Turbo Kit on stock D16A6
Old 05-14-2009, 06:56 PM
SquirtleSquadEf9's Avatar
Default Turbo Kit on stock D16A6
hey wats up guys. i have a bone stock 89 civic Si. the motor has 150 compression on each cylinder. so the motor is in perfect condition. My question is how much power can i get from a stock motor with a Turbo kit on it? And wat are the pros and cons of puting a turbo kit on a stock Si motor. thanks for the help
Old 05-14-2009, 07:04 PM
Reject Papi
jhammond_82's Avatar
Default Re: Turbo Kit on stock D16A6
i think the d series can squeeze somewhere around 220 or so, but don't quote me on that. if you build it, THEN you can really push some good numbers.
Old 05-14-2009, 07:12 PM
not to bad. would i need any other parts other than the turbo kit? will the engine be able to handle the turbo? and would it run ok with out a tune?
Old 05-14-2009, 07:21 PM
93formula's Avatar
LOL^^^^
do some research on turbod16.com
Old 05-14-2009, 07:27 PM
Radim's Avatar
D15s/d16s don't have very good connecting rods, so anything over 200HP will be a little unsafe though it is possible to reach 200-230 on stock rods.
Old 05-14-2009, 07:30 PM
well yea all im looking for is 160 to 200 hp its not like i think im going to get 500hp out of a stock single cam
Old 05-14-2009, 07:40 PM
D16SiHatch's Avatar
i know this is for a b-series engine but it will give you a fairly complete list of what you will end up needing if you boost your car.
https://honda-tech.com/forums/forced-induction-16/complete-how-turbocharge-your-honda-rep-ing-hypnotik-speed-1263795/
Old 05-14-2009, 07:45 PM
thanks man. ^^^ its cause im buying another stock d16a6 for 100 bucks and i wanna put a turbo kit on it. but i want to keep my car as stock as possible so i can swap it out when ever i want.
Old 05-14-2009, 08:21 PM
Reject Papi
i actually just bookmarked that ht link a little earlier today. good info in there. and you can drive it without a tune. just don't get into the boost.
Old 05-14-2009, 08:36 PM
thanks so a turbo kit on a stock d16a6 would be ok if i get a tune right?
Old 05-14-2009, 08:45 PM
Reject Papi
yuppers! just make sure you DO get it tuned. we don't wanna read a "boosted my car and now i have a hole in my block" thread.
Old 05-14-2009, 08:47 PM
D16SiHatch's Avatar
yep, that certainly would be advised lol
Old 05-14-2009, 09:29 PM
Vietnamese!
ALLxMOTOR EG's Avatar
Tune it
Old 05-14-2009, 09:43 PM
Fo-Do Fanatic's Avatar
if you do not tune you car when you end up putting a turbo on it you will run super lean when you start getting into boost thus you will likely spin a bearing or worse, toss a rod.
what psi you run really doesn't matter it's about it matters about horspower. just get your car tuned to around 180ish whp and have it tuned more on the rich side for added security. and please for god sake dont boost everywhere just to hear your damned blow off valve.
Old 05-15-2009, 03:21 AM
alright thanks for the info =] last question turbo kits usually come with the t3/t4 turbo would it be better for me to go with a SMALLER TURBO since im running a SINGLE cam and i dont want that much lag at low RPMS???
Old 05-15-2009, 04:34 AM
Reject Papi
t3, or a t3/t4 would be a decent size. go to the forced induction forum, and there is a thread on turbo sizing there.
Old 05-15-2009, 06:22 AM
redlinetuning's Avatar
It's funny(and annoying), this place (h-t) is becoming more and more common with lazy people not wanting to do their own research, using the site a as a learning resource. Expecting to get information spoon-fed to them and expecting to have a fast, reliable, and/or cheap build.
Everyday there's threads like this... even though there's been thousands before like it. The search function works better than before, so why does the site offer it if people don't even use it? IDK.
I know my post is irrelevant to your questions, but please do use the search function. That's why the site is broken up in to specific sections.
Old 05-15-2009, 09:03 AM
^^^^^ to the guy above ive tried the search function and it doesnt work for SH*T u type in one thing a whole bunch of other crap comes up. o and if u read on top of the web site it says HONDA-TECH and right under it, it says HONDA AND ACURA RESOURCE so GTFO
Old 05-15-2009, 10:03 AM
thumbs down to you dude. Honda-tech isn't what it used to be. I was going to say that your general questions have been answered over and over. All it takes is a little time to search in the right sections for answers. Turbocharging ANY motor, whether it's Honda, Chrysler, FORD, whatever it is, will have PROS and CONS. Horsepower output has many variables, boost level, turbo size, injector rates, engine condition, tuner experience, etc. There is NO definite answer to any type of vague question like that.
Old 05-15-2009, 11:12 AM
yea i know and i was asking wat the pros and cons could be
Old 07-07-2009, 04:00 PM
chemik's Avatar
go to turbod16.com for your answeres dude, and if you cant find something on HT then youre not looking right
Old 05-09-2012, 03:07 PM
jdavis94teg's Avatar
X2 >
Old 05-09-2012, 03:54 PM
nealnanoHX's Avatar
1. Get a good turbo kit nothing from Ebay. A Garrett Super 60 or 50 trim .48 AR will be fun turbos and meat your goals. OR last the least a Ebay kit with cast mani, real Tial waste gate, a real quality BOV and a real turbo like the ones mentioned. You can also get a CRX HF exhaust manifold and turbo adapter.
2. You will need larger injectors, DSM 450cc will be fine
3. A 255lph fuel pump is a very good idea or al least a new OEM pump.
4. You will need a better clutch than stock. A stage 2 will be plenty.
5. A OBD1 conversion and a way to tune like Hondata, Neptune or Crome and a good tune on the dyno.
All are needed for a good reliable turbo setup. If you dont have $1500-2000 to spend on a simple low budget turbo kit then dont waste your time or money.
Old 05-10-2012, 11:51 AM
wmac's Avatar
lol, this thread is from 2009.
and turbod16.com has been gone for a couple of years...
Old 05-10-2012, 04:47 PM
peardrax's Avatar
^^^ Yeah, was a good site when I needed it though
marvin75
05-14-2014 03:50 PM
gregory
12
01-09-2007 09:16 AM
firstclassjdm
11-12-2005 05:59 PM
oMek
08-01-2003 01:17 AM
Phoenix GSR
03-24-2002 06:58 PM
Quick Reply: Turbo Kit on stock D16A6
