Ryguy's New Turbo Build
Ryguy's New Turbo Build W/ Pics!
Hey Guys,
I’ve helped people build motors, but I’ve never had a boosted motor before, if you can believe that. So here is my build that I’ve been putting together for the last year. If you have any suggestions or comments, I would like to hear them, but I don’t want to get slammed here. I’m a poor college student who is trying to have a little fun lol. I will be posting and updating with pictures and new items as I receive them. She will hopefully be tuned and put on the dyno for numbers when it gets warmer out here, and everything should be put together in the next month! I don’t want anything more than 350-375 whp initially, and it’s going to be my daily driver.
Block:
- B18A1 block
- LA Sleeves (Bored to 84mm)
- GSR Eagle H Beam Rods
- ARP Head Studs
- ARP Rod Bolts
- Arias 10.8:1 Pistons
- Arias Piston Rings
- Arias Wrist Pins
- Micropolished GSR Crank
- King Thrust washers
- King Rod Bearings
- King Main Bearings
- GSR Oil Pump
- GSR Water Pump
- OEM GSR Timing Belt
Head:
- B16 head (Decked/3 Angle Valve Job)
- 1st Gen Skunk2 Intake Manifold
- CTR Cams
- Stock Cam Gears
- Ferrea 6000 Series Dished Valves
- Supertech Valve Guides
- Supertech Dual Valve Springs
- Supertech Retainers
- Golden Eagle 84mm Head Gasket
Transmission:
- GSR Transmission
- OEM Flywheel
- Competition Stage 5 6 Puck Clutch
- Competition Pressure Plate
Turbo Setup:
- Precision 6165
- Custom Manifold (Made by PFI_NAYR_ONE)
- Tubes and Hoses Oil Line
- CXRacing Charge Piping
- Precision 350 hp Back Door Intercooler
- Greddy Type RS BOV
- Turbosmart 38mm Wastegate
- Tapped GSR Oil Pan
Fuel:
- 1000cc FIC Injectors
- Walbro 255 Fuel Pump
- Stock Fuel Rail and Regulator
Exhaust:
- 3” Stainless Exhaust Piping
- Vibrant 3” StreetPower Flat Black Muffler
- Vibrant 3” Resonator
- Vibrant Flex Pipe
Electronics:
- AEM Wideband
- AEM Boost Gauge
- Rywire OBD2B to OBD1 Conversion Harness
- P28 ECU w/ Hondata S300 and Boost by Gear
Extras:
- Speedfactory 4 Bar Map Sensor
This is how the car currently is with my B16.
Block:
- B18A1 block
- ARP Head Studs
- ARP Rod Bolts
- Arias Wrist Pins
- King Rod Bearings
- GSR Oil Pump
- GSR Water Pump
Head:
- CTR Cams
- Stock Cam Gears
Transmission:
- GSR Transmission
- OEM Flywheel
Turbo Setup:
- Precision 6165
Fuel:
Exhaust:
- Vibrant Flex Pipe
Electronics:
- AEM Wideband
- AEM Boost Gauge
Extras:
Re: Ryguy's New Turbo Build
Here are some of my picture from the stuff I have for my turbo setup. Idk how to write the description in words above each picture, but I'm sure the pictures are pretty self explanatory.
I literally just got these as I was finishing up the last post. I want to give a big thanks to Innes on here. He hit me up about these cams, and these are absolutely flawless '00 ITR cams.
Thanks. It's taken me awhile to get almost everything together. Craigslist and the marketplace on here have become my best friends to find parts. Taxes gave me a nice amount to spend to finish it up.
Do u mean the little plate that has the serial number for the cartridge? The number on is 700177-14. I'll get a picture up when I get off work.
Haha you guys have any suggestions? I have friends that use a stock fuel rail. Do I need an aftermarket one or will I be just fine with a stock one?
Or save that upgrade for a later date when/if you want to make more power.
I pieced everything together. I spent a lot of time on craigslist looking for parts. There were only a few things that are actually new cuz I found awesome deals through friends and on here.
I know I haven't updated this, but it was because it didn't look like anyone was interested. After some work and assembling this is the motor. Still have a couple small things to attend to, but it should be running in about a week! I also spent about an hour and a half sanding and polishing the compressor housing. Looks a bit better.
I also picked up this blown 57 trim garrett turbo for a good price and rebuilding it. Took it apart and cleaned it. The guy I bought it from on here said that the wheels were in good shape, but when I looked at the turbine, the blades were literally torn to shreds, so now i'm just waiting for the turbine wheel I ordered. Douchebag.
