Tial Wastegate Not Opening
I purchased a tial wastegate (38mm) 2 months ago and all was fine. I ran 7 psi. Then i installed exhaust wrap, reinstalled my turbo manifold, and reinstalled the wastegate, and my wastegate now dosent seem to be opening. I was driving and accidentally went above 12psi. I checked all the lines, and i just dont know how it could have broken. All i can think of is when i installed the wrap, the wrap smoked like crazy, and maybe the heat busted the spring. PLease give me your input. Thanks
Re: (b16turbosi)
make sure you hooked up your vacuum line to the side of the wastegate and that it has a good source of vaccum like brake booster or something strong hope that helps out
Re: (primeredbeast)
i just went out to double check the settings, and everything, the only thing i think it could be is the boost controller. Do wastegates really break this easily, and what would cause the spring to bust/warp
Re: (b16turbosi)
take the boost controller out and just run straight vacuum to the wg that will tell you whether or not it is the boost controller or not
Re: Tial Wastegate Not Opening (b16turbosi)
You can easily check it for smooth operation if you have a handheld vacuum pump.
If not any local mechanic should have one.
Ive seen this problem before...and it turned out to be the electronic boost controller....post i read a while back, his boost kept riseing when everything checked ok.
Re: Tial Wastegate Not Opening (itslogics)
what knid of turbo is it? i hope its not a big crappy t3/t4 turbonetics crap . j/k its luc. if u said the guy at pizza hut could help ask him and then if it is still messed up then buy another. when i was lookin for ur fourm i saw a post that was titled rear located turbo kit or somethin like that it was crazy lookin. peace
Be sure you didn't swap your side and top fittings on your tial. I know on mine if they are hooked up backwards the BC won't control boost at all. HTH
Re: Tial Wastegate Not Opening (RacerXI)
Henry i am a friend of Shaz (the kid u met at pizza hut) do u know when the stl honda-tech meeting is?
shaz i burnt the crap out of my face at work sunday morning. thats why i havent been at school the past 2 days.
we set the BC up right. i think that it is something internal but not the spring. this is the second wastegate we have gone through on the car.
Re: Tial Wastegate Not Opening (h22aturbolude)
ok never mind on the h-t meeting i found it. i was wondering if trial H-T members can show up(even though i have a celica i wish i had a honda).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22aturbolude »</TD></TR><TR><TD CLASS="quote">ok never mind on the h-t meeting i found it. i was wondering if trial H-T members can show up(even though i have a celica i wish i had a honda). </TD></TR></TABLE>
did u change the spring in the wasdtegate? maybe you didnt put the wastgate together properly example pinched the diaphram
How long are they though. if the lines are too long that can cause a problem.
Also did you put the ring in the wastegate in when installing it?
