shattered thrust bearing on built motor???
Old 06-25-2007, 10:13 AM
B_radGSR's Avatar
Default shattered thrust bearing on built motor???
Thrust bearing shattered after only 300 miles!!!!!!
Mods:
82mm JE pistons 9.2:1
File to fit rings
Eagle rods
All brand new ACL bearings
Golden Eagle block guard
ARP main/head studs
Cometic head gasket
My question is If you install a thrust bearing backwards.....meaning the oil runners are not next to the crank, would this cause it to wear down and eventually shatter? Could i bring forth this information to the shop as an installation error??
Old 06-25-2007, 11:03 AM
Unceasing Measure
Archidictus's Avatar
Default Re: shattered thrust bearing on built motor??? (B_radGSR)
I've never heard of a thrust bearing shattering. Good luck with this.
Old 06-25-2007, 11:18 AM
building boost's Avatar
if you install it backwards you would've heard it knocking after less than 50-100 miles.
Old 06-25-2007, 11:19 AM
New User
Boostfed's Avatar
Default Re: shattered thrust bearing on built motor??? (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">I've never heard of a thrust bearing shattering. Good luck with this.</TD></TR></TABLE>
Ditto. WOW!
Old 06-26-2007, 11:15 AM
B_radGSR's Avatar
well the only signs it gave was that when at idle when u push the cluth in it would die, or serious drop in rpm!
Old 06-26-2007, 12:28 PM
ringgold's Avatar
Default Re: (B_radGSR)
This one guy that rebuilt and engine of mine once said that when he tore down my engine and inspected it that my thrust bearing was still in good shape. He made a comment like "you had a good clutch in there" or something like that. Since you made that last comment about the clutch related problem it made me think of it.
If the crankshaft had to much play in it or run-out whatever its called, and when the clutch was being used could it have put enough pressure on that bearing to make it shatter?
Old 06-26-2007, 12:30 PM
vaporboy12's Avatar
what clutch was in the car?
Old 06-26-2007, 12:41 PM
Moderator in Chief
Muckman's Avatar
Does the bearing have significant wear on the backside? not the side with oil runners? If it does then thats proof it was installed improperly.
Old 06-26-2007, 03:26 PM
boosted k20's Avatar
Default Re: shattered thrust bearing on built motor??? (Muckman)
if u step on the clutch and the car shuts off, then u have crank walk. this will build up insanely high oil pressure and cause damage to the crank and block!
Old 06-26-2007, 03:32 PM
rebo0t's Avatar
pics of the thurst? something new everyday..........
Old 06-26-2007, 05:37 PM
postman's Avatar
Default Re: (rebo0t)
if it shattered how did yoiu know it was in backwards or were all of them backwards.
i could see grinding to eventually break apart but shatter damn.
Old 06-26-2007, 06:00 PM
B_radGSR's Avatar
i have an ACT Extreme pressure plate with a street disc. Only one half of the bearing shattered, the other half came out. The bearing itself has EXTENSIVE wear on the side with the runners, aka they are shaved down almost flat. The other side is really shiny, i will post pics of it tomm.
Old 06-26-2007, 06:31 PM
Shooting Star
vtecspeed1320's Avatar
its the clutch presure plate...
Old 06-26-2007, 08:15 PM
Moderator in Chief
Muckman's Avatar
Default Re: (vtecspeed1320)
nfw, after only 300 miles?
Old 06-26-2007, 08:43 PM
RC000E's Avatar
Default Re: (Muckman)
No way....you have something more at play here other than the damn pressure plate. Thousands of people run that pressure plate and don't grenade thrust bearings. There has to be some type of install error or oiling issue.
Old 06-26-2007, 10:12 PM
Pullig's Avatar
Default Re: (RC000E)
same **** happend to my buddys h22 .. he used that same pressure plate ... when he pressed in the clutch the idle rpms dropped dramatically... eventually messing up the motor around 300 miles like you here is the thread to that .....
https://honda-tech.com/zerothread?id=1697767
Old 06-27-2007, 03:54 AM
Default Re: (Pullig)
its not the pressure plate!!!!!!!!!!! the crank clearance - endplay (not crank bearing clearances) was outta spec which created crank walk. u will most likely need to machine the block to fix that problem or just get a new block
Old 06-27-2007, 05:39 AM
B_radGSR's Avatar
yeah def not the pressure plate. I have ran that same clutch and pressure plate for around 15,000 on the stock gsr motor. Is there any possible way to prove it was an installation error? I will post pics of the actual bearing later on today
Old 06-27-2007, 06:23 AM
WHTZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B_radGSR &raquo;</TD></TR><TR><TD CLASS="quote">Thrust bearing shattered after only 300 miles!!!!!!
Mods:
File to fit rings
Eagle rods
ARP main/head studs
Cometic head gasket
My question is If you install a thrust bearing backwards.....meaning the oil runners are not next to the crank, would this cause it to wear down and eventually shatter? Could i bring forth this information to the shop as an installation error??</TD></TR></TABLE>
You did install it backwards....The 2 grooves should be facing you when looking at them.
Old 06-27-2007, 06:45 AM
B_radGSR's Avatar
i didn't build it a race shop did...thats y im trying to prove that it was due to an installation error! So which way would be correct? Oil runners toward the crank or away from it?
Old 06-27-2007, 06:48 AM
New User
Boostfed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B_radGSR &raquo;</TD></TR><TR><TD CLASS="quote">i didn't build it a race shop did...thats y im trying to prove that it was due to an installation error! So which way would be correct? Oil runners toward the crank or away from it?</TD></TR></TABLE>
Toward crank
Old 06-27-2007, 07:28 AM
tony1's Avatar
Bottom line is if you pay someone to build your motor and the thrust bearing "shatters" in 300 miles, it's the builders fault....
Old 06-27-2007, 09:27 AM
Bakeoff's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Bottom line is if you pay someone to build your motor and the thrust bearing "shatters" in 300 miles, it's the builders fault....</TD></TR></TABLE>
Good luck making them fix it if he's already torn it apart... Might happen. Might not.
Old 06-27-2007, 11:21 AM
B_radGSR's Avatar
see took care of that one too. They tore it down I took the bearing into 2 other machine shops and they said it was installed backwards, but wouldn't write me a reco because they didn't wanna step on any toes. What the hell is that?!
LightningTeg
09-02-2011 01:46 PM
llloyd
14
04-27-2008 04:22 PM
ntrider
03-03-2006 11:58 PM
marcussmith26
01-28-2006 01:45 PM
luckypon7
11-21-2003 05:13 PM
Quick Reply: shattered thrust bearing on built motor???
