revhard stage 2 has 9psi spring, why would joetech tell me 7psi..
Smarter than you
i went to jotech the other day and asked a few things about the revhard stage 2 kit.. it has a deltagate wastegate with a 9psi spring right, well the guy at jotech told me it has a 7psi spring.. is there something i dont know?
im gonna switch to a tial wastegate anyways, which has a 4.sumthing psi spring right.. will i need a boost controller with the tial to run 7psi... i have a LS so id like to tune it through 10psi in case boost spikes(hopefully it wont with the tial, and also in case i decide to turn it up to 9psi...
lastly lets say im running the tial wastegate on stock boost but i add a testpipe, will this make me automatically boost more, with out turning up the boost?
Re: revhard stage 2 has 9psi spring, why would joetech tell me 7psi.. (DIRep972)
I comes with a 7psi spring. It can come with the 9, but Im sure it comes with the 7psi.
Just sell it and get the tial. No, with a test pipe you wont boost more, just quicker.
art
art
though revhard lists a 9psi spring with their stage 2 kit. it could be possible that jotech specifically requests a 7psi spring instead for their kits they sell.
Re: revhard stage 2 has 9psi spring, why would joetech tell me 7psi.. (bgod)
how can you tell if its a 9psi spring or a 7psi spring....i was told my kit comes with the 9psi spring..but whenever I boost...its around 5 - 7...on the top of my deltacreep...there's a sticker of the number 9...if that helps...
Acturally, you will see a boost creep about 1 or 1.5 psi with the testpipe compare to stock cat.
Re: revhard stage 2 has 9psi spring, why would joetech tell me 7psi.. (b18cturbo)
I would think with the Deltagate you would spike, but I dont spike with my Tial and I have a flex pipe(Test pipe).
art
art
i belive if i read your question right u were also asking if u could adjust the boost with a boost controller if u get the 4 psi spring?
with the springs... they can always be adjusted for more boost... the rating on them is the minumum it will boost...
Smarter than you
Re: revhard stage 2 has 9psi spring, why would joetech tell me 7psi.. (4dr-gsr)
Cyber ITR
01-19-2004 03:38 AM
