Turbo question
Turbo question
I bought my civic off a guy who swears he didn't have it turbo'd. I don't really believe him because after looking a little closer at the car, there's a new exhaust manifold gasket, and steel braided line that looks like it could be an oil line, plus the car doesn't feel like it's timed correctly. When it's cool out the car runs great....but when it's too hot out the car really bogs down and feel extremely sluggish.
Does anybody have any idea what I could do to fix the problem?
Re: Turbo question (SOHCammed)
change the spark plugs. see wich ones are in there if you havent already. soundns like your running bkr7e in a NA car. those are mostly used in turbo setups.
Re: Turbo question (koa)
Well the guy might be telling you the truth, The oil line could be of a oil pressure guage that he remove and sold seperatly and the gasket could be that he remove the headers and put a stock manifold or remove the original manifold and put a header on the car, as well as the gasket could of had a leak and he replace it.
good luck....
good luck....
Re: Turbo question (madracer)
whats the oil line coming from? the back of the block or an oil filter sandwich plate...also what about the oil pan is it tapped?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by koa »</TD></TR><TR><TD CLASS="quote">change the spark plugs. see wich ones are in there if you havent already. soundns like your running bkr7e in a NA car. those are mostly used in turbo setups.</TD></TR></TABLE>
I changed the spark plugs, wires and oil after I bought the car. I still haven't changed the distributor cap, or the timing belt. I will when I get the money, but the problem still exists. It is getting cooler so the problem isn't as apparent, but after driving any distance over 5 miles or so, at least enough to warm up the engine real good, the prob comes back.
Re: Turbo question (c1turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c1turbo »</TD></TR><TR><TD CLASS="quote">whats the oil line coming from? the back of the block or an oil filter sandwich plate...also what about the oil pan is it tapped?</TD></TR></TABLE>
It looks like it's coming from the back of the block. It's difficult to see where it ends, but it goes around the back and under the engine itself.
Best bet it to check if the oil pan is tapped. If the line is coming from the filter (small T like plate that splits the oil filter outlet into two) thats mostly used for an oil pressure gauge. Although if the oil pan is tapped and the line goes into there and is just blocked off...then chances are thats the oil return line thats used to connect to the turbo for cooling.
edit - boost the car up and tell us exactly where that line is connected to. If its the pan, then it was most-likely boosted.
Re: (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan »</TD></TR><TR><TD CLASS="quote">Also, check the timing using a timing light. Some people retard overall timing for safety when they are turbocharged.</TD></TR></TABLE>
I want to do that but I don't know how, and I've seemed to have lost my Hanes manual, and all I have left is my big Chilton's Import guide.
diet rite
12-22-2005 06:26 PM
