So You want to turbo your SOHC and want ideas about the numbers it will make - NEWBIE INFO
When I first started reading all the forums when I wanted to boost my d16 I had a gazillion questions about how fast certain parts would go. Eventually I find you gain a good skill of cutting through the bullshit and once and a while finding some relevant information.
So I wanted to put together a post of all the relevant setups that I can find and the power and 1/4 times they are putting down.
<FONT SIZE="12"><u>TurbodCX</u></FONT>
<FONT COLOR="green">Racing:</FONT>
60'......1.713
330......4.911
1/8......7.401
mph.....101.26
1000.....9.552
1/4.......11.31
mph......129.84
<FONT COLOR="blue">Setup:</FONT>
JDM SOHC Vtec
75mm bore 1.6L SOHC
The car is being run on precison 880cc injectors with a AEM 1040 EMS
8:1 arias pistons
Crower rods
GE sleeved block
Ferrea valve train
Zex 59300 cam
T3 Blowzilla turbo from cheapturbo.com with a .63 A/R
<FONT COLOR="red">Dyno:</FONT>
Dynoed @ 502Whp and 370WTQ @ 33 psi
<FONT SIZE="12"><u>USDM 4G VTEC</u></FONT>
N/a
D16Z6 SOHC VTEC
JE SRP 9.0:1 Forged Pistons 0.40 over (76mm)
Eagle H beam rods with ARP2000 bolts
COMP CAM 59300
JE piston rings
polished crank
OEM headgasket
D16Y8 intake manifold
3 angle valve job
head milled 0.1o thousands
mild port and polish
Block Bored 0.40 over and tapered 0.02
450 DSM injectors
MSD BTM
APEX VAFC
Edelbrock fuel rail
14B turbo
HF manifold
2.25" charge pipes
ebay BOV
Johny race car intercooler 30x5x2
My own CNC machined Adapter plate
My own made downpipe on 2.5" (still on my 2.25 crush bend exhaust )
VAFC Hack
180 whp & 162 wtq @ 9 psi (shitty tune)
<FONT SIZE="12"><u>BeerBongKicksAss</u></FONT>
13.5 @ 102 (slicks)
13.8 @ 99 (slicks) *blown cooling fan fuse so my car was overheating on this run*
13.4 @ 102 (slicks)
13.4 @ 105 (drag radials)
13.3 @ 102 (slicks)
13.9 @ 102 (drag radials)
14.0 @ 102 (drag radials)
95 Civic Coupe EX
Stock D16Z6
Custom turbo setup running 10 psi...
T3 60 trim .48/.60 turbo
Uberdata
DSM 450cc injectors
Custom Manifold
Johhnyracecar 5 inch tall IC
2.5 inch charge piping
2.5 inch custom downpipe
3 inch exhaust
ACT xtss clutch
Quaife LSD
216hp/181tq @ 9-10 PSI (Self Tuned)
230whp/208wtq at 12psi
<FONT SIZE="12"><u>LadysMan</u></FONT>
N/A
Maxrev Manifold
2.5" Maxrev Downpipe
3" Exhaust
Maxrev Dumptube
Drag turbo intake kit
Revhard intercooler piping
PWR intercooler
Garrett T3/T4 .63ar 60 trim
HKS SSQV BLow Off Valve
800cc RC injectors
Hondata S200
2 slimline 12" Autozone fans.
262whp and 217wtq. @ 12.3xx psi
<FONT SIZE="12"><u>SOHCvtec1995</u></FONT>
R/t 1.018
60' 2.279
330 6.432
1/8 9.956
mph 69.61
1000 12.995
1/4 15.546
mph 88.32
1.6 Sohc Vtec
Jdm 4-1 Header
CAI, With Aem Bypass Valve
Arospeed Ground wire Kit
OBX cam Gear (not adjusted yet)
AEM Alt Pulley
UR Crank Pulley
No PS (Removal kit purchased from Padwan)
Apexi N1 Exhuast
Test Pipe
Fully gutted interior
Short Shifter
Vis oem style CF Hood With Sparco Hood Pins
Battery Relocated to trunk
VAFC
OBX intake Manifold
N/A
<FONT SIZE="12"><u>FJT's Friend lol</u></FONT>
12.60 @ 109mph @ 16psi
D16Y7 Coupe
Stock ECU
Stock IM
AFC Hack
Car complete with a 260lbs driver.
