For those of you using TunerToys oil pressure sender fitting...
Old 03-23-2007, 10:36 PM
GetawayInMoscow's Avatar
Default For those of you using TunerToys oil pressure sender fitting...
How tight did you tighten that thing into the block? It says 13 ft/lbs in the instructions but I can't get my torque wrench in there.
I have it hand tight right now, I mean I tightened the **** out of it with my hands but I can still move it easily with a wrench. I would tighten it another revolution but Im worried of cracking something...
Old 03-23-2007, 11:00 PM
V-SPEC 1's Avatar
Default Re: For those of you using TunerToys oil pressure sender fitting... (GetawayInMoscow)
I've tried to use torque wrench and torque it to 13 ft. lbs and the end of it broked . Don't torque it down, just tighten it w/o the using torque wrench until it gets tight to the feel. IF you know what I mean. NO problem doing it this way.
Old 03-23-2007, 11:01 PM
A.E Motoring's Avatar
Default Re: For those of you using TunerToys oil pressure sender fitting... (V-SPEC 1)
yea same here, just make sure u use teflon tape. just tighten till it gets some wat snugg and stop there
Old 03-24-2007, 12:20 AM
sohc_turd's Avatar
Default Re: For those of you using TunerToys oil pressure sender fitting... (Dual Cam Racing)
Teflon and snug it up!
Old 03-24-2007, 12:42 AM
HiProfile's Avatar
Default Re: For those of you using TunerToys oil pressure sender fitting... (sohc_turd)
Wrap it a few times with teflon, but do not let the tape go beyond the threads (farther into the block than the fitting). Then get it fairly snug, then fire it up. If it leaks, give it a quarter turn. Let it weep a bit if it still does, let cool, then 1/4 turn again.
The key is to put as little stress on the threads as you can, as the fitting's weight is already enough to crack the block if you hit a good sized bump/pot hole.
Old 03-24-2007, 09:20 AM
Default Re: For those of you using TunerToys oil pressure sender fitting... (HiProfile)
Okay well I only have it half threaded in right now, so does that mean I should tighten in more?
Old 03-24-2007, 12:39 PM
V-SPEC 1's Avatar
screw it in until it get snug and stop.
ninjaturtleEG
11-23-2011 03:18 PM
Suzukii
12-01-2006 06:34 PM
743power
05-31-2004 11:07 PM
Smith Wise
04-15-2003 04:02 PM
Anderson
05-09-2002 06:54 AM
Quick Reply: For those of you using TunerToys oil pressure sender fitting...
