Water/Meth Fail Safe Transducer Hook Up need help :)
Old 04-07-2015, 06:29 PM
ESP.net's Avatar
Default Water/Meth Fail Safe Transducer Hook Up need help :)
I have the below pictured Transducer with Devils Own/Controller Water/Meth inj kit. It is a 3 wire setup. I have the Transducer T'd inline with the control solenoid after. So pump-transducer-control solenoid.
From my understanding Blk wire is grounded. Grounded to Thermostat. Red wire is ran to the ECU and Blue is not used. I have a Hondata s300v2 does the Red wire go to one of the analog pigtails that the v2 has? I am looking where to put this 1 wire? Also I am curious how do you set this up for fail safe protection is there a certain program such as nitrous to control this in order to back down boost etc? I am not an electrical wiz. But 1 wire short from completion Tuner can handle the rest...
Thanks for the help.
ESP.net
Engine Management and Tuning
10
04-13-2015 03:41 PM
ESP.net
04-07-2015 06:26 PM
nigtron
07-07-2007 08:41 AM
T25 civic
10-06-2002 02:11 PM
Quick Reply: Water/Meth Fail Safe Transducer Hook Up need help :)