Log Manifold
T3 turbine
2.5" downpipe and exhaust
Tial WG
Starion FMIC
Slicks
N/A
<FONT SIZE="12"><u>WONG FRIED RICE</u></FONT>
13.6 @ 114mph on street tires
88 crx si
d16y7/8 Ported, multi-angle valve job head
jg cam
thicker head gasket
stock bottom end
custom drag turbo kit
w/ turbonetics t3 turbo
custom IC piping
drag manifold
drag downpipe
test pipe, tanabe 2.5 in. catback
walbro 255lph fuel pump
b&m fpr
dsm 450cc inj.
act hd pressure plate, extreme disc
msd 6AL ignition
hondata s200 setup for boost, and tuned by frank from RACETUNE
boosted 11lbs daily
N/A
<FONT SIZE="12"><u>12sechatch</u></FONT>
12.5@111 slicks
95 ex motor
stock internals
thicker head gasket
fmax turbkit
N/A
<FONT SIZE="12"><u>TheShocker</u></FONT>
13.8@105 MPH
D16A6,
100% stock block
NON-VTEC
Super-T kit at 12 psi
Street tires (Azenis)
Full weight
Stock clutch
Hondata
DSM 450s
N/A
<FONT SIZE="12"><u>Phresh_5</u></FONT>
13.04 @ 103.42 MPH
D16Z6: Stock
DSM T25
STD Manifold
DSM 450's
DSM BOV
Custom dual core IC
2.5" straight exhaust
Uberdata Tuned by myself
205.2 WHP/ 196 TQ @ 10-11psi
<FONT SIZE="12"><u>RacerAge1</u></FONT>
60'------2.313
330-----6.253
1/8-----9.528
MPH----76.30
1000---12.326
1/4-----14.699
MPH----94.69
99 Civic EX Full Interior
15x6.5 rota slips on some crappy street tires(Doral?) @ 20psi
D16Y8
Greddy Turbo Kit
intercooled @ 6psi
blue box(untuned)
184.5WHP/170TQ @ 7psi
<FONT SIZE="12"><u>Bretxor</u></FONT>
13.7
-101mph
1998 Honda Civic HX
D16Y5
T25
HF manifold
Starion Intercooler
2.5" downpipe
Cartech FMU
Inline fuel pump
N/A
<FONT SIZE="12"><u>SteveOunce</u></FONT>
N/A
00' hatch
y7/y8 mini me boostin 7psi
stock internals
greddy 2mm headgasket
ihi rhb5 turbo
stock muffler and cat
hondata s200
170.2whp and 160.1tq
<FONT SIZE="12"><u>Name</u></FONT>
<FONT SIZE="12"><u>rrussell</u></FONT>
N/A
D16z6 built bottom end and head
T3/T4 54 trim .63AR
22psi and 70 shot
Haltech w/ 72lb. injectors
http://www.turbod16.com/album_pic.php?pic_id=2090
418whp 314wtq
<FONT SIZE="12"><u>Supreme1</u></FONT>
N/A
D16y8 forged internals
T3/T4 60-1 vtrim stg 3 .63exhuast
20psi
Hondata
DSM 450s
http://www.turbod16.com/album_pic.php?pic_id=2375
306whp 270wtq
<FONT SIZE="12"><u>BoostedED9</u></FONT>
N/A
D16z6 stock w/ thick headgasket
T3/T4
16.5psi
AFC hack
302whp 251wtq
<FONT SIZE="12"><u>boltz</u></FONT>
N/A
54 trim SC32 .63AR
~17psi
Hondata S200
287whp 219wtq
<FONT SIZE="12"><u>nate123</u></FONT>
N/A
D16z6 forged internals
T3/T4 .63
14-16psi
Hondata
RC550s
273whp 240wtq
<FONT SIZE="12"><u>ladysman</u></FONT>
N/A
D16z6 stock
T3/T4 .63AR 60 trim
12.5psi
Hondata
RC800s
262whp 217wtq
<FONT SIZE="12"><u>booscivic</u></FONT>
N/A
comp cam
t3/t04e 57 trim 63 a/r
15psi
Hondata
RC550s
