Turbo GSR cutting out - Honda-Tech
Old 10-11-2007, 08:44 PM   #1
I serve phở for my babies
ohsnapzafingcu's Avatar
Default Turbo GSR cutting out
This is the second turbo kit my friend has put on his car..
at around 7,000 rpm and 7,500 rpm it cuts out really bad and it won't let the motor rev higher.. we thought it was the plug gap but it turns out it wasn't.. the gap is at 0.032 right now and we started from a 0.038. and it doesn't feel any different
we know the motor is getting enough fuel because when we let off it has a nice backfire..
any suggestions or help would be appriciated
ohsnapzafingcu is offline   Reply With Quote
Old 10-11-2007, 08:45 PM   #2
toekneexD's Avatar
Default Re: Turbo GSR cutting out (ohsnapzafingcu)
bump for my car =/ and gap is at .03
ive been told maybe its my rotor bug? someone please confirm this.
toekneexD is offline   Reply With Quote
Old 10-11-2007, 09:49 PM   #3
japan4racing's Avatar
gap them at .028 and make sure you have good wires. if the plug wires are failing you are not prividing strong spark adn you are spark knocking. rotor button could be it too. just start checking everything in the ignition system. do you have a msd or anything on this car? you ned to check rotor, cap, plug wires, coil and ignitor. also is this car tuned???
japan4racing is offline   Reply With Quote
Old 10-11-2007, 10:03 PM   #4
i ♥ snails
quicksilver1689's Avatar
i would just get new rotor, clean the cap, new plug wires just for good measure, its always good to keep the ignition system in top shape when running higher cylinder pressures.
quicksilver1689 is offline   Reply With Quote
Old 10-11-2007, 10:08 PM   #5
toekneexD's Avatar
Default Re: (quicksilver1689)
the car is on a s300 hondata base map.i think ill try to do the rotor bug first then wires after that.. thanks for input bump for more
Old 10-11-2007, 10:22 PM   #6
ignition is super important when boosting. def do the ignition tune up quicksilver mentioned and get that car tuned before you blow it!
Old 10-11-2007, 10:29 PM   #7
jdmhondacrx's Avatar
Default Re: (japan4racing)
dude i had the same problem but first what is ur motor set up and turbo set up plz
jdmhondacrx is offline   Reply With Quote
Old 10-12-2007, 05:28 AM   #8
turbo-crx's Avatar
i dont understand how you can even get on the motor with a basemap? when i had my basemap in before my tune the car wouldnt rev over 5500 and it didnt build any boost
turbo-crx is offline   Reply With Quote
Old 10-12-2007, 06:16 AM   #9
HarfordCTR's Avatar
Default Re: Turbo GSR cutting out (turbo-crx)
why are you at 7500 rpm's on a basemap? U want to blow it up?
HarfordCTR is offline   Reply With Quote
Old 10-12-2007, 08:53 AM   #10
2s1owsi's Avatar
Check your timing, it might be off. I had the same problem in my b16 turbo, and my timing was off and at high rpm's it will cut off just like your case
2s1owsi is offline   Reply With Quote
Old 10-12-2007, 09:09 AM   #11
jmm96gsr's Avatar
Default Re: Turbo GSR cutting out (HarfordCTR)
jmm96gsr is offline   Reply With Quote
Old 10-12-2007, 12:49 PM   #12
u n v kenny's Avatar
Default Re: Turbo GSR cutting out (toekneexD)
Are the injectors big enough?
u n v kenny is offline   Reply With Quote
Old 10-12-2007, 01:17 PM   #13
B18c1turboedEK's Avatar
Default Re: Turbo GSR cutting out (u n v kenny)
check the TPS sensor. we had the same problem and it was the TPS
B18c1turboedEK is offline   Reply With Quote
Old 10-12-2007, 09:38 PM   #14
D@nnY's Avatar
Default Re: (toekneexD)
Quote:
thats not the way you check air fuel...the car needs to be tuned
D@nnY is offline   Reply With Quote
Old 10-12-2007, 09:48 PM   #15
boostedh22lude1's Avatar
Default Re: (D@nnY)
sounds like a timing issue, but could also be a map problem what map and setup are you useing?
boostedh22lude1 is offline   Reply With Quote
Old 10-12-2007, 10:36 PM   #16
Default Re: (boostedh22lude1)
Quote:
b16 with greddy turbo kit, the motor has more then enough fuel. and i believe the basemap is better then a FMU..
we ran the same map on a previous boost setup and it worked flawless to 8 grand. now we can't seem to get past 7,500... we'll double check all the ignition this weekend.. thanks for the bump guys!
Old 10-13-2007, 04:05 AM   #17
D@nnY's Avatar
Default Re: (ohsnapzafingcu)
having more then enough fuel is also a problem. the car isnt tuned. you dont know what the air fuel is you dont know what the ignition timing is. you should really check these major things before you ask for help
Old 10-15-2007, 08:36 PM   #18
Default Re: (D@nnY)
Quote:
so we hooked up a wideband and the a/f is 11:5-12:5 from vtec all the way up to 7,500. then it cuts out. after tightning the gap down the 0.030 it didn't even seen to help. what other things could be the problem? it's not the rotor bug, cuz we replaced it
Old 10-15-2007, 08:50 PM   #19
high_octane's Avatar
this might sound dumb but it happen to me, i left my boost cut on a lower psi an forgot about it check that...
high_octane is offline   Reply With Quote
Old 10-19-2007, 06:35 PM   #20
toekneexD's Avatar
Default Re: (high_octane)
well i got the car tuned. and the car continued to do it.. today i got my exhaust(apexi ws2 piping w/ s2k exhaust) completely on (car was open downpipe before) and now it doesnt cut out anymore. any reason?
Old 10-19-2007, 09:02 PM   #21
werd^^^.. i bet noone would've guessed that..
Old 10-20-2007, 05:03 AM   #22
D@nnY's Avatar
if you have exhaust dumping under the engine bay it will be pushed back up the firewall and be sucked into the motor.....if its open downpipe it needs to go pretty far back
Old 10-20-2007, 10:22 AM   #23
Default Re: (D@nnY)
ooo. good point. cuz alot of the smoke got inside the car when it was windy out
TR3030R GSR, now with 512whp! 1158 Forced Induction 488 06-03-2016 07:33 PM
Ls/v cutting out at 7800rpm. Please help! zpayne21 Forced Induction 79 12-14-2015 04:53 PM
EK4 idle trouble after setting vavle clearance chrisbigmouth Honda Civic / Del Sol (1992 - 2000) 3 07-20-2007 11:25 AM
Car sputters after 5K on WOT, what could it be? drintegra Forced Induction 43 05-22-2006 06:26 AM
spark plug gap for turbo d16a1 staticchmbr Forced Induction 11 01-14-2006 08:29 AM
Tags
5500, 7000, b16, boost, crx, cut, cuts, cutting, engine, gsr, high, honda, rpm, rpms, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
