Tranny & Head bolt thread pitch and size.
Anyone know the specs of the headbolts as well as the exhaust manifold bolts?
I believe the headbolts are 15x1.5 thread pitch.
The exhaust bolts are 8x1.25
Anyone know the tranny bolt specs. I wanna purchase some more bolts for my engine stand.
Please Correct me if I am wrong on the above specs.
Thanks!
Thanks!
Re: Tranny & Head bolt thread pitch and size. (BodyKits NW)
For the tranny bolt. I believe it's m12x1.25 and should be about 60mm in length?
Do you need lengths too? I've got an engine on the stand right now I can measure later on tonight for lengths.
The thread size/pitch for the tranny is M12x1.25. The odd thing is that I can't find a tap for that fine of a thread in that bolt size.
Head bolts are M11x1.5. You can look up the length on Acura Carland's site.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BodyKits NW »</TD></TR><TR><TD CLASS="quote">For the tranny bolt. I believe it's m12x1.25 and should be about 60mm in length?</TD></TR></TABLE>
If you're using the bolts for mounting the engine to the stand, they need to be longer than 60mm I believe. The length depends on how deep the arms are on the tetrapus.
Re: Tranny & Head bolt thread pitch and size. (IN VTEC)
The only tap I really need is for the headbolts, and the exhaust manifold. I was installing my full-race manifold and screwed up 1 of the threads. So I am going to chase all the exhaust manifold bolts.
I think I did get a M11x1.5. I am not sure how I got M15. Glad I posted on here. I am going to use that to chase the threads before I install my ARP headbolts.
If you can get me lengths for the engine stand that would be great.
I think the bolts I used were 65mm or 70mm for the two top holes. They came from the misc. Honda bolts bin that I have. The ones I bought from the store didn't seem to want to thread.
For the lower holes, I used either 7/16" or 1/2" bolts x 4.5" length with some washers and a corresponding nut to secure it. 1/2" sounds more like it than 7/16" b/c the holes accomodate 12mm bolts.
I was not able to find a store tonight that had the m12 in 1.25 thread pitch. I'll have to do some more searching tomorrow.
Pepboys might have a 65-70mm bolt.
I always get them from the local hardware store. The ones with the Ace Hardware bags.