259whp 225wtq
<FONT SIZE="12"><u>MADDOG2020</u></FONT>
N/A
Greddy kit
15psi
Hondata
RC440s
256whp 227wtq
<FONT SIZE="12"><u>92civicsi</u></FONT>
N/A
D16y8
Zex cam
Greddy kit
12psi
270cc
252.3whp 207.7wtq
<FONT SIZE="12"><u>gitwidit</u></FONT>
JRSC
10psi
Hondata
Nitrous Controls
RC440s
251whp 227wtq
<FONT SIZE="12"><u>MikeEXT</u></FONT>
N/A
Greddy kit
15psi
Hondata
RC440s
251whp 220.2wtq
<FONT SIZE="12"><u>beerbongskickass</u></FONT>
N/A
D16z6 stock
T3 .60/.48
11psi
Uberdata,
DSM 450s
230.13whp 206.11wtq
<FONT SIZE="12"><u>jamyam</u></FONT>
N/A
D16y8 stock
Greddy Kit w/ blue box
intank 255lph
12.5psi
225whp -- 204wtq
<FONT SIZE="12"><u>SleeperCivicEX (ScrappyDoo)</u></FONT>
N/A
D16Y8 stock
Greddy 15G
11psi
VAFC
RC440s
219whp 204wtq
<FONT SIZE="12"><u>peiku</u></FONT>
N/A
D16z6 w/ headwork
zex cam
Apexi kit
9psi
210whp 168wtq
<FONT SIZE="12"><u>CivicSoul</u></FONT>
N/A
D16y7 stock
T3 .60/.48
SMC dual
208.9whp 175.4wtq
<FONT SIZE="12"><u>Pfieff</u></FONT>
N/A
D16y7 stock
Greddy kit
12psi
Hondata
RC440s
205whp 216wtq
<FONT SIZE="12"><u>phresh_5</u></FONT>
N/A
D16z6 stock
T25
10-11psi
Uberdata
DSM450s
205whp 196wtq
<FONT SIZE="12"><u>h3avyarms</u></FONT>
N/A
D16y7 stock
T3 50 trim .48AR
10psi
AFC hack
DSM450s
202whp 207wtq
<FONT SIZE="12"><u>EG6turbo</u></FONT>
N/A
D15 stock
Greddy kit
10psi
FMU
intank pump
202.3whp 166.9wtq
<FONT SIZE="12"><u>Civicryda2k/M.A.R.C</u></FONT>
N/A
D16y8 stock
T3 .60/.48
8.5psi
AFC hack
intank
193.7whp 164.3wtq
<FONT SIZE="12"><u>BoostedEKHatch</u></FONT>
N/A
D16y8 stock
Greddy 15g
10psi
Greddy E-manage
RC440s
188.5whp 186.0wtq
<FONT SIZE="12"><u>****</u></FONT>
N/A
D15B stock
Greddy kit
11psi
Crome
450cc
188whp 159wtq
<FONT SIZE="12"><u>scttydb411</u></FONT>
N/A
D16y7 stock
TD04L
11psi
Uberdata
450cc
186whp 175wtq
<FONT SIZE="12"><u>Pollito</u></FONT>
N/A
D16y8 stock
T3 .42/.48
9psi
AFC hack
RC440s
186.6whp 170.1wtq
<FONT SIZE="12"><u>Quicksilver</u></FONT>
N/A
D16y8 stock
Greddy kit
8 psi
Blue box
184.5whp 170wtq
<FONT SIZE="12"><u>Rota92</u></FONT>
N/A
D16z6 stock
Apexi kit
7psi
AFC hack
RC440s
185.8whp 151.9wtq
<FONT SIZE="12"><u>Marauder</u></FONT>
N/A
D16y8 stock
Edelbrock kit
7psi
Edelbrock piggyback
178whp 148wtq
<FONT SIZE="12"><u>CSaddict</u></FONT>
N/A
D16y7 stock
T3 .42/.48
9.5psi
Uberdata
450cc
171.7whp 176.0wtq
<FONT SIZE="12"><u>JunkyardD16Z6</u></FONT>
N/A
D16z6 stock
Greddy kit
7.5psi
Emanage
171.5whp 160wtq
<FONT SIZE="12"><u>Weq</u></FONT>
N/A
D16z6 stock
Greddy kit
9psi
Greddy E-manage
RC440s
168whp
<FONT SIZE="12"><u>fishnfst</u></FONT>
N/A
D16y7 stock
Greddy kit
6psi
Hondata s200
340cc
163whp 158wtq
<FONT SIZE="12"><u>sohc_vtec 2NR</u></FONT>
N/A
D16y8 stock
Greddy 19T kit
~7psi
154whp 147wtq
