Test pipe or high flow cat (Turbo b18b) - Honda-Tech
Old 01-04-2009, 08:49 AM   #1
typexero's Avatar
Default Test pipe or high flow cat (Turbo b18b)
I took my car to the dyno for tuning and with 9 psi I got a maximum of 200 whp and 177 tq. However, the torque is 177 lb-ft at 5000 rpm and goes all the way down to 120 lb-ft at 8100 rpm. My question is: is my high flow cat the cause of the dramatic loss of torque? Do you guys think it's worth putting a test pipe in instead?
typexero is offline   Reply With Quote
Old 01-04-2009, 10:47 AM   #2
Default Re: Test pipe or high flow cat (Turbo b18b)
Give us every detail of your setup.
I.e. turbo manifold, turbo size, intercooler piping size, intercooler size, downpipe size, exhaust size.
Post a dyno sheet too....
mtber is offline   Reply With Quote
Old 01-04-2009, 11:35 AM   #3
typexero's Avatar
The turbo manifold is a log manifold from Spoolin performance. The turbo is a GT2871R with 0.63 AR. The intercooler piping is 2.5". The downpipe is 2.5" and the exhaust is 2.5". I don't have the dyno sheet. I'll post it if I can find it.
Old 01-04-2009, 11:46 AM   #4
street_ride14's Avatar
You bring a great example of how log manifolds hurt performance in all rpm ranges exp in higher rpm'. Post a dyno sheet if available. I blame your log manifold for the tremendous drop in torque at the end of your powerband.
street_ride14 is offline   Reply With Quote
Old 01-04-2009, 12:00 PM   #5
Silva Bullit DC4's Avatar
Mine falls off like crazy, too. My numbers are in my sig, but I have that same mani and DP. Time for a ramhorn!
Silva Bullit DC4 is offline   Reply With Quote
Old 01-04-2009, 12:26 PM   #6
typexero's Avatar
Thanks for all of your input. My tuner also said the log manifold may be the culprit. Just wanted to make sure.
Torque/HP RSX Type-S vs. regular RusBear Acura RSX DC5 & Honda Civic EP3 15 03-13-2005 06:35 PM
How much do I torque the bolts for the Front Strut Tower Bar? HapiHonda Honda Civic / Del Sol (1992 - 2000) 3 11-23-2002 10:02 PM
B20Z dyno results StorminMatt Honda CRX / EF Civic (1988 - 1991) 44 08-22-2002 07:08 PM
The Frankenstein Project_SOHC_EX Tech / Misc 2 05-03-2002 06:51 PM
Yesterday's dyno run summary IN VTEC Acura Integra 5 02-03-2002 05:52 PM
Tags
01, b18, b18b, cat, dyno, exhaust, flow, high, honda, integra, ls, manley, pipe, racing, sheet, size, test, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
