Tial wastegate spring set at 7psi, why is my car running 10?
well i just put my turbo kit on my car, and i recently bought a tial 38mm wastegate for it. i bought a 7lb spring and forsome reason my car is running ten daily. Thats what my boost gauge is reading. does anyone know what might be the problem. on top of my tial wastegate where the boost controller goes, i left it open because i don't have one. and many on H-t says its ok to run it open if i didn't have one. or is it even a problem with my wastegate?
Re: Tial wastegate spring set at 7psi, why is my car running 10? (LilCivic04)
are you sure the spring is a 7lb spring? Like have you taken it apart and found out? you dont have a mbc on the vac line that is connected to the side of the wastegate? Where are you taking your vac source from? Same place as the boost guage?
well i got a drag manifold w/ turbonetics turbo. there are two ports for the tial, the one on the side just T is to any vacuum after the throttle body and the top one i just left it open.
for boost i just T it off just some vacuum after the throttle body also
i think the spring is only the limit you can not go under so if you have a seven pound spring then you can not boost under seven pounds
Who is Mr Robot?
Re: Tial wastegate spring set at 7psi, why is my car running 10? (no-vtec94)
its probably just the drag mani, theyve been know to creep a few pounds
Re: Tial wastegate spring set at 7psi, why is my car running 10? (wantboost)
Make sure that you are looking at the spec sheet correctly. 10 pounds is equal to .7 bar. Open the wastegate if it is a big red that is the .7 bar or 10.15 pound.
Jason
Jason
Who is Mr Robot?
Re: Tial wastegate spring set at 7psi, why is my car running 10? (SFWD 1934)
^good point. you might have thought the ordering sheet said 7 psi, sure it wasnt .7 bar?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">^good point. you might have thought the ordering sheet said 7 psi, sure it wasnt .7 bar?</TD></TR></TABLE>