<FONT SIZE="12"><u>mookvtec</u></FONT>
N/A
D16y8 stock
Greddy kit
5psi
AFC hack
RC440s
134.85whp 135.82wtq
<FONT SIZE="12"><u>VTC_Civic</u></FONT>
N/A
D16Y8
GReddy kit
217.7whp / 183wtq @ 10psi (Hondata)
164.4whp / 145wtq @5psi (Uberdata)
<FONT SIZE="12"><u>ELSpool</u></FONT>
12.55@110mph, 1.85 60Fts on M&H 23/7.5-15
Acura 1.6EL
D16Y8
SRP Piston 9.0:1
Eagle Rods
Zex Cam
Lovefab A/C SST
Precision SC-50 .60/.63 ar
Skunk2 IM with GSR TB
PWR IC
Tial BOV and 38mm Wastegate
Kteller 3 inch exhaust
Clutch Master Stg 4
dyno numbers: 300whp/215ft-tq @17psi Mustang Dyno (Pump Gas)
<FONT SIZE="12"><u>Rowdy</u></FONT>
13.19 @ 104.41mpg
Stock '00 CX hatchback
Ghetto fabbed turbo kit
22x8x15 M/T slicks,
Drag gen 1 turbo custom fitted to exhaust manifold.
BBK inline fuel pump,
Saab intercooler,
Blitz blow-off valve.
Hallman boost controller,
FMU.
Autometer boost guage,
Greddy turbo timer.
<FONT SIZE="12"><u>redzcstandardhatch</u></FONT>
14.2 @ 100
90 hatch
d16a6
drag mani
t3 .42/.48
dsm 450's
turboedit
6.5 lbs
spearco intercooler
homemade piping
185 hp/155tw on a dynojet
<FONT SIZE="12"><u>Eli_Vang</u></FONT>
13.3 @ 106
stock block z6
custom manifold
greddy 18g turbo
johnny racer fmic
blitz bov
dsm 450
vafc
act clutch
2" crush bent dp
n/a apex'i n1 catback
stock hx firestone tires..
N/A
<FONT SIZE="12"><u>Ar Fab</u></FONT>
N/A
Precision SC32
Precsion 880cc
Hondata S200
Eagle Rods
JE/SRP pistons
stock Sleeve
GE intake Manifold
RevHard Exhaust Manifold
Ferrea Vlavetrain
Stock Cam and Cam Gear
Tial Bov
Tial WG
407whp 387ft tq (stock sleeves)
<FONT SIZE="12"><u>Kranked91DX</u></FONT>
N/A
JDM D15B (NOT A D16)
Greddy kit.
Greddy fuel management...
Bored out trottle body to 62 mm
Polished and ported head.
Hondata Manifold gasket.
Trust type 24 FMIC
Turboxs manual boost controler
Turboxs Type H bov
Vacuum manifold.
Nitrous Express 35 Import EFI Wet kit @ 35 horses.
Mister Gasket MLS Head Gasket.
Dyno 216 Whp at 8 psi on Mustang Dyno
<FONT SIZE="12"><u>Turbozxi</u></FONT>
N/A
ZC sohc = Jdm d16a6
Completely stock engine.
Turbo Edit
450cc injectors
Tuned on 93 by professional tuner.
One step colder ngks (7's)
2in intercooler piping (HPC coated)
JDM VR4 intercooler
custom equal length manifold made from steam pipe(HPC'd and Heat wrapped) IHI VF22 turbo running ported internal wastegate
2.5in exhaust from turbo back
Action 6 puck kevlar sprung clutch 3000lb p/plate
quaife LSD
<FONT COLOR="blue">Dyno:</FONT>
201 WHP @ .6bar 246whp @ .9bar Dyno pack Dynometer
Oh yea,
Big thanks to Pollito for compiling a bunch of this from previous Turbod16 members.
If you want yours added, just post it in this thread, and I'll get around to adding it whenever I get the time.
