spoolin performance log manifold
Old 04-11-2010, 05:57 PM
Luke G.'s Avatar
Default spoolin performance log manifold
im looking at buying a spoolin performance log manifold for my gsr engine as well as 3" downpipe and 3" exhaust. I will be using a .60 trim Garrett turbo built by The Shodan and looking to make around 350whp. This will be a DD street car. Is this manifold a good choice?
Old 04-11-2010, 06:06 PM
boostedEF91's Avatar
Default Re: spoolin performance log manifold
For driving alot on the street and for a DD yes its a good choice. will never crack or have to worry about it. for 350whp its a decent choice. anything more i'd go with a mini ram or ramhorn.
Old 04-11-2010, 06:09 PM
Luke G.'s Avatar
Yea, 350 is as high as i want to go, anywhere from like 330-350 is what im looking at making
Old 04-11-2010, 06:13 PM
sanman000719's Avatar
wow man ill tell ya log manifolds dont get much love on here, but I have been trying to get people to realize you dont need a 800 dollar ramhor or 1000 dollar topmount to make power.
I run the pfab log manifold with a t3/66 turbonetics and made 589hp with it @28psi.
turbo is now bad, and just bought the new billet 67/65 and will run it on the log also just to prove more of a point.
the log is a good manifold man just need to be carefully who you buy it from because quality means alot.
Old 04-11-2010, 06:15 PM
Luke G.'s Avatar
yea i know, i trust spoolin pretty well, ive bought from them in the past.
Old 04-11-2010, 06:17 PM
sweet man well then sounds like you know what you want so go get it lol
Old 04-11-2010, 06:41 PM
90dxhmt's Avatar
A log manifold is generally more reliable and all you need for sub 500hp. Don't listen to the hype.
Old 04-11-2010, 09:18 PM
miguel329's Avatar
yea phil at spoolin is a good guy too... def a+ product...
Old 04-12-2010, 05:59 AM
Silva Bullit DC4's Avatar
You'll be fine with the Spoolin log at that whp.
I have had two mani/DP combos from Phil @ Spoolin, a log combo & an A-spec combo, and the quality & fitment was top notch. I ran a Bullseye 50 trim t3/t04B with the log, and it was a super fun setup, the combination of the log mani & the size of the turbo made it a spooling machine, 301 whp @ 14 psi on a bone stock LS, seeing maximum pressure (spool) by 3800 rpm!
Old 04-12-2010, 11:39 AM
Kyle R's Avatar
Old 04-12-2010, 04:46 PM
Luke G.'s Avatar
alright thanks for the replies. I'll be buying the stuff soon.
Old 04-12-2010, 07:37 PM
Mr.Spec's Avatar
you should email him on the website because they're currently moving facilities its difficult to get to the phones
Old 04-12-2010, 08:10 PM
Mr. Em1's Avatar
spoolin performance makes a good product and for what you are looking to go for should be great. Having a log manifold will help to spool up the turbo quicker than most other style manifolds and will help you creating a more street friendly powerband. good luck!
Old 08-20-2010, 09:04 AM
4dvti's Avatar
now that's got me excited! I've got the sp log manifold on a built b16 motor and i have a new garrett t3/t4 50 trim turbo. hoping for 350 to 400bhp fingers crossed.
Old 08-20-2010, 12:04 PM
Retired Moderator
EsotericImage's Avatar
The reason they dont get much love is they suck at flow past 6000 rpms.. yea, they might do the job, but in the upper rpm range, you want a better flow. A ram horn or mini ram will solve this.
I use a log on my b20 cuz im not revving much past 6k.
OP: if its going on a GSR, look into a better flowing manifold.
EDIT:
Spoolins manifold are welded better than others ive bought which failed. Im not going to mention the company, but Phil at Spoolin should hook you up.
Old 08-20-2010, 12:17 PM
boostedeg302's Avatar
great for your goals and I would go with that manifold any day of the week
Old 08-21-2010, 06:13 AM
CDecker0218's Avatar
Couldnt agree with you more. Fast shipping, great fab work + customer service (even if he is a tool ) = top notch! My next manifold choice will be from Spoolin!
Old 01-02-2011, 02:40 PM
SweetTeg's Avatar
i beg to differ. i'm under 300whp and here's what i found today.
Old 01-02-2011, 02:49 PM
1904wrencher's Avatar
Is there any warranty's on their parts... try and send it back and hope they send it welded back...
Old 01-02-2011, 02:54 PM
pauld's Avatar
I dont think your power level had anything to do with that. Is your dump tube is merged into your downpipe, without a flex section?
2k.civic.si's Avatar
well at least the welds didnt crack =P
Old 01-02-2011, 04:07 PM
SweetTeg's Avatar
yes, but only 1 year. i bought it from someone.. it sat in a room for 95% of it's life.. may not be eligible
nope, open atmosphere dump tube(goes to about level with bottom of oil pan).
lolololol
Old 01-03-2011, 07:56 AM
MantisX's Avatar
Mine did that in the picture too. I just had my local shop weld it back up and its been fine since. It also developed small hairline cracks in the runners but I believe those are my fault as the exhaust under my car sometimes hits speedbumps and what not. Ive had the manifold for over 4 years now though so im happy.
MantisX
Old 01-27-2011, 12:13 PM
racebum's Avatar
not to bump a near month old thread but that's a SUPER easy fix. best bet imo is to look up a welding shop in your area and have them do it. why this and not an exhaust shop? generally a real welding outfit will have a TIG which that appears to have been done with in the first place, they also will grind the carbon out of the inside around the area to be welded so it doesn't pop while welding.
sohczcturbo
09-11-2007 09:51 PM
jerbear!
10-18-2004 10:34 AM
donpeters
05-26-2004 09:53 PM
Quick Reply: spoolin performance log manifold
