Removing turbo... need re tune?
Old 02-20-2012, 07:32 AM
Fnix's Avatar
Default Removing turbo... need re tune?
I am removing my current boosted engine back to N/A. If I will rarely drive the car afterwards is a retune neccesary or will I just use a little more gasoline? Can I still use my aftermarket MAP if it's not boosted?
Old 02-20-2012, 07:36 AM
Blove1991's Avatar
Default Re: Removing turbo... need re tune?
If you are going back to 100% N/A then you should be able to put a stock ECU back in the car. If not then I would go get retuned.
Wait for others to chime in though.
Old 02-20-2012, 07:50 AM
kbouchard1092's Avatar
Yes you would need to retune...Unless you have a OEM ECU and have minor upgrades. If its all stock then oem ecu would be fine. Laeving youre boosted map would not be smart as the timing map is going too be different boosted vs.NA. Re-tune is always a smart idea in any case.
92frostwhtdb2's Avatar
Depending on what engine management you are on will dictate if you can still use your aftermarket map sensor,replace the injectors with the stock size. Otherwise the ecu and map will have to be replaced with stock components also
Old 02-20-2012, 09:14 AM
darkhorizon's Avatar
I probably wouldnt attempt it, because I have never setup a boosted tune to run well not boosted... but technically it is possible...
Old 02-20-2012, 09:24 AM
Fnix's Avatar
mmmm might as well garage it until I get back to the states then... no tuners here in my area of Germany
Old 02-20-2012, 09:30 AM
EK9
Dc4LsTeG's Avatar
Just buy a stock or chipped ecu.. what's the NA set up going to be? If its built get a retune
Old 02-20-2012, 09:47 AM
Retired Moderator
EsotericImage's Avatar
like said ^^ u have 2 options:
oem ecu and replace injectors to stock, fuel pressure to stock
or
retune for NA with what u have.
garaging it will prob be ur best bet.
Old 02-20-2012, 11:42 AM
DirtyDA9's Avatar
If you have no one to tune there in Germany, there of plenty of people on here that sell ECU's chipped that can burn you a map depending on your mods, before they send it to you.
Old 02-20-2012, 11:50 AM
rich7777's Avatar
If the car has been tuned for boost i can't see a reason why taking the turbo off will send the fueling or ignition timing out. The only thing that will happen is that he won't build positive pressure so the car will be driving around in the NA section of the map like it was before when it wasn't under boost ???? I'm pretty much sure he'll be fine (EDIT, providing he removes the turbo only)...
Old 02-20-2012, 11:54 AM
BigMike0147's Avatar
Rich has it right.
The only thing that wouldn't be correct is if the tune wasn't great/correct in the vacuum section for higher rpm's (where it was previously tuned to be under boost). It should be ballpark, but it might not be great (similar to a base tune).
Old 02-20-2012, 12:24 PM
rich7777's Avatar
Yeah i confirm that. OP, please post screen shots of the fueling and igniton tables in the map if possible. I want to see how linear the tables look.
Old 02-20-2012, 05:07 PM
CrackingVTEC's Avatar
Put your stock or chipped ecu back in. You don't want to run the turbo tune on an N/A engine..
Old 02-21-2012, 07:12 AM
Man U FTW
Schister66's Avatar
I agree with Rich. Driving with no turbocharger is just like driving with no boost which should be a condition that has been tuned into the current map. I dont think you should have an issue AS LONG AS your tuner did enough part throttle and light load tuning.
Old 02-21-2012, 07:29 AM
Moderator in Chief
Muckman's Avatar
I do this when I break in new engines. I use the previous turbo tune with no turbo. It'll just run on the vacuum parts of the map. Keep the same EFI components for the tune obviously - MAP, Injectors etc.
However if you are returning the car to NA permanently than just put the stock ECU/EFI parts back in.
coolvtec
Engine Management and Tuning
11-20-2013 12:26 PM
blueballsh22
10-05-2012 07:18 PM
95cxhatch
01-27-2005 09:23 PM
teg92
19
01-20-2005 01:09 PM
Quick Reply: Removing turbo... need re tune?
