Sleeper D15b7 Turbo Build! - Honda-Tech
Old 11-06-2010, 10:19 AM   #1
Honda HP's Avatar
Default Sleeper D15b7 Turbo Build!
So, I've done a little research but want to make sure I'm on the right track before I order all the parts. Any input that is constructive would be helpful! I'm aiming for 250-300hp range. May get different rods to up the hp potential.
D15B7
- JDM D15B Crank
- LS Rods
- Vitara Pistons
- Block Posting
- Freshly Rebuilt OEM Head
- A6 Camshaft
D15B LSD Transmission
- Stage 3 clutch
- resurface oem flywheel
DSM Bluetops
aftermarket FPR
z6 intake manifold
b18 throttle body
DC Turbo Manifold
T25 Turbo w/ internal wastegate
Synchronic BOV
Misimoto FMIC
custom intercooler piping/downpipe
Honda HP is offline   Reply With Quote
Old 11-06-2010, 10:32 AM   #2
Honda HP's Avatar
Default Re: Sleeper D15b7 Turbo Build!
Otherwise my friend has a d6y8 block w/ eagle rods, vitaras, and mico polished crank for sale...may pick that up and build y8....anyone?
Old 11-06-2010, 01:20 PM   #3
nonvtecD's Avatar
Are you building it yourself or having a shop do it? D15s are cool, and rarely built, but everyone is going to say just go with the D16 and be done with it. If your friend's motor is already built I would convince him to sell it to you on the cheap. You're going to make a lot more safe power with the eagle rods and the D16.
nonvtecD is offline   Reply With Quote
Old 11-06-2010, 07:45 PM   #4
Honda HP's Avatar
He ended up selling it. I do have a friend who runs a machine shop so any work that is needed i know i can have done on the cheap. What do you guys think of the d15 setup? People keep telling me the d15b crank won't work for what I'm trying to accomplish. I really need some help on this guys!
Old 11-06-2010, 10:56 PM   #5
LTCxD2B's Avatar
Quote:
Originally Posted by scottdh20 View Post
two way to go about it
1) jdm d15b crank w/ either d16 rods(stick out of the hole or better yet fj distributors custom jdm d15b i beams
2) check out turbod16.com and search for d15b8 rods, there is some guy in hungrey makeing them for $300ish i think like 350-380 shipped , i have been waiting to see a transaction go down to see how good the quality is and make sure he isnt a scamer, however his shop seems to have an extremely good reputation in europe.
thethings to consider are:
the d15b7/8/2 crank is not as beefy as the d16/ d15b cranks. it is said to keep it around 300 with the factory d15b7 crank maybe 350 on a really good tune, it also is only partially ballanced. whereas the jdm d15b crank is just as strong as the d16 crank which has seen 700+ whp as well as being fully forged and balanced from factory.
but then again the d16 crank was thought to fail at 300whp as well as the factory sleeves but we see how far we have come since then as tuneing softwear gets better and better and more percise the limits are being pushed farther than ever.
good luck
LTCxD2B is offline   Reply With Quote
Old 11-06-2010, 11:00 PM   #6
LTCxD2B's Avatar
as long as the crank is in good condition and not pushed it'll last more than one run
Old 11-07-2010, 08:42 PM   #7
Honda HP's Avatar
bump. just need some help if I'm on the right track for this setup.
Old 11-08-2010, 08:00 AM   #8
wmac's Avatar
i'm planning to do a similar build, jdm d15b with ls rods + vitaras, and z6 head
ls rods should be ok for 250-300hp.
if you plan on using a b7 head, the CR will be very low.
the only place i know to find a jdm d15b crank is in a jdm d15b block.
wmac is offline   Reply With Quote
Old 11-08-2010, 08:20 AM   #9
Honda HP's Avatar
i was thinking of using a ihi rhb5 turbo instead so that it's spooling at idle basically. kinda a version of tdi? lol
Old 11-10-2010, 01:50 AM   #10
Honda HP's Avatar
got the d15b crank on order for not too much...90. rods are chillin in storage. pistons on order soon. 75.5mm pistons for sure. then source a z6 head or figure out something to up the CR for the d15b7 head
Old 11-10-2010, 10:32 AM   #11
wmac's Avatar
Quote:
hurry, its your lucky day
http://cgi.ebay.com/ebaymotors/Honda...ht_4890wt_1121
Old 11-12-2010, 04:32 PM   #12
ls rods wont fit on a b7 they have smaller journals
es01civy is offline   Reply With Quote
Old 11-12-2010, 06:54 PM   #13
Honda HP's Avatar
Quote:
I know that dude, that's why I'm using the JDM D15B Crank. Which has journals same as d16 but mains for the d15 block. Thanks tho.
Old 11-12-2010, 06:56 PM   #14
Honda HP's Avatar
Actually. Just had another idea to still utilize the b7 head...LS rods are 137mm while b16 rods are 134mm. this should solve the Compression issue as well as piston height.
Old 11-12-2010, 07:21 PM   #15
AlexDphoto's Avatar
sounds fun, my roomate had a boosted ef D15 with a big 16g (or something along those lines) with DSM injectors and an ebay 2.5inch.
Never dynoed it or anything, he was using an ECU from xenocron.
Car was fun as hell to pick on people with, no one expected it lol, I think he even beat an SRT-4 on the hwy. lol
have fun
AlexDphoto is offline   Reply With Quote
SOHC turbo build for 200 HP cityofcaterpillars Forced Induction 14 05-26-2016 05:38 AM
D15b7 Tiny Turbo help PureGarrison Forced Induction 26 10-06-2015 04:07 PM
b7/z6 mini me turbo build based13 Honda Civic / Del Sol (1992 - 2000) 6 05-03-2013 10:25 PM
fully built JDM D15B RJ209_EJ2 All Motor / Naturally Aspirated 8 10-31-2009 10:09 AM
which set up would make more hp? j0keefe21 Honda Civic / Del Sol (1992 - 2000) 54 01-22-2009 10:34 PM
Tags
block, build, built, civic, crank, crx, d15b, d15b7, d16, honda, hp, sleeper, sleper, t25, turbo, y8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
