Is this true?????....H22 and pistons?????
Old 05-01-2002, 08:44 AM
Smurfylude's Avatar
Default Is this true?????....H22 and pistons?????
I was told by JE that when replacing pistons in an H series motor the block must be bored out and resleved before dropping in any type of piston.... Is this true? Or can I just hone the block? Please someone tell me that I do not need to take the motor out and have it bored and sleved.......I dont have the $$$$ right now to do that......
[Modified by Sushi X, 11:44 AM 5/1/2002]
Old 05-01-2002, 08:47 AM
b18bturbo's Avatar
Default Re: Is this true?????....H22 and pistons????? (Sushi X)
you can just have it honed no need to bore it and all that stuff. If you cyl walls are okay you should be okay then.
Old 05-01-2002, 09:07 AM
bgod's Avatar
Default Re: Is this true?????....H22 and pistons????? (b18bturbo)
can't use forged pistons with stock sleeves in an h22a.
Old 05-01-2002, 09:09 AM
PrecisionH23a's Avatar
the cylinder walls in preludes are made from fiber re-enforced material. you cannot hone or bore these cylinders at all. you have to resleever your block if you are looking to run aftermarket pistons. so yes, JE was correct. It sucks, but then again once you resleeve you virtually have a bullet proof block
Old 05-01-2002, 09:16 AM
Smurfylude's Avatar
Default Re: Is this true?????....H22 and pistons????? (GudeH23a)
That sucks Thanks for the help guys....
Old 05-01-2002, 09:28 AM
no problemo. resleeving your block will cost you right around 1000 after everything has been said and done. Darton does a badddddddd *** job, so does golden eagle.
Old 05-01-2002, 09:45 AM
Smurfylude's Avatar
I can get Darton sleeves for about $500 and have my machine shop bore hone and deck my block for $200. Or I could go with Goledn Eagle and ship the block to them have it done $825+$125 for bore and Hone....Then ship it back for $50. The only thing is. It'll take 1 month for turn around at the GE and my guy could probably do it in a week. What do you guys think? Also, will going 88mm from the stock 87mm bore make a difference?
Old 05-01-2002, 09:52 AM
b18bturbo's Avatar
Not exactly true. You can slap set of 87mm stock bore pistons back in and you should be fine. its only when you got to forged setup that you see issues.
Old 05-01-2002, 09:56 AM
Smurfylude's Avatar
I am getting a set of forged JE pistons...so I guess I am SOL either way....
Old 05-01-2002, 02:26 PM
The Punisher's Avatar
Ok, this is the beaten to death topic. I lost the link that I read this info from (And I talked to a buddy that is an ASE honda Tech, and really knows his ****!), but the sleeve walls are aluminium. Then there is the FRM. This liner is a hardened material that keeps aluminium from rubbing against aluminium. The liner is .5 mm thick. You can safely hone to .25 mm, so that is why the Type S pistons that are .2 mm over stock will work in an un-sleeved block. That is why any piston will work in an unsleeved block as long as the FRM is not honed over .25 mm. If anyone is looking for the GE sleeves, I am sponsoring a GB for them in the FI section. Price for the Lude is $644 + $17.50 for tax. Bore and Hone is $125 Extra and the pistons need to be included. I am also sponsoring a JE GB for 87 mm and 87.5 mm pistons for $495.
[Modified by gsr*lude, 6:27 PM 5/1/2002]
[Modified by gsr*lude, 6:29 PM 5/1/2002]
Old 05-01-2002, 04:39 PM
Yes thats true, my bad.
Danial Gooch
Engine Machining & Assembly
03-20-2018 08:40 PM
MyVtec8yourV8
08-29-2004 10:34 AM
Performance-Online
10-06-2003 06:15 AM
v4lu3s
05-30-2003 02:09 PM
p10hlm
01-07-2003 11:25 PM
Quick Reply: Is this true?????....H22 and pistons?????
