Signs of a BAD O2 Sensor?? Symptoms?? - Honda-Tech
Old 08-01-2003, 09:33 PM   #1
shermanyang's Avatar
Default Signs of a BAD O2 Sensor?? Symptoms??
okay guys, i'm curious as to what are signs of a bad O2 sensor? running lean/rich? bogging? what are ways to check for signs of a bad O2 visually and electrically?
i'm asking because i'm running super lean when the O2 is plugged in and of course super rich when i unplug them due to the CEL/limp mode. i have 2 O2's one in the cat and one right after the turbo and both do the same thing. i just bought a Bosch universal O2 today for $80 along with 36 new spark plugs(like to have a little stock pile) and just want to make sure it could be my O2's before actually installing the new O2.
shermanyang is offline   Reply With Quote
Just replaced primary O2 sensor..is read O2 sensor and CAT bad now? 98IntegraLSNonVtec Tech / Misc 9 08-04-2006 10:18 PM
Bad o2 sensor? AllMotorDA9 Tech / Misc 8 10-26-2004 11:24 AM
Car Is Stuttering After Re-install OF o2 Sensor. integranator Forced Induction 3 07-14-2003 04:07 PM
will the car run normal without the o2 sensor plugged in? juniordc2 Acura Integra 29 09-19-2002 09:39 PM
Oxygen sensor ?? nfn15037 Acura Integra Type-R 5 01-18-2002 02:16 PM
Tags
02, bad, crx, gsr, h22, honda, o2, rich, running, sensor, signs, symptoms, symptons, tech, turbo, unplug
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
