Vaccum nipples on Turbo and wastegate
Okay I have three questions....I have a 95 Prelude vtec with a drag 2 turbo kit. (T3/T04B Super V)
1) On the Delta waste gate, what is the top vaccum port for? The one next to the
bolt for adjusting the pressure of boost.
2) On the Delta wastegate, what is the nipple on the side of the waste gate for?
3) On the Intake side of the turbo, there is also a vaccum nipple, what is that for?
Thanks in advance!!!
Re: Vaccum nipples on Turbo and wastegate (95PRELUDEVTEC206)
Top is for electronic boost controller. The one on the side should go to the intake manifold, and if y ou have a manual boost controller...inturrept this line. The nip on the turbo is absolute pressure, another electronic boost controller relation. Plug it if you dont run an EBC.
HT's Biggest Loser
Re: Vaccum nipples on Turbo and wastegate (B18EG6)
The nip on the turbo is absolute pressure. Plug it if you dont run an EBC.
someone told me that i should run the nipple on the intake turbo side into the nipple on the wastegate and tee it off to the MBC...what do you guys think?
Markb16a
06-27-2007 08:42 PM
underpressure02
10-06-2003 08:14 AM
