Ring Gap question's for turbocharged engine
So last week I started filing the rings for my K24 engine that I am putting together. The rings are CP Piston rings. I used their spec sheet to figure out what I should gap the rings. Most that have built an engine know the formula. They suggested a wall clearance of .0035" for the pistons. I went with a P2W clearance of .0040" after doing some research and talking to a few experienced engine builders that had more experience with CP Pistons than me.
So here is the deal, from my calculations my top ring gap should have been somewhere around .022 - .024" and the second ring gap should have been around .024 - .026" as per my calculations using the CP specs. I am using the 87.5mm shelf pistons in the K24A1 stock sleeves. The engine will get pushed to whatever it can hold at some point, but will be more of a street engine and not one that is going to be raced on a regular basis. It will also be ran on gasoline since ethanol is not really an option for me. This is what my ring gaps looked like with the rings placed approximately 1" into the bore using the piston to level them out in the cylinder. Some rings were simply placed into the bore and not filed, others were slightly filed to achieve a wider end gap.
cylinder 1 = .025" for the top ring and .028" for the 2nd ring
cylinder 2 = .024" for the top ring and .027" for the 2nd ring
cylinder 3 = .023" for the top ring and .025" for the 2nd ring
cylinder 4 = .027" for the top ring and .030" for the 2nd ring
From my research, these gaps should probably be alright considering they will be in a turbocharged gasoline engine. They seem to be a little on the loose side, but should work I think. However, I am concerned that I will get too much blow-by. I have sent CP an email and should hear something maybe tomorrow. I did also talk to an experienced engine builder. He said that they sounded too loose for stock sleeves, but might work just fine for me. He does not like to run them that loose, and said that I may need a new set of rings.
What do you guys think?
Who is Mr Robot?
Re: Ring Gap question's for turbocharged engine
What he said
Who the hell honed that block? You shouldn't have a different ring gap for each cylinder, they should be fairly even across the motor and not .030 loose
Also, me and a friend that is also a member of this board and who has showcased his build checked each thing that needed to be checked/measured not long ago. The bores were honed and the machine shop who did it, did a pretty dang good job. There was some slight variation on the dial bore gauge, but nothing out of the ordinary.
Who is Mr Robot?
Whether they were filed or not, the gap shouldn't be that big
So the machine shop apparently did a **** job of honing
Moderator in Chief
What is the EXACT bore? And what multiplier are you using for the gap (bore x .00??)?
Im confused why some are filed and some are not? Are you filing them with an angle grinder? You have a spread of 5 thousanths on some of them.
Those ring gaps are all way too big already (unfiled or not). Buy 4 new ring packs.
Also, I have heard of end gaps bigger than this. Not necessarily for a Honda engine, but I do not build several engines a year nor do I really build anything else other than Honda engines. But obviously some people do.
I stopped filling rings when I saw that the second ring was already at .030" and had never touched my filer. From that point I just stuck the rings in and measured. These are the measurements I got.
Seems to me whoever made the rings for CP had a bad day at work. My cylinder bores are not that out of whack. Cylinder #3 are for sure two of the rings that I filed and they are smaller than the rest. The 2nd rings on the rest of the cylinders were never touched other than to be measured.
I read a lot on another forum, more than I post anyways. On there I have read where guys have gotten bad packs of rings and I have also seen where guys run really big ring gaps, however, that was not on a Honda engine. It seems that may be what happened to me. With this build that does not surprise me.....
Who is Mr Robot?
Try moving rings around to different cylinders. If the measurement changes the hone is fucked. If they stay the same you have a bad ring pack and need a new one
As stated the ring gaps need to be uniform. And .03 is rather large. You'll have issues with blowby, poor cylinder sealing, etc.
And don't try and troll the master :p
I troll hard lol
I troll hard lol
I troll hard lol
I troll hard lol
Who is Mr Robot?
I would definitely call, they get slammed with e-mails
Also I think your multiplier is off (don't quote me though lol) I always go by info off endyns site www.theoldone.com
Moderator in Chief
Ok if the top ring UNFILED is bigger than the ones you have alrady filed then thats a problem. If you move it other cylinders and the gap stays the same then the bores are consistent obviously.
