spark plug gap for turbo d16a1
i was wondering if anyone knows what the spark plug gap should be on a turbo d16a1. i will be running about 6-7 psi on it. this is the dohc d series out of an 89 integra.
if you dont know the gap on this motor, what is the average gap change for any car?
Re: spark plug gap for turbo d16a1 (staticchmbr)
id run a .42 gap, and also dont run normal d16a1 plugs, ur gonna need at least three stages colder or ur gonna mess up those plugs in no time
dude dont listen to the newby^^^. run 1 step colder plugs than the original and gap them to .32. .42 is way too big and might get blown out and cause misfires.
Re: spark plug gap for turbo d16a1 (xxxmonoxidechild)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxxmonoxidechild »</TD></TR><TR><TD CLASS="quote">id run a .42 gap, and also dont run normal d16a1 plugs, ur gonna need at least three stages colder or ur gonna mess up those plugs in no time</TD></TR></TABLE>
You have no clue.
1 step colder start with an .032 gap.
Sorry, I am not sure what plugs are used in this engine.
You have no clue.
Re: spark plug gap for turbo d16a1 (Cee_mon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cee_mon »</TD></TR><TR><TD CLASS="quote"> NGK BRK7E gapped at .030.</TD></TR></TABLE>
Phil
Phil
Re: spark plug gap for turbo d16a1 (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 »</TD></TR><TR><TD CLASS="quote">
Only gapped to .028 here </TD></TR></TABLE>
I called "DRAG TURBO KITS" and they recommend using that spark plug and to gap it .035..... this was for my set up and probably universal for all b series turbo set ups. SIR2 with DRAG turbo at 7psi
Re: spark plug gap for turbo d16a1 (eGeeHaTcH)
mine were gapped to .028 and i was having problems misfiring. Right now theyre at about .042 and my problem seems to be gone on turbo z6