Andrew
Modified by Terrabomb at 6:21 PM 12/3/2004
Modified by Terrabomb at 8:16 PM 12/3/2004
60'......1.713
330......4.911
1/8......7.401
mph.....101.26
1000.....9.552
1/4.......11.31
mph......129.84
JDM SOHC Vtec
75mm bore 1.6L SOHC
8:1 arias pistons
Crower rods
GE sleeved block
Ferrea valve train
Zex 59300 cam
N/a
D16Z6 SOHC VTEC
COMP CAM 59300
JE piston rings
polished crank
OEM headgasket
3 angle valve job
450 DSM injectors
MSD BTM
APEX VAFC
Edelbrock fuel rail
14B turbo
HF manifold
2.25" charge pipes
ebay BOV
VAFC Hack
13.5 @ 102 (slicks)
13.4 @ 102 (slicks)
13.3 @ 102 (slicks)
95 Civic Coupe EX
Stock D16Z6
Uberdata
DSM 450cc injectors
Custom Manifold
3 inch exhaust
ACT xtss clutch
Quaife LSD
N/A
Maxrev Manifold
3" Exhaust
Maxrev Dumptube
PWR intercooler
800cc RC injectors
Hondata S200
R/t 1.018
60' 2.279
330 6.432
1/8 9.956
mph 69.61
1000 12.995
1/4 15.546
mph 88.32
1.6 Sohc Vtec
Jdm 4-1 Header
AEM Alt Pulley
UR Crank Pulley
Apexi N1 Exhuast
Test Pipe
Short Shifter
VAFC
OBX intake Manifold
N/A
D16Y7 Coupe
Stock ECU
Stock IM
AFC Hack
Log Manifold
T3 turbine
Tial WG
Starion FMIC
Slicks
N/A
88 crx si
jg cam
thicker head gasket
stock bottom end
custom IC piping
drag manifold
drag downpipe
b&m fpr
dsm 450cc inj.
msd 6AL ignition
boosted 11lbs daily
N/A
12.5@111 slicks
95 ex motor
stock internals
thicker head gasket
fmax turbkit
N/A
13.8@105 MPH
D16A6,
100% stock block
NON-VTEC
Full weight
Stock clutch
Hondata
DSM 450s
N/A
13.04 @ 103.42 MPH
D16Z6: Stock
DSM T25
STD Manifold
DSM 450's
DSM BOV
Custom dual core IC
60'------2.313
330-----6.253
1/8-----9.528
MPH----76.30
1000---12.326
1/4-----14.699
MPH----94.69
D16Y8
Greddy Turbo Kit
intercooled @ 6psi
blue box(untuned)
13.7
-101mph
1998 Honda Civic HX
D16Y5
T25
HF manifold
Starion Intercooler
2.5" downpipe
Cartech FMU
Inline fuel pump
N/A
N/A
00' hatch
stock internals
ihi rhb5 turbo
hondata s200
N/A
T3/T4 54 trim .63AR
22psi and 70 shot
418whp 314wtq
N/A
20psi
Hondata
DSM 450s
306whp 270wtq
N/A
T3/T4
16.5psi
AFC hack
302whp 251wtq
N/A
54 trim SC32 .63AR
~17psi
Hondata S200
287whp 219wtq
N/A
T3/T4 .63
14-16psi
Hondata
RC550s
273whp 240wtq
N/A
D16z6 stock
T3/T4 .63AR 60 trim
12.5psi
Hondata
RC800s
262whp 217wtq
N/A
comp cam
15psi
Hondata
RC550s
259whp 225wtq
N/A
Greddy kit
15psi
Hondata
RC440s
256whp 227wtq
N/A
D16y8
Zex cam
Greddy kit
12psi
270cc
252.3whp 207.7wtq
JRSC
10psi
Hondata
Nitrous Controls
RC440s
251whp 227wtq
N/A
Greddy kit
15psi
Hondata
RC440s
251whp 220.2wtq
N/A
D16z6 stock
T3 .60/.48
11psi
Uberdata,
DSM 450s
230.13whp 206.11wtq
N/A
D16y8 stock
intank 255lph
12.5psi
225whp -- 204wtq
N/A
D16Y8 stock
Greddy 15G
11psi
VAFC
RC440s
219whp 204wtq
N/A
D16z6 w/ headwork
zex cam
Apexi kit
9psi
210whp 168wtq
N/A
D16y7 stock
T3 .60/.48
SMC dual
208.9whp 175.4wtq
N/A
D16y7 stock
Greddy kit
12psi
Hondata
RC440s
205whp 216wtq
N/A
D16z6 stock
T25
10-11psi
Uberdata
DSM450s
205whp 196wtq
N/A
D16y7 stock
T3 50 trim .48AR
10psi
AFC hack
DSM450s
202whp 207wtq
N/A