Get new ring packs and start over.
And pick a single multiplier. bore x .0065 for top and .0070 for second is good for a big power turbo engine. Sometimes the second ring is large out of the box which is OK just make them consistent.
You'll see some people order larger rings so that you can get the gaps you want, not what they give you by default.
Also, gaps and PTW are dependant on fuel type and power. If you're using ethanol then I'd run gaps and PTW on the tight side, but gas is a different story. If you are using gas then you want to open up your PTW quite a bit. I'd shoot for at least .005 PTW depending on power.
Almost all of these comments are null and void until we know your fuel and power goals.
Fuel will be gasoline and power on pump gas I am shooting for 550whp or so. On race gas i have enough fuel system for something around 750whp based on what I have seen other cars make by the same tuner. The engine is not going to be a full race engine, so street miles are more important than making maximum power.
I just talked with CP, the guy I talked too also said that the gaps were too big for what I was going to be doing with the engine, which is what most people would say. He offered me another set of rings from them with the same part #, but I am a little leery of that and do not want to waste money on them and end up with the same results. I talked with some other guys and someone suggested using Hastings Rings. They were V8 guys though.
Get 88mm rings and file them down to what you want.
That's pretty high for pump gas and really close to the margin for even 93oct, but to each their own.
The numbers you came up with .022-.024 and .024-.026 are what I would do for a street driven motor. The tighter side of the spec will give you better performance. Looser than desired, you need to make sure your PCV system is up to par. Personally I'd go with .022 on top and .026 on the second ring. .015-.018 for the oil guide rings.
I really have no clue what the engine will make on pump 93 octane, just going from what I have seen the 550whp is just what I was shooting for. If it makes over 500whp, I am cool with that. It is a rod/piston K24 using a PTE 6765 and .82ar. Has ID1000's, bosch 044 and walbro 255. I wished E85 was an option for me, but it isn't. Closest ethanol pump is around 70 miles away, if it is still there.
You got a part # for any specific 88mm rings or what do you suggest using? Anything specific?
Who is Mr Robot?
Yea 550 on 93 is brave. That's basically the ragged edge or a bit over for only straight 93 octane. I would highly recommend a water/meth injection system with a high methanol ratio (70/30) to help dop IATs, bump fuel octane a bit and help eliminate any signs of detonation
Your tune has to be dear nuts accurate for those power goals on 93, detonation is a serious risk ane at that level the slightest bit will kill your motor in no short order. Also if you ever get a bad tank of gas you can kiss your bottom end goodbye.
I don't know what you're doing for a tuning solution but I hope you employ numerous failsafes to protect your motor and I'm hoping you're incorporating a knock sensor as well so you can have various failsafe measures like wideband o2 monitoring that either lowers boost, pulls timing/fuel etc and have a knock count threshold so the ecu can pull timing and other things I mentioned. You'll have to keep an eagle eye on various things like lambda, fuel pressure, knock, IATs, etc
If e85 is plentiful in your area I would ask that you seriously consider that as a safer alternative to 93. You'll have a much greater knock threshold and can make 550 plus with a much larger margin of safety and error should an issue present itself
see i hate this crap. it seems from my personal experience that there is always 1 ring that comes way too big of a gap to use right out of the box and i wind up having to order another set.
.004 might be a tad tight but tune it well and i think you will be ok. i used .0045 for my cp's at about 500hp no problems.
your gaps can be up in the mid to upper .020 range for the 2nd ring, but id keep the top ring around .023-.025 max
I have been posting on this message board since 2001, I have also been messing with Hondas since around 1997. If I am in here checking and posting about the gap of piston rings on a K series engine, wouldn't you think I would already know what I would need to do to monitor knock and air fuels? My oringinal post about the ring gaps I found could have been confusing and I could have probably worded it differently, but I know a little about tuning and what is needed to keep the engine happy.
So we shall see what comes of this.
