Turbo vtec issues
Turbo vtec issues
I have a JDM H23 vtec which I have turbo'ed. I'm having an issue with vtec not activating on the car. I'm running an AEM EMS and it says the vtec is engaged, but it's not working. I checked for continuity and the solinoid wire is getting voltage. The vtec solinoid is good as well( took a 12 v source and you can hear hear the solinoid clicking). Just did a oil change to the car and the oil is at the top dot of the dip stick. What else could casue it from not activating? Any ideas? Any help would be great thanks. (Below are specs of the motor)
Mild Port and polished H22A4 head
Ferrea Stainless steel valves, Titanium retainers & dual springs set.
JDM H23 vtec block sleeved by Golden Eagle
Balance Shaft removed and plugged
JE 10:1 forged pistons 87mm
Crower forged H23 Rods
Cometic .40 head gasket
Hondata Intake Manifold gasket
H23 manual tensioner swap
Maxrev Turbo Kit
MaxRev Stainless Steel Manifold (Coated by HPC )
MaxRev Stainless Steel 2.5" Downpipe (with flexpipe)
MaxRev Intercooler
TiAL 35mm WasteGate
Garett T3/T04E T-601 Turbo
Blitz FATT turbo timer
Blitz Dual SBC Spec R Boost Controller
Blitz SBC ID Power meter
AEM Hi-flow Fuel rail
AEM Fuel Filter
Aeromotive Fuel pressure regulator
Precision Turbo 78lbs Injectors
AEM EMS with Wide band O2
Bosch Hi pressure fuel pump
Fidanza 8lb Lightened Flywheel
Clutchnet 6 puck Sprung clutch
MSD blaster SS coil
Magnecore 8mm wires
3” exhaust with Apexi N1 (turbo application) Muffler
Maxrev Turbo Kit
MaxRev Intercooler
TiAL 35mm WasteGate
AEM Fuel Filter
MSD blaster SS coil
Magnecore 8mm wires