D15 stock
Greddy kit
10psi
FMU
intank pump
202.3whp 166.9wtq
N/A
D16y8 stock
T3 .60/.48
8.5psi
AFC hack
intank
193.7whp 164.3wtq
N/A
D16y8 stock
Greddy 15g
10psi
Greddy E-manage
RC440s
188.5whp 186.0wtq
N/A
D15B stock
Greddy kit
11psi
Crome
450cc
188whp 159wtq
N/A
D16y7 stock
TD04L
11psi
Uberdata
450cc
186whp 175wtq
N/A
D16y8 stock
T3 .42/.48
9psi
AFC hack
RC440s
186.6whp 170.1wtq
N/A
D16y8 stock
Greddy kit
8 psi
Blue box
184.5whp 170wtq
N/A
D16z6 stock
Apexi kit
7psi
AFC hack
RC440s
185.8whp 151.9wtq
N/A
D16y8 stock
Edelbrock kit
7psi
Edelbrock piggyback
178whp 148wtq
N/A
D16y7 stock
T3 .42/.48
9.5psi
Uberdata
450cc
171.7whp 176.0wtq
N/A
D16z6 stock
Greddy kit
7.5psi
Emanage
171.5whp 160wtq
N/A
D16z6 stock
Greddy kit
9psi
Greddy E-manage
RC440s
168whp
N/A
D16y7 stock
Greddy kit
6psi
Hondata s200
340cc
163whp 158wtq
N/A
D16y8 stock
Greddy 19T kit
~7psi
154whp 147wtq
N/A
D16y8 stock
Greddy kit
5psi
AFC hack
RC440s
134.85whp 135.82wtq
N/A
D16Y8
GReddy kit
Acura 1.6EL
D16Y8
SRP Piston 9.0:1
Eagle Rods
Zex Cam
Lovefab A/C SST
PWR IC
Clutch Master Stg 4
13.19 @ 104.41mpg
22x8x15 M/T slicks,
Saab intercooler,
FMU.
Greddy turbo timer.
14.2 @ 100
90 hatch
d16a6
drag mani
t3 .42/.48
dsm 450's
turboedit
6.5 lbs
spearco intercooler
homemade piping
13.3 @ 106
stock block z6
custom manifold
greddy 18g turbo
johnny racer fmic
blitz bov
dsm 450
vafc
act clutch
2" crush bent dp
N/A
N/A
Precision SC32
Precsion 880cc
Hondata S200
Eagle Rods
JE/SRP pistons
stock Sleeve
GE intake Manifold
Ferrea Vlavetrain
Tial Bov
Tial WG
N/A
Greddy kit.
Trust type 24 FMIC
Turboxs Type H bov
Vacuum manifold.
N/A
ZC sohc = Jdm d16a6
Turbo Edit
450cc injectors
JDM VR4 intercooler
quaife LSD
Oh yea,
Andrew
Re: So You want to turbo your SOHC and want ideas about the numbers it will make - NEWBIE INFO (Terr
thanks i feel important already
i shall give u guys some new numbers once i get dyno tuned with turboedit along my custom manifold
Nice job! Good post.
If you need more cars I can scan my 1/4 slip when I get home, d15b7 turbo power.
Location: Just Drank A 5th of VODKA Dare me to drive, Ca, u.s.
this is a good idea
more setups please
more setups please
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoStMyBoOsT »</TD></TR><TR><TD CLASS="quote"> this is a good idea
more setups please</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Snail Tuning »</TD></TR><TR><TD CLASS="quote">your numbers are off on my time.
i ran a 14.068 at 102mph
and dynoed 183.9whp and 154 torq.
this was untuned, at 9.5psi. never saw 10psi.
</TD></TR></TABLE> Thats what i was goin to say...16s omg i can run that on a stock civic well hope u edit that cause it threw me off other than that good post ill be puttin this n my favz One more thing i think that if u specify the car it would be better cause u think about it a 92 cx and 99 coupe with the same set-up will have different #s well thats what i think but ehh cool thread either way
wow,thats some good ****.
