main question/concern is will the meth act the same way with the q16? As far as iat's/afr's go? Don't know if meth serves any purpose being mixed with that fuel... if it has beneficial effects like it would with pump gas, thinkin of shooting for a safe tune pushing 600whp on the q16+meth. Any and all insight greatly appreciated.
Edit: the whole reason 4 asking is b/c I'd rather run the 93/meth setup more and save some $, and only using the q16 for track or racing in Mexico w/$ involved. But don't wanna spend $500 for the kit plus $ for retune if it's essentially not really worth it
Old 04-07-2016, 06:49 AM
Moderator
TheShodan's Avatar
Default Re: Water/meth kit plus q16? HELP
Short answer, yes.. but closer to c16, or C110 depending upon methanol mixture type.
*waiting on sometime with E85 sheeple solution to come in*
Old 04-07-2016, 08:45 AM
LightningTeg's Avatar
E85 yo.
Old 04-07-2016, 10:10 AM
miahjera04's Avatar
I have to drive 30+ min to get e85, and that gas station has been known to have shitty fuel... so no thanks.
Old 04-07-2016, 10:11 AM
miahjera04's Avatar
I'm not really following, what do u mean closers to c16,c110
Old 04-07-2016, 10:41 AM
Man U FTW
Schister66's Avatar
You're just a hater, Mac. Time to jump on the corn bandwagon
Old 04-07-2016, 11:11 AM
Dark_Teg's Avatar
I wish I could jump on the bandwagon. E85 is 100 miles away from me and shipping by the drum brings the price pretty close to C16.
Old 04-07-2016, 07:35 PM
Moderator
TheShodan's Avatar
Yeah. That's what it is. .
Old 04-07-2016, 07:53 PM
mtber's Avatar
You will be able to make the same 550 whp you are making on c16 with 93octane + a meth kit properly setup & spraying 100% m1, m3 or m5
You will need a retune. You will want to properly setup the kit & fail safes etc.
FYI you can make well over 600whp on q16 without meth & you can make close to 500 whp on a properly setup & tuned turbo bseries on 93 octane.
Old 04-07-2016, 07:55 PM
miahjera04's Avatar
Ok I figured as much. My main question though was asking about adding meth to the Q16
Old 04-07-2016, 08:02 PM
Moderator
TheShodan's Avatar
There's no point in doing that. The point is to have reasonable knock resistance. You have all the corrosive effects of Q16, and only half the benefits. . You don't stack all the benefit together.
Old 04-07-2016, 08:38 PM
miahjera04's Avatar
Ok, I'll leave the setup alone for now then... keep buying the q16 when I want the extra power.thanks
raene
05-17-2014 06:14 AM
Central Florida Turbo
Performance
03-13-2010 07:47 PM
speed1
03-09-2010 06:22 AM
boostedb20z
08-14-2009 09:13 AM
ActiveAero
10-23-2004 12:29 PM
Quick Reply: Water/meth kit plus q16? HELP
