valve cover breather
Old 11-19-2013, 06:21 PM
Pellegrini808's Avatar
Default valve cover breather
hey guys ive got a b16 with 300 whp, ive been looking at all the breather kits just wondering if anyone is running a valve cover breather kit, if so which one, what maintenance to they require, and which one do you recommend? i dont want the big box ones with three filters, do i need one with a drain back plug because i hear up people having problems with the cans squirting oil every where in the engine aby
Old 11-19-2013, 06:36 PM
Charlie Moua's Avatar
Default Re: valve cover breather
there's a thread on it already. good read.
IMHO for 300whp, if you really want one - KISS
you could just easily drill & use ntp fittings on the backside and plumb lines to a ebay catch can. Mount the catch can higher the block. Have a return line of the catch can feed back into the top 90 fitting onto of your stock black canister box.
Old 11-19-2013, 09:06 PM
Moderator
TheShodan's Avatar
300whp, its not even needed.
Old 11-19-2013, 11:57 PM
Who is Mr Robot?
wantboost's Avatar
well that depends on a lot of things :p
health of the motor
boost pressure being run/turbo size
max engine rpm
compression ratio (if the bottom end isn't stock)
it might not be absolutely mandatory at that power level but a good crankcase ventilation setup can never hurt
Old 11-21-2013, 10:40 PM
slowcivic2k's Avatar
Depends on the ring gap, piston to bore clearance oil viscosity. The more you can prevent crankcase pressure, the better.
Old 11-21-2013, 11:00 PM
SiRCiviC94's Avatar
Better safe than sorry your ring lands won't crack as easily . My similar set up is running stock ok and raced a lot but need to do 2 ports on the covert for an oz more of hp
Old 11-23-2013, 06:07 AM
Who is Mr Robot?
wantboost's Avatar
Crankcase pressure and blowby has nothing to do with ringland lifespan, especially when using a stock cast piston
Old 11-23-2013, 09:39 AM
motoxxxman's Avatar
actually, yeah it does have something to do with it. crankcase pressure can cause ring flutter, which definitely can damage ringlands. especially on used pistons where the ring grooves are worn. the more worn the grooves are, the more flutter crank pressure will cause, and the more likely a ringland will crack
Kompressorbengt
05-04-2017 08:41 PM
slippery seal
07-01-2015 06:06 AM
slowassBubble
07-25-2012 06:30 PM
93egallmotor
04-21-2007 01:45 PM
wdwalker
04-10-2005 09:42 PM
Quick Reply: valve cover breather
