Very fine red/rustish looking dust inside distributor cap??? - Honda-Tech
Old 04-23-2005, 02:35 PM   #1
IloveNewt's Avatar
Default Very fine red/rustish looking dust inside distributor cap???
As the subject states, there is this very fine redish/rustish looking dust covering the inside of my cap. Is this OK? Normal? Anyone else have this? My ignition setup is stock except for a msd blaster coil.
IloveNewt is offline   Reply With Quote
Old 04-23-2005, 04:37 PM   #2
non-VTEC's Avatar
Default Re: Very fine red/rustish looking dust inside distributor cap??? (MordecaiPSI)
i do belive that redish dust/rust is coming from your distributor bearing. its on it's way out......you should be replacing it soon. $$$
non-VTEC is offline   Reply With Quote
Old 04-23-2005, 05:03 PM   #3
BlueSi2k's Avatar
Default Re: Very fine red/rustish looking dust inside distributor cap??? (non-VTEC)
you may be gettin some moisture inside the cap. How did you run the wires from the external coil? Have you washed under your hood lately?
BlueSi2k is offline   Reply With Quote
Old 04-23-2005, 09:14 PM   #4
IloveNewt's Avatar
Default Re: Very fine red/rustish looking dust inside distributor cap??? (BlueSi2k)
I am not sure what you mean by running the wires from my external coil. You know the H23 came with an external coil stock correct?
Are you sure this is a sign of the distributor going out? Dont dizzies make weird knocking sounds when they start going bad?
Old 04-23-2005, 09:48 PM   #5
EE_Chris's Avatar
They nicknamed it "Red Death" for a reason - your distributor bushing is about to go. You have to replace the sub-assembly.
EE_Chris is offline   Reply With Quote
Old 04-23-2005, 09:58 PM   #6
FredoSP's Avatar
Default Re: Very fine red/rustish looking dust inside distributor cap??? (EE_Chris)
what exactly is the distributor bushing?
FredoSP is offline   Reply With Quote
Old 04-24-2005, 02:38 AM   #7
havok hybrid's Avatar
Default Re: Very fine red/rustish looking dust inside distributor cap??? (FredoSP)
IF you happen you be running a MSD cap .. the red dust is from the glue/filling its breaking down.....
Or its the bushing it you have stock cap.. or both
havok hybrid is offline   Reply With Quote
Old 04-24-2005, 06:01 AM   #8
EE_Chris's Avatar
Quote:
Its what the distributor shaft spins on.
Old 04-24-2005, 08:50 AM   #9
mrDFWmechanic's Avatar
so when u see this " red death " you have to replace the whole dizzy then
mrDFWmechanic is offline   Reply With Quote
Old 04-24-2005, 09:25 AM   #10
IloveNewt's Avatar
Default Re: (iROCKtheSOHC)
Damnit.......this distruibutor is less than 5,000 miles old. Anyone know where to get a new OEM dizzy thats not an arm and a leg?
Old 04-24-2005, 05:17 PM   #11
BlueSi2k's Avatar
Oh, my bad. On b series you have to run the wires out from the internal coil.
Do I need to clean the inside of my PC? GoLowDrew General Discussion and Debate 15 03-26-2012 04:29 PM
T/W- 92' Honda Civic DX Hatch LSEGHATCH Vehicles for sale 8 06-24-2005 09:09 PM
Powdercoated jdm header? digital sol Acura Integra Type-R 3 05-25-2005 07:02 AM
Red dust inside distributer cap...What is this?...NORMAL? IloveNewt Tech / Misc 8 04-28-2005 08:22 PM
Red dust inside Distributor - 90 CRX Si Count Blah Honda CRX / EF Civic (1988 - 1991) 6 09-29-2002 01:52 PM
Tags
accord, bearing, bushing, cap, civic, corrison, death, distributor, dust, fine, honda, inside, red, replacement, rust
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