Modified by dabig1 at 6:16 PM 11/28/2004
hey wheres my name at?? stock d16z6.. custom tubular mani.. greddy 18g turbo.. greddy piping.. 2" crush bent dp.. 2.25 exhaust.. vafc hack.. 13.3@106
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eli_vang »</TD></TR><TR><TD CLASS="quote">hey wheres my name at?? stock d16z6.. custom tubular mani.. greddy 18g turbo.. greddy piping.. 2" crush bent dp.. 2.25 exhaust.. vafc hack.. 13.3@106 </TD></TR></TABLE>
I've never seen your name pop up in the threads sorry, or I just didn't notice it.
IF YOU WANT ME TO ADD YA, or know of the threads, let me have em and I'll put it all together.
I edited your information Snail Tuning.
*raises hand* 198WHP with the stock downpipe and stock cat. Once the new 2.5 dp with cat elimination is on it will be definetly over 200
JDM D15B vtec
factory lsd tranny
clutchmasters stage 4
skunk 2 IM
thermal R&D 2.5 cat back
greddy kit and intercooler
tuned on neptune at 10psi
(god i need a boost controller)
JDM D15B vtec
factory lsd tranny
skunk 2 IM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">boltz -- 287whp 219wtq
D16y8 forged internals -- 54 trim SC32 .63AR -- ~17psi -- Hondata S200
http://www.turbod16.com/album_pic.php?pic_id=2377 </TD></TR></TABLE>
Cool, I made it on there!
Too bad im thinking of selling it for an evo .
Im conflicted about what to do
My setup below is making at least 200HP or even more
I pulled a stock WRX STI '04 maybe a bad driver!
Modified by CivicEJ1 at 12:36 PM 11/29/2004
The setup you put as FJT <u>is not mine</u>.. i just want to clear that...I hope to be in those numbers but my setup is slightly different..
That setup posted under my name is from a friend of mine..Not me.
It would be nice if you had the car type such as "99 coupe" etc, like said above. Nice post though
Cool post! This should help a lot of noob sohc lovers out. I actually went to the dyno again and made 230whp/208wtq at 12psi, I think I could make more, but I am more interested in getting lower ET's. Those track times were my first time at the track, my second time at the track I only had my drag radials and I ended up running 13.4 @ 105 mph, so I almost beat my best slick time. Both times at the track I was running 10psi. My next trip to the track I plan on running 14-15psi with my new 23 inch slicks. I should hit 12's easy and keep in mind this is a full interior civic coupe ex and I am still on the stock d16z6.
Re: (fjt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fjt »</TD></TR><TR><TD CLASS="quote">The setup you put as FJT <u>is not mine</u>.. i just want to clear that...I hope to be in those numbers but my setup is slightly different..
That setup posted under my name is from a friend of mine..Not me.</TD></TR></TABLE>
fixed:D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GiNuWiNe »</TD></TR><TR><TD CLASS="quote">It would be nice if you had the car type such as "99 coupe" etc, like said above. Nice post though </TD></TR></TABLE>
I'll enter it whenever that information is there. Eventually I'll divide it all into car types and group them together.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass »</TD></TR><TR><TD CLASS="quote">Cool post! This should help a lot of noob sohc lovers out. I actually went to the dyno again and made 230whp/208wtq at 12psi, I think I could make more, but I am more interested in getting lower ET's. Those track times were my first time at the track, my second time at the track I only had my drag radials and I ended up running 13.4 @ 105 mph, so I almost beat my best slick time. Both times at the track I was running 10psi. My next trip to the track I plan on running 14-15psi with my new 23 inch slicks. I should hit 12's easy and keep in mind this is a full interior civic coupe ex and I am still on the stock d16z6.</TD></TR></TABLE>
Very nice Numbers. I'm hoping to make that kind of output on my sohc in the spring. Although I am using a dsm t25(7-8 psi daily and 12-14 track). I'm thinking about using 14" Drag radials to hopefully get a mid 13 second time. Hopefully it'll work out using the t25 at around 12psi.
Andrew
fixed:D
Andrew
Re: (Terrabomb)
i just got back from dyno today...just wanted to share
00' hatch
stock internals
ihi rhb5 turbo
hondata s200
170.2whp
160.1tq
00' hatch
stock internals
ihi rhb5 turbo
hondata s200
170.2whp
160.1tq
